Old 07-24-2013, 03:28 PM   #1
JasonSmithed
My Ride: 00 323i
Intake vacuum help
Can't remember where this hose goesClick image for larger version
It's the hose in the center half inch diameter with 90 degree elbow
JasonSmithed is offline   Reply With Quote
Old 07-24-2013, 05:20 PM   #2
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Intake vacuum help
Back of the intake manifold. If its the thing I'm thinking of.
Old 07-24-2013, 08:21 PM   #3
JasonSmithed
My Ride: 00 323i
Intake vacuum help
I couldn't find where though you are right
Old 07-25-2013, 12:41 AM   #4
dreiundzwanzig
My Ride: 2000 323i
There is a small protrusion from on the back of the intake manifold that this connects to. It's right next to the smaller one that has a cap on it. If you don't reattach this hose, you'll get a CEL for an Evap leak.
This picture shows the location pretty well, unfortunately it's not nearly as easy to see when the intake manifold is attached to the engine. If you remove the heat shield around the brake booster, it might make it a little bit easier to find.
dreiundzwanzig is offline   Reply With Quote
Old 07-25-2013, 02:17 AM   #5
JasonSmithed
My Ride: 00 323i
Intake vacuum help
Thanks exactly what I needed
Old 07-25-2013, 03:26 AM   #6
peytonracer4
:D
My Ride: '00 328i
that picture shows it perfectly. mine actually fell off and created a vacuum leak for a while. i recommend putting some silicone on it to hold it on if it's the original rubber piece. it seems to get bigger with time.
