Serpentine belt melting on Tension & Idle Pulley - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-24-2013, 05:51 PM   #1
saturn
My Ride: 525i
Hi Guys, this is yet one of those mysteries where I say experience counts. I am still in learning stages of my E60 and have done few DIYs lately and thanks to all the good people here most of them were successful. But this one has stumbled me and I am hoping it is minor but could leave me stranded in the worst case scenario.
I recently changed my engine tension pulley, Idler pulley, AC Tension pulley, Serpentine belt and AC belt with OEM brands (NAPA, Contitech -main , Optibelt - AC). All was well until my water pump and thermostat gave up last week and was leaking coolant. While I was fixing the water pump and tried to take off the serpentine belt, it was nearly stuck to the tensioner pulley. After removing the belt, what I found was that both the tensioner pulley and the idler pulley had worn off/melted rubber on the outer edge. This is where the belt was sticking on to. I inspected the belt, but it is not showing any major signs of damage. I have attached a picture of the tensioner and idler pulley where you can see the rubber on the edge.
The hot coolant was leaking from thermostat and the water pump and getting sprayed (very fine drops) to the right side of the vehicle at the same level as these pulley, but I doubt that would have caused any rubber to melt. Questions I am wondering to myself;
Is this normal?
Is something going wrong?
Hope I won't loose the belt in the middle of a highway or something....
All suggestions are welcome.
saturn is offline   Reply With Quote
Old 07-24-2013, 06:35 PM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
It looks to me like it has worn grooves into the pulleys from just the pulleys being old. Mine were originally like that as well: fairly obvious grooves in changeable pulleys.
Old 07-24-2013, 07:15 PM   #3
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Check your pulleys and make sure they move freely.
Did you.have the belt on correctly?
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptain
BMWCaptain is offline   Reply With Quote
Old 07-24-2013, 07:48 PM   #4
saturn
My Ride: 525i
Both those pulleys and the belt are new (none of them are old, that is the reason of concern) and changed at the same time. The belt is on correctly and only the flat side of the ribbed belt touches these two pulleys, all other wheels (4 - water pump, alternator, power steering, engine) have the ribbed side of the belt.
Both Tensioner and Idler pulley move freely.
Old 07-24-2013, 07:57 PM   #5
wildirish317
My Ride: 2005 330Ci vert
Heat. You're building up friction somewhere. Take the belt off and make sure all pulleys (alternator, etc.) turn freely. It could be the tensioner. If it's not keeping the belt tight, it could be slipping, which could cause friction. Watch the belt with the engine running. Have someone rev the engine to about 3,000 rpm or more, and see if the belt stays tight. The only other thing I can think of is to use a strobe light and tune it to the belt rpm so you can "freeze" it and see if it's "flopping".
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 07-24-2013, 08:02 PM   #6
lszlszx
My Ride: 1.8T, XC70
Coolant is very slippery, it's possible that it made the belt slip, overheated it a bit and caused it to stick to the plastic. If all the pulleys are spinning fine and the belt is on the right way, I wouldn't worry about it.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 07-24-2013, 08:07 PM   #7
WDE46
My Ride: '13 128i, '04 330Ci
If it's melting, that means heat buildup on a non load pulley. Meaning, that these pulleys would not slip anyway. The only pulleys that would slip are the loaded pulleys. That is the Crank, water pump, alternator, AC compressor, and power steering pump.
OP this is a shot in the dark, but does your belt have the correct number of grooves?
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 07-24-2013, 09:22 PM   #8
BobbyC
My Ride: 2000 328I
It could be related. What exactly gave up on the water pump??? If it was bearing related, the extra head from the bearings could have transferred to the pulley on the water pump and the excess heat caused your belt to degrade and become soft, then it transferred to the plastic pulleys. Clean then, then run it.
BobbyC is offline   Reply With Quote
Old 07-24-2013, 11:17 PM   #9
saturn
My Ride: 525i
Thanks WDE46, the belt was OEM Contitech 8pk 1538. No issue with the grooves.
Not sure what happened with the pump, but it was leaking along with the thermostat. I cannot tell if the bearing was totally gone or not but it seemed to be fine. Pump is replaced, pulley has been cleaned. I guess, I will just wait for a week and pull out the belt again to see what happens in a weeks time.
