Old 07-23-2013, 11:05 PM   #1
Mr330iM
My Ride: 2002 330i M
Oil question ...
I usually use 5w-30 in my 330 but my wife went out and bought 10w30. My car needs alittle oil to be just right. is 10w30 safe to use ? Curious... I know it's a stupid question
Mr330iM is offline   Reply With Quote
Old 07-23-2013, 11:11 PM   #2
dwtaylorpdx
My Ride: 2005 330xi
I try and keep 1 brand at a time,, other than that.. should be fine. Especially in the summer...
Dave
dwtaylorpdx is offline   Reply With Quote
Old 07-24-2013, 05:22 AM   #3
sprintman
My Ride: Ex 325CI owner
Does either oil meet spec? Most XW30's don't (too thin, HTHS to low etc).
sprintman is offline   Reply With Quote
Old 07-24-2013, 06:06 AM   #4
Foxtrot_Uniform
My Ride: 325Xi
The 3 Series calls for 5W30 on the oil cap... At least on mine it does.
OP.... It is safe to mix different weights of oil. I would stay with the same brand and type and I wouldn't do it all the time, but it should be safe.
Foxtrot_Uniform is offline   Reply With Quote
Old 07-24-2013, 06:13 AM   #5
Efekkt
My Ride: 02 330ci
From BMW website
Approved LL-01 Oils:
Castrol Syntec European Formula SAE 0W-30
Mobil 1 SAE 0W-40
Pennzoil Platinum European Formula Ultra SAE 5W-30
Valvoline SynPower SAE 5W-30
I use the Mobil 1
Efekkt is offline   Reply With Quote
Old 07-24-2013, 06:36 AM   #6
sprintman
We know that genius, but most 5W30's don't meet spec. A 30W oil can be nearly a 20W to a 40W and everything in between. Hence my question, "does the oil chosen meet spec"?
Old 07-24-2013, 06:36 AM   #7
jdny516
My Ride: Oxford Green M5
Pdf
National Capital Chapter #465420
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Frank Smith Tune
TTFS Alpha N
SuperSprint Headers
SuperSprint X-Pipe
DINAN Front Strut Brace
Storm Motorwerks Products
2003 BMW X5 4.6iS | Black Sapphire Metallic | Black Sport | Titan Trim
2000 323Ci | TiAg | Gray | 5MT | SOLD My Progress Thread
jdny516 is offline   Reply With Quote
Old 07-24-2013, 06:38 AM   #8
sprintman
Originally Posted by Efekkt View Post
From BMW website
Mobil 1 SAE 0W-40
I use the Mobil 1
Typo it should be Valvoline SynPower MST 5W30, not the common SynPower 5W30. It should have been fixed years ago but BMWNA are slack!
Old 07-24-2013, 07:29 AM   #9
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
From BMW website
Mobil 1 SAE 0W-40
I use the Mobil 1
Don't forget the BMW High Performance Synthetic 5W-30
Old 07-24-2013, 09:12 AM   #10
Hogan773
My Ride: 2002 325xi
Right but I'm assuming OP is just using any old "5W-30" off the shelf, which won't meet spec.
OP: If you're just adding a little I can't see how it will really hurt much. It will mix in with the other oil. But if you've got a full oil pan of generic 5W-30 oil and not one of the five listed above, I'd do an oil change.
Really no reason not to use the "right" oil. I just was at WalMart a few days ago and they had 5qt jugs of Mobil 1 for $22 and change. I picked up a couple jugs of the 0W-40. Great deal and no excuse to get all analytical about whether something else MIGHT work because you save $5 on the cheaper stuff. Our car doesn't get a lot of mileage anyway so my oil changes can stretch easily past a year. Could probably go 2 or 3 years if I really wanted to.
Hogan773 is offline   Reply With Quote
Old 07-24-2013, 09:13 AM   #11
VishTheFish
My Ride: Ex M54B30 ZHP
Any oil brand that has the bmw LL-01 label on it is the correct oil to use. No real reason to use any other. BMW dealer oil is often the cheapest, and most recommended, but any brand will do with that LL-01 label.
/thread
VishTheFish is offline   Reply With Quote
Old 07-24-2013, 10:13 AM   #12
WDE46
My Ride: '13 128i, '04 330Ci
/thread
LL-01 and nothing else matters!
END OF THREAD!
Where's Jake to lock this down.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 07-24-2013, 11:43 AM   #13
Knight
My Ride: '05 330Ci | '01 325i
I read it as oil needed to top it off. In any case, 10W-30 is not going to break your engine. However, down the road, the short and sweet answer is to stick to anything LL-01.
I'm using Mobil 1 0W-40 at the moment. You can get two 5QT jugs for $45 at Walmart. Cheaper than BMW 5W-30 and factory approved.
Knight is offline   Reply With Quote
Old 07-24-2013, 11:47 AM   #14
Hector45
My Ride: 2002 OB 330i
Damn thats high, they sell them for $26 at my walmart.
Hector45 is offline   Reply With Quote
Old 07-24-2013, 11:55 AM   #15
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Oil question ...
You're one lucky guy. It normally costs me about $60+ just for my oil. And I use Mobil 1
Old 07-24-2013, 12:17 PM   #16
Hogan773
My Ride: 2002 325xi
Ummm he said TWO jugs.....
And they're on "rollback" for 22.47 right now.....even better!
Do you not have WALMART in Valpo Indiana?
Old 07-24-2013, 12:29 PM   #17
jdstrickland
My Ride: '94 325iC & '00 323i
It does not need to be "just right." There is an upper mark and a lower mark on the dipstick. The oil ONLY needs to be between the two marks, it does not have to be precisely at the top. When the oil level reaches the bottom mark, add a full quart, or liter depending on your market.
Yes, 10w30 is okay.
Old 07-24-2013, 12:45 PM   #18
Mr330iM
Oil question ...
Thanks for the responses!
Old 07-24-2013, 06:30 PM   #19
sunsetcoast
My Ride: '99 323i & '00 323iT
It's right across the road from Strongbow.
But, those who haven't been shopping for oil recently may not have seen the recent "rollback" prices. If I didn't already have enough oil for all of our vehicles for the next 2 years, I'd have stocked up on it.
sunsetcoast is offline   Reply With Quote
Old 07-24-2013, 06:53 PM   #20
Knight
Best prices for synthetics I've seen by a good margin. The instant I see Pennzoil Ultra Euro 5W-40 on the shelves I will be stocking up.
