Old 07-22-2013, 07:09 PM   #1
330Cole
My Ride: 01' 330Ci
little mods & a little juice
So far I have not done any power mods, and figured it was time to catch up.
I couldnít decide which route I wanted to go, for reasons of cost, maintenance, and fun factor. Also, labor was a serious issue because of my resources and time on this DD. I needed close to $2k in cost, wanted something I could learn from, have close to e46 M3 whp/tq, and fairly reliable on a DD that I could fix if there was any issues.
I have read many N/A, SC, Turbo, and nitrous builds, and couldnít decide on what application was best. So I inquired about something I didnít know much about (Nitrous), to a very reputable, and knowledgeable member on this forum; Rob43, who Pointed me where I wanted to goÖ
The n2o itself would be the main power adder, with a few bold-onís to help it breathe. A true CAI has been ordered, to pull a colder IAT at a slightly larger volume. Catless headers (most likely bimmerbrakes Gen3) will be for opening up the exhaust, and letting the hot nitrous charge out of the engine faster. When my stock clutch goes (145k currently, note: compression test will be done before any nitrous is added) I will go with a lwfw/clutch package (brand undecided). Pulleys/cams are considered. Already have Eisenmann cat back, and 3.38 Diff.
So then I asked Rob how to make the Nitrous ďsafe,Ē because I had everyone and their brother telling me I was stupid and/or going to blow it up. Rob gave me a list of safety featutres, and how they worked. A BottleHeater/blanket will keep bottle pressure consistent at around 950 psi. This means that regardless of ambient temperatures, the spray will have the same preassure behind it to keep things constant. An afr gauge will give the ability to tune through jetting, as well as sound a warning and activate a lean-cut off switch if AFRís reach dangerous levels. A progressive controller will be used to fine tune the shot, adjusting the release to be at a safe rpm window, and come on progressively instead of all at once.
The system will have consistent pressure (monitored through an in-cabin bottle pressure guage), come on progressively within a safe rpm window, be fine-tuned to desired afrís, and have an automatic lean cutoff switch if all else fails.
I will tune up to 75 shot probably. Anything higher will require a direct port setup, and probably some attention to the motor.
Special thanks to Rob43 for all of his help and information!, as well as any members I may (or already have) purchased parts from!
  • KW V1
  • Meyle HD Diff & Subframe Bushings
  • Meyle RTAB & TMS RTAB Limiter kit
  • Lemforder ZHP HD Control Arms
  • Meyle HD FCAB
  • TMS Subframe Reinforcement kit
  • TMS Swaybars F/R & Adjustable Endlinks
  • 3.38 Open Diff
  • BMW Performance SSK
  • BB Gen 3 Headers
  • Eisenmann Race Exhaust
  • 3.5" Longtube CAI
  • 3.5" Conforti Eurosport Filter
  • Shark Injector
  • Stoptech Slotted Rotors
  • TMS SS Brakelines
  • ST Sport Pads
330Cole is offline   Reply With Quote
Old 07-22-2013, 09:15 PM   #2
Twin_Turbo_S54
My Ride: M3
lean shut down reacts slower than n20 and...
get a set of colder plugs, heat range 8 at least.
and If you can, turbocharge the engine and do not use n20. Its not desinged for the hobbyist, its more like for the racers.
Requires a lot of attention before each use.
n20 does not forgive even the smallest mistake.
To be on the safe side get a turbo kit from a good vendor and stay on the safe side.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 07-23-2013, 06:55 AM   #3
330Cole
My Ride: 01' 330Ci
I have been very impressed with the turbo kits I've seen, however it looks as though 7k is the minimum finished price.
The plugs are on my to do list, forgot to put them in there, thanks!
  • KW V1
  • Meyle HD FCAB
  • 3.38 Open Diff
  • BB Gen 3 Headers
  • 3.5" Longtube CAI
  • Shark Injector
  • TMS SS Brakelines
  • ST Sport Pads
Old 07-23-2013, 08:23 AM   #4
BDUB328I
My Ride: bmw 328i S54 sedan (
Technique tuning didn't impress? If I didn't swap s54 I would have went with them. Nick G is a legend
BDUB328I is offline   Reply With Quote
Old 07-23-2013, 08:46 AM   #5
330Cole
My Ride: 01' 330Ci
I said I was impressed... Lol TT is the only kit I found for my car and the videos I've seen looked promising, however cost is pricey for me. Still a great piece none the less though!
  • KW V1
  • Meyle HD FCAB
  • 3.38 Open Diff
  • BB Gen 3 Headers
  • 3.5" Longtube CAI
  • Shark Injector
  • TMS SS Brakelines
  • ST Sport Pads
Old 07-23-2013, 09:07 AM   #6
bAby norAA
My Ride: 01 BMW 330i
nitrous can be very safe if you run it properly. Make sure you run it with some safety features and be smart about how and when you use it and you will be fine. WOT switch is the only way to run it and probably the most important, a window switch (there are a few inexpensive ones out there that are very reliable). Make sure you invest in a bottle heater, vent tube and buy yourself an accurate scale to weigh your bottle on. Like someone above said make sure you get some colder plugs (BKR7's) and make sure you have the kit jetted correctly (on a dyno is really the only way dont rely on manufacture specs).
I didnt read your whole post, i'm assuming you are using a wet kit? do not run a dry kit on your car. And make sure your fuel pump is working properly and wont give out on you.
| VF Supercharged Stage 1.5| Southbend Stage 2 Clutch | ZHP Cams | Technik Headers |
bAby norAA is offline   Reply With Quote
Old 07-23-2013, 09:19 AM   #7
330Cole
My Ride: 01' 330Ci
The progressive controller will be used to control the window/WOT feature. A bottle heater/blanket will be used. It is most likely going to be an NX proton plus kit, (wet). Tuning would start at a 35 shot, with factory recommended jetting as a starting point. From there, I will increase the fuel jetting until afr's are safe.
  • KW V1
  • Meyle HD FCAB
  • 3.38 Open Diff
  • BB Gen 3 Headers
  • 3.5" Longtube CAI
  • Shark Injector
  • TMS SS Brakelines
  • ST Sport Pads
Old 07-23-2013, 11:31 AM   #8
Sweed
My Ride: 07 6.0L / 04 M3
I know everyone has there difference's but I love nitrous
Here is a 100 shot I did on a N/A M3 years ago using a lot of the items your looking for. http://www.e46fanatics.com/forum/sho...d.php?t=691685
I know it's an M3 but all in all it was fun.
Doing your own work is the best part and you learn so much more from it.
Good luck
AA HKS Stg 2 / Nitrous Express
Sweed is offline   Reply With Quote
Old 07-23-2013, 02:04 PM   #9
SK330ci
My Ride: 02 330ci w/ 3 Pedals
OP,
if you have a list of potential parts for this build i/we would like to see it.
Mods: Header, CAI, Shark, Koni Sport Struts, Rob43 9 Way Shocks, Big Sway Bar, Special Lowering Springs, 3.38 Diff, PFC Z-Pads, 75 Shot Of N20
E46 M3's are just tasty snacks i eat for lunch.
SK330ci is offline   Reply With Quote
Old 07-23-2013, 05:29 PM   #10
330Cole
My Ride: 01' 330Ci
Thanks Sweed!
And yes, I will post some links in a little bit
  • KW V1
  • Meyle HD FCAB
  • 3.38 Open Diff
  • BB Gen 3 Headers
  • 3.5" Longtube CAI
  • Shark Injector
  • TMS SS Brakelines
  • ST Sport Pads
Old 07-23-2013, 05:55 PM   #11
SK330ci
NX Video
Old 07-23-2013, 08:10 PM   #12
330Cole
My Ride: 01' 330Ci
http://www.amazon.com/gp/aw/d/B00470...=sr_1_1&sr=8-1
http://www.dynotunenitrous.com/store...p?idproduct=17
http://www.dynotunenitrous.com/store...p?idproduct=67
http://www.nitrousexpress.com/15718-...-manifold.html
And more afr gear, don't know yet because I might run an lc1 for the cats
  • KW V1
  • Meyle HD FCAB
  • 3.38 Open Diff
  • BB Gen 3 Headers
  • 3.5" Longtube CAI
  • Shark Injector
  • TMS SS Brakelines
  • ST Sport Pads
Old 07-23-2013, 10:54 PM   #13
330Cole
My Ride: 01' 330Ci
Edit
The nitrous express cutoff switch link should have been this http://m.summitracing.com/parts/nos-...FUqk4AodU3YAog
  • KW V1
  • Meyle HD FCAB
  • 3.38 Open Diff
  • BB Gen 3 Headers
  • 3.5" Longtube CAI
  • Shark Injector
  • TMS SS Brakelines
  • ST Sport Pads
Old 07-24-2013, 09:26 PM   #14
330Cole
My Ride: 01' 330Ci
longtube intake just came in, have to replace fender liner before install (old one got ripped off), and my also swap out the no-name dry media filter it came with
  • KW V1
  • Meyle HD FCAB
  • 3.38 Open Diff
  • BB Gen 3 Headers
  • 3.5" Longtube CAI
  • Shark Injector
  • TMS SS Brakelines
  • ST Sport Pads
Old 03-11-2014, 09:34 PM   #15
330Cole
My Ride: 01' 330Ci
So to bring this back from the dead, I have the intake and headers installed, and an innovative lc1 to take care of the check engine light from not having cats, and can also be used to display afr's, the person I bought it from even included the necessary gauges. Just some more electronics and the kit itself and I should be good to go. I want to get a compression and leakdown test before anything though, and possibly a little attention to the fuel system just in case.
  • KW V1
  • Meyle HD FCAB
  • 3.38 Open Diff
  • BB Gen 3 Headers
  • 3.5" Longtube CAI
  • Shark Injector
  • TMS SS Brakelines
  • ST Sport Pads
Old 09-06-2015, 09:05 PM   #16
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Refresh my memory, what ever happened with this ??
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 09-07-2015, 07:55 AM   #17
330Cole
My Ride: 01' 330Ci
I ran into some troubles getting the cel to go off using the lc-1, the process was not as easy as I had thought. Going through the rest of the car I found that the disa, pcv, maf and a few other bits needed to be replaced/fixed, and I was spending more money and time and the idea of nitrous go father and farther away. I ended up selling the car to a good friend of mine who knew the whole story of the car since the beginning. Fast forward to about a year later, I bought the car back (as in, a few weeks ago). The car was compression tested and all of the worn parts I previously mentioned were taken care of. It runs better than when I owned it, and now has straight pipes and a welded diff. These mods add a bit of "fun" but I think we can all agree they are not ideal. But other than that, the car is ready for a little shot.
  • KW V1
  • Meyle HD FCAB
  • 3.38 Open Diff
  • BB Gen 3 Headers
  • 3.5" Longtube CAI
  • Shark Injector
  • TMS SS Brakelines
  • ST Sport Pads
Old 09-15-2015, 11:40 PM   #18
lui328i
My Ride: 99 Bmw 328i
I've been working on reinforcing my car full suspension overhaul tranny engine bushings full drivetrain upgrade,m54 intake manifold thinking of active or shark tune check out my post, but I've been thinking of something like 25 shot
always modding
lui328i is offline   Reply With Quote
Old 09-15-2015, 11:44 PM   #19
lui328i
Forgot to mention going to weld the diff, I've thought about it for along time made up my mind I'm welding I want to have fun car is slowly becoming a track car
always modding
Old 10-05-2015, 04:49 PM   #20
330cidrifter
My Ride: 2001 330ci
I'm also going the nitrous route, have all nessecary safety compenents, colder plugs, fuel pressure cut of switch, wideband, etc. Do I need to retard timing, if so how do I go about it?
330cidrifter is offline   Reply With Quote
