Australia
Old 07-22-2013, 11:31 PM   #1
94vtirozguy
My Ride: 330 ci convertible
Oils and recommendations
What oil do you guys recommend as i don't have the handbook ? I have a 2004 330ci with over 100,00 kms on it, and leaks a bit of oil at the moment so wanting something safe and meets spec but a little thicker!
94vtirozguy is offline   Reply With Quote
Old 07-22-2013, 11:53 PM   #2
frostbytez
My Ride: '04 M3
just get it fixed man.. it's probably your valve cover gasket. they go hard and leak
oil i use is mobil 1 0w40
plenty of alternatives, make sure it has LL01 written on it
frostbytez is offline   Reply With Quote
Old 07-23-2013, 12:32 AM   #3
Davconelectric
My Ride: 2 dog powered sled
Doesn't need to be long life if you change your oil more frequently
Do not use this
Davconelectric is offline   Reply With Quote
Old 07-23-2013, 12:44 AM   #4
94vtirozguy
just have the had the valve cover gasket replaced and still leaking from somewhere. Not had chance to get under car yet. But in two months gone from high to oil light coming on.
Old 07-23-2013, 01:06 AM   #5
Hamsocne
My Ride: 2002 330Ci
I have read many oil threads to the point where I am done. At least for now. It seems to boil down to using LL01. Our cars can leak from numerous places.
My issue is that I only drive about 3,000 miles per year and sometimes I add nothing and some times I add almost a quart per year. I change it once a year.
Search for oil leaks and enjoy reading.
Hamsocne is offline   Reply With Quote
Old 07-23-2013, 01:10 AM   #6
Hamsocne
My Ride: 2002 330Ci
Also, if you Google "e46 owner's manual" you can print it out.
Old 07-23-2013, 01:21 AM   #7
94vtirozguy
thanks API SH or higher... 5w30 or 5w40 Synthetic Oil
Old 07-23-2013, 02:17 AM   #8
Davconelectric
2 months means nothing. For all we know you've travelled 30,000kms in that time
Old 07-23-2013, 02:21 AM   #9
selien
My Ride: 330CI
Only **** I use:
I AM OF DUBIOUS NATURE
selien is offline   Reply With Quote
Old 07-23-2013, 03:32 AM   #10
Davconelectric
Old 07-23-2013, 03:33 AM   #11
sonaldinho89
My Ride: e90 325i 6MT
Supercheap auto has plenty of oils that are BMW LL-01 or Longlife-01 approved (just look for that and you'll be fine).
The readily available oils that are LL-01 approved at Supercheap are: (in order of decreasing price)
- Mobil 1 0W-40
- Castrol EDGE 0W-40 A3/B4
- Castrol EDGE 5W-40 SN
- Castrol EDGE 5W-30 A3/B4
- Shell Helix Ultra 5W-40 (Ultra Extra is 5W-30 and LL-04, not LL-01)
- Penrite HPR5 5W-40
- Nulon 5W-40
removed "full synthetic" to make it easier to read, but these are all full synthetic oils
Edited: figured I'd make a proper list for future reference. I've checked the LL-01 status of each of the oils on the manufacturers websites (although I'm a bit confused why Castrol has 3 approved retail oils)
sonaldinho89 is offline   Reply With Quote
Old 07-23-2013, 06:52 PM   #12
94vtirozguy
got Penrite HPR5 5W-40
Old 07-23-2013, 07:02 PM   #13
selien
My Ride: 330CI
Re: Oils and recommendations
ack RIP
Sent from my GT-I9300
Old 07-23-2013, 07:57 PM   #14
sihyonkim
My Ride: E46 325i
How does the Liquimoly LEICHTLAUF HIGH TECH 5W-40 compare to the LEICHTLAUF SPECIAL LL 5W-30 ?
They are both LL01 approved
sihyonkim is offline   Reply With Quote
Old 07-23-2013, 08:56 PM   #15
Brissyjohn
My Ride: 2007 MX-5
Mine is currently on Liqui Moly 5W-40. Previous changes were Shell Helix Ultra 5W-40 and Penrite HPR5. All excellent oils IMHO.
Brissyjohn is offline   Reply With Quote
Old 07-24-2013, 10:18 PM   #16
trive2
My Ride: 1989 BMW 535i
Uhg if that's your attitude to owning a BMW you are not going to have a good time. Oil leaks should be fixed with new seals.
I spend days and days researching oil and boiled down to the most common oils with positive results. Both are LL01 longlife approved and both are as thin as possible when cold whilst being thick enough at running temp.
Mobil 1 0W-40
Castrol Edge Titanium 0W-40
trive2 is offline   Reply With Quote
