ESS TS2+ dyno results - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-11-2013, 08:25 PM   #1
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
My Ride: ESS TS2+ 330Ci
Send a message via Yahoo to Dirtboy
I've had my TS2+ in my car for over 6 years and never had it dyno'ed. Got my chance today.
First off my car's a 2002 330Ci 5-sp. Here's what it's got:
ESS Twin Screw stage II+ 8.5psi supercharger kit
Schrick 248/256/10.8 forced induction camshaft set
Technik Gen2 ceramic-coated headers
SuperSprint free-flow race cats
SuperSprint free-flow middle muffler
Eisenmann race end muffler
OEM "modified" airbox
Snow Performance MPG-MAX water/meth kit
And here's the dyno:
I'm in Las Vegas so the elevation and heat probably hurt the results; it was 85 in the shop. All 3 pulls were done in 4th gear (they were too scared to go into 5th, lol). I also just installed the water/meth kit so it's not dialed in yet.
Just wondering if anyone else with a TS2+ got similar numbers.
Dirtboy is offline   Reply With Quote
Old 05-12-2013, 12:39 AM   #2
lab rat
My Ride: '02 330iT
That seems a bit low especialy for dynojet.
My car has 93mm pulley (this get's confusing as 6 years ago 93mm used to be the TS2 pulley and 91mm was TS2+), coated catless headers, stock exhaust, stock cam, BMW performance intake.
I pulled 331whp (317 after weather adjusting for temp) on Mustang dyno.
BTW where do you spray the meth? Before the SC or after?
Because sleeper
Old 05-12-2013, 03:04 AM   #3
Steven747
My Ride: 05 330ci
seems low thats what a stage 1 aa kit puts down with stock cams if not more
Sponsored Links
Advertisement
Old 05-12-2013, 11:54 AM   #4
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
I'm thinking it's low too. Like I said, could be the heat and elevation difference between Las Vegas and Norway.
I'm spraying the water/meth right before the TB.
I'll have to mess with the water/meth tune a bit
Old 05-25-2013, 11:00 AM   #5
Richaraiza
My Ride: TS2+ 330ci, 135i
Send a message via AIM to Richaraiza Send a message via Yahoo to Richaraiza
I'm running the same numbers, but I've been having problems since install left and right. Biggest problem was the people who installed it never put the spacers for the bracket in. Should have just installed it myself :censored: I dynoed in Colorado in the winter. Then went to Cali and dynoed there at 310.
Uncorrected if anyone is interested.
-Richard Araiza - EVO 3 SSK - D-FORCES - TC KLINES - LINEA CORSA Z2'S - ORION V2'S - ARGUAY LIP(R.I.P.) -
- ESS TS2+ - SS HEADERS - JB FLYWHEEL/CLUTCH - CF TRUNK - O.Z. ALLEGGERITA'S - CUSTOM EXHAUST - 3.23 LSD DIFFS ONLINE-
And much more...
Richaraiza is offline   Reply With Quote
Old 05-25-2013, 11:42 PM   #6
Dirtboy
Grüne Hölle Junkie
Dirtboy's Avatar
I talked to a ESS rep at Bimmerfest. He told me to get ahold of the data files from the dyno pull and send it to ESS. They said they can analyze the data and see if there's anything going on. But I still think that a custom tune will get the numbers up closer to what they advertise.
Old 08-02-2013, 10:01 AM   #7
ATLZHP6M
My Ride: TS2+ ZHP, ESS E39 M5
Dirtboy,
I had my ZHP dyno'd last night. Outside Temp was 82F.
Dyno pulls performed on 4th gear to redline.
I'm hoping to get more power once I get headers installed.
I have the TS2+ tune @8.5 PSI, stock ZHP cams, lightweight flywheel, TS3 catback, and BMW Perf Intake, that's about it for power adders.
ESS TS2+ Street/Track Toy
ATLZHP6M is offline   Reply With Quote
Old 08-02-2013, 01:32 PM   #8
Rob43
Suspension Guru
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by ATLZHP6M View Post
Dirtboy,
Now all you need to make things happy inside your motor is:
http://forum.e46fanatics.com/showthread.php?t=998396
http://forum.e46fanatics.com/showthread.php?t=998401
If you only knew how important these two pieces are,.......research.
SUMMIT POINT WV 1:24:229 SCCA
