Australia
Old 07-23-2013, 08:52 PM   #1
Dazinoz
My Ride: 2001 bmw 318i
Rear passenger Bearing replacement
Hi guys the rear passenger wheel wobbles when off the ground and grinding noise when driving.
Looks like the wheel bearing has gone,
Has anyone had this done and how much would it cost.
Getting the run around from garages on prices.
BMW E46 2001 318i.
Dazinoz is offline   Reply With Quote
Old 07-23-2013, 09:00 PM   #2
Brissyjohn
My Ride: 2007 MX-5
I paid RX Automotive $349 back in January 2012 for a rear wheel bearing replacement. Price included parts and a job very well done.
Brissyjohn is offline   Reply With Quote
Old 07-24-2013, 04:29 PM   #3
TurnersInOz
My Ride: 2004 325i
I'll be doing this pretty soon, as well as a refresh on some of the bushings.
$349 per side is a fair chunk of money, but unless you really want to dig into things, it may be well worth it. It is a pain in the butt to do, and you cannot do it without the right tools.
TurnersInOz is offline   Reply With Quote
Old 07-24-2013, 11:48 PM   #4
Brissyjohn
My Ride: 2007 MX-5
Yeah, it was few hours labour plus parts plus GST. It would take me at least a day to do - even if I had the dedicated tools.
Old 07-25-2013, 10:43 AM   #5
Ballistic325
My Ride: slow and steady
Re: Rear passenger Bearing replacement
Tough to DIY as you need some semi specialist tools.
Basically the entire hub and driveshaft will be dismantled for whichever side you're working on. Bugger to get to and a bugger to get the bearing off then the new one pressed on properly. If you're there, make it worth the effort and do some bushings etc as well if they're required and they most probably are. Then that leaves the other side to done too....
Good luck.
I can help with
* Reading Codes / Coding your car
* R&R FCAs, Tie Rods, Sway links....
* RTABs
Need an RTAB tool? Or clutch fan and water pump tools? PM me.
Ballistic325 is offline   Reply With Quote
