Old 07-24-2013, 08:43 PM   #1
austinadrew11
My Ride: 2001 BMW 330Ci
Exclamation Steptronic failure???!!!
Everything was fine earlier. I got home shifted into park and noticed it was much heavier, then that my key wouldn't release from the ignition no matter how much I tried pushing it further into park. I looked under the plate and nothing is unplugged. Is it going out? I wanted a manual conversion, but not so soon...
My Ultimate Driving Machine
austinadrew11 is offline   Reply With Quote
Old 07-24-2013, 08:54 PM   #2
lszlszx
My Ride: 1.8T, XC70
It's most likely just a malfunction of the shift mechanism. Were you able to
shift to park with the shift surround lifted? The shifter sits atop a plastic platform for lack of a better word, that can pop out of place. There is a cable that goes from the ignition switch to the shifter (among other things) and the key won't turn all the way back, unless the shifter is in park.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 07-24-2013, 08:59 PM   #3
austinadrew11
It does the same thing with the surround lifted and in place. My dash says that it is in park. My key still does not come out, and everything looks like it's moving as it should. However, the shifts sound more metallic and forced from both inside and outside of the car than before.
Old 07-24-2013, 09:11 PM   #4
BeMyWhip
My Ride: 01 BMW 330ci
My trans stays locked in gear longer and longer.... thinks my 5 or 6 speed conversion is coming soon as well lol.
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 07-24-2013, 09:14 PM   #5
austinadrew11
I was wanting to do it..just after nav, wheels, bumpers, auto-level bi-xenon, bsw speakers, sat radio
Old 07-24-2013, 09:20 PM   #6
lszlszx
My Ride: 1.8T, XC70
I think it's something with that cable, it's called shift interlock cable.
Remove some of the interior trim pieces and inspect it, maybe it's worn, loose, frayed, or there is a kink in it.
Old 07-24-2013, 09:26 PM   #7
austinadrew11
What about the drastic change in how the shifts sound and feel. It feels normal when going from drive to sport and fine when shifting manually.
Old 07-24-2013, 09:56 PM   #8
BeMyWhip
I think an M3 rear and M3 trans will be a great starting point.
A 3 liter motor with an AA supercharger... very cool!
Always Mod!!!
Old 07-24-2013, 10:06 PM   #9
austinadrew11
The problem with that is that I'm a high school kid making minimum wage
Old 07-24-2013, 10:09 PM   #10
iRide113
My Ride: 2004 M3
Lift the black panel up and look for a caught wire on the right side. Happened to me before, I couldn't pull the key out and I couldn't get out of park.
iRide113 is offline   Reply With Quote
Old 07-24-2013, 10:11 PM   #11
austinadrew11
I've done that already..everything is where is supposed to be. I'm really worried about how much this is gonna cost.
Old 07-24-2013, 10:13 PM   #12
BeMyWhip
One word of advice... as a high school kid... Don't waste your hard earned money on your car; Also, don't waste your time either. Focus on college and a future. Then you can get what you want when you get your life together! Trust me!
Best wishes, best of luck,
The Whip!
Always Mod!!!
Old 07-24-2013, 10:27 PM   #13
lszlszx
My Ride: 1.8T, XC70
Are you talking about how the shifter itself sounds, or how the transmission is shifting?
Old 07-24-2013, 10:36 PM   #14
austinadrew11
It seems to be the mechanism itself
Old 07-24-2013, 10:38 PM   #15
BeMyWhip
ok then...
Always Mod!!!
Old 07-24-2013, 10:57 PM   #16
austinadrew11
I can't even lock it..the only key I have is stuck in it. I'm taking it in tomorrow to get looked at
Old 07-24-2013, 11:17 PM   #17
austinadrew11
Fixed it!!!!! The wire that leads to the position light fell out and got jammed in the way. It's been out for months. Sadly it got torn apart and it doesn't stay into place. Know how I can replace it?
Old 07-24-2013, 11:21 PM   #18
lszlszx
My Ride: 1.8T, XC70
This gives you an idea how it works.
Old 07-24-2013, 11:26 PM   #19
austinadrew11
It wasn't the interlock cable. It was the wire that connects the little orange gear indicator light to the position of the lever. It's plugged into a white box on the underside of the plate
Old 07-24-2013, 11:47 PM   #20
aldeghij
My Ride: 2003 330i
ok then...
I think you got ignored! BMW
aldeghij is offline   Reply With Quote
please help, problem, shifting, steptronic failure, transmisson
