E46 Xi Forum
Old 09-06-2013, 11:57 AM   #21
Kubica
My Ride: 2003 325xi
Originally Posted by Sgtbean View Post
So another small edit to this thread. My steering wheel shake only happens around 55 or so. Usually anything higher and it smoothes out and steering wheel is good. At 55 when I turn the wheel ever so slightly before the tires start to turn I can feel the vibration. It's not crazy vibration either it's a small shake. Any ideas?
Don't worry about it. Do the fcabs and if it's still there just drive faster.
Old 10-27-2013, 07:39 PM   #22
Sgtbean
My Ride: 03 325xi
Front Shake issue
Just hitting this up for people still following. I ended up swapping calipers finally with remanned ones and I believe my shake is gone. Bearings sounded fine no clunks or any sounds when I turned the hub itself. The caliper seems to be the source of my shake and vibration all along.
Sgtbean is offline   Reply With Quote
Old 11-04-2013, 09:51 PM   #23
neutron325
My Ride: 03 325xi
I was driving home and had the noticeable vibration when all of a sudden it was like I had a flat tire and the steering wheel was shaking at 45-60 or so in 5th gear. So I baby it and pull over. Tire was inflated and fine. So I continue driving home and the shake is unbearable at anything over 45. Then all of a sudden it goes back to how it was before all the crazy wheel shake.
This is EXACTLY what my car did when I had a front caliper stick. What you (may have) felt was the rotor warming up, warping (violent shaking), and then getting so hot it smoothed out again. (basically brake fade to the point that it was no longer wagging the wheel)
Did you notice the chassis pulling when you applied the brakes during this?
03 325xi sport appearance, cold weather, Harman Kardon audio, etc
neutron325 is offline   Reply With Quote
Old 11-06-2013, 08:24 PM   #24
Sgtbean
My Ride: 03 325xi
Front Shake issue
I did notice it pull to the left with the passenger side being the shot caliper.
Old 11-08-2013, 05:08 PM   #25
Sgtbean
My Ride: 03 325xi
Front Shake issue
Seems my shake is back. Thought it was all but gone. Does it between about 50-60 ish then smoothes out at 70. Thinking maybe a wheel balance issue.
Old 05-10-2016, 10:15 PM   #26
BUDGET76
My Ride: 03' M3 & 95' 330TI
Resurrecting an old thread as I'm having the same issue on my 330XI.
I was getting the usual 45-60mph front end wiggle that's well documented and was working thru figuring it out. Drove the car Monday and had 2 instances where the frontend started shaking so bad it felt like all my lugs backed off, but then smoothed itself out. Occurred when driving straight, decelerating, accelerating, and braking. When the car is smooth, there is ZERO vibration under braking at any speeds, ruling out a warped rotor.
I found that my passenger front rotor was much warmer than the drivers side, suspecting a sticky caliper. I pulled things apart tonight and the caliper looks like it was replaced fairly recently, and I did the pads & rotors so they have <5k miles on them.
Then found that my wheel bearing has a fair amount of play when shaking the wheel at 12:00 and 6:00. While I suspect my FCAB's are tired, I believe I've found the cause of my issue. I think since the bearing is allowing the rotor to sag into the caliper that's the cause of the heat/dragging.
Will be replacing the bearing soon and follow up with if it fixed the issues
'03 M3. Titanium Silver/Black. Bilstein PSS10, 19" VMR 710, UUC SSK, UUC LWT clutch/flywheel, UUC catback, ///Avin Avant2.
'02 330XI daily
SOLD'95 S50 TI, bad weather beater, tow rig
BUDGET76 is offline   Reply With Quote
Old 05-10-2016, 10:26 PM   #27
Mflara20
My Ride: 04 330i
I replaced the control arm on both sides and that worked a bit but the winner was both front axles. No more vibration, I have both with only 10k if you want to look forward that.
Sent from my SM-G925P using Tapatalk
Mflara20 is offline   Reply With Quote
