Old 07-25-2013, 01:28 PM   #1
Radium
Past Site Sponsor
My Ride: RadiumAuto.com
Want to save your engine at the track?
RADIUM Engineering recently released a bolt-in Fuel Surge Tank specifically for the BMW E46.
This comprehensive installation kit includes everything needed to install a Radium Engineering Single Walbro, AEM, Aeromotive, or Deatchwerks equipped fuel surge tank (FST) in a 1999-2006 BMW E46 3-series. All Radium FSTs feature anodized aluminum surfaces, Teflon insulated wiring, submersible hose, etc. to make them alcohol (ethanol/methanol/E85) compliant. The BMW install kit locates the FST in a collision-safe area of the trunk behind the rear seat.
The bolt-on powdercoated aluminum mounting bracket features rubber isolating grommets to reduce fuel pump noise. Also included is a fully assembled plug and play wiring harness featuring a weatherproof fuse and relay to drive the FST's fuel pump. A Delphi weatherpak connector is also provided for the fuel pump trigger activation to make the entire system modular.
Included are 8 PTFE (Teflon) hoses which are cut to length and preassembled. The PTFE liner is great for all types of fuel, especially with high alcohol contents, such as ethanol (E85). Unlike standard rubber hose, PTFE is non-permeable and eliminates any possible fuel vapor smell.
These PTFE hoses use anodized aluminum hose ends are cut-to-length specifically for this application. The inner stainless steel braid resists extreme fuel pressures and is covered with black PVC which gives the hose added protection from debris and provides abrasion protection. Supplied in -6AN size only.
The PTFE hoses mate at a junction point in the trunk using 4 bulkheads fittings and a billet aluminum plate for interior aesthetics.
For more information go HERE.
Radium is offline   Reply With Quote
Old 07-25-2013, 03:21 PM   #2
Commanderwiggin
My Ride: 900rwhp Turbo M3
Very nice stuff as always, makes me glad my system is almost all fully Radium now...just the in-tank pump left
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Commanderwiggin is online now   Reply With Quote
Old 07-26-2013, 09:25 AM   #3
InDiGlOM3
My Ride: HPF M3 stg 2.5
Re: Want to save your engine at the track?
Looks like enough line to go all the way upfront getting ride of all factory fuel lines?
Old 07-26-2013, 12:50 PM   #4
Radium
Past Site Sponsor
Originally Posted by InDiGlOM3 View Post
Looks like enough line to go all the way upfront getting rid of all factory fuel lines?
The OEM hose (upfront) is retained unless you use the RADIUM Fuel Rail Kit
The RADIUM fuel rail's PTFE (Teflon) hose replace's the OEM rubber hose that connects to the factory fuel pressure regulator (shown below)
With the RADIUM FST kit the included PTFE hoses attach to the OEM connections at the BMW fuel tank. So you can still replace all of the tube/hose from the BMW tank forward, if need be.
But keep in mind, hose ID size is usually overrated. We know of a certain S54 making over 800rwhp on E85 with -6AN (3/8") feed hose!
Old 07-26-2013, 04:04 PM   #5
Twin_Turbo_S54
My Ride: M3
labor, attention to detail are awesome. Keep up the good work.
I ll buy a set of these for my street S54B35.
La ilahe illallah = God is one and only
Twin_Turbo_S54 is offline   Reply With Quote
Old 07-26-2013, 05:38 PM   #6
BDUB328I
My Ride: bmw 328i S54 sedan (
Awesome explination of the video until now I was confused how it worked....
Have any e46 actually had problems with air getting to the fuel rail though? What happens when air does get to fuel rail? Boom?
BDUB328I is offline   Reply With Quote
Old 07-27-2013, 01:25 PM   #7
Minnoe07
My Ride: 2004 BMW 330Ci
When tanks gets about 1/3 full on the track, you will get stuttering on long sweepers. It gets really annoying and I'm sure it wreaks havoc with your a/f ratios.
Surge tank is definitely a good fix. Until then, I just keep the tank over 1/2 full but if I had the money, I would just buy the kit.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 08-01-2013, 01:29 AM   #8
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
Very Nice.
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 08-04-2013, 01:02 PM   #9
Radium
Past Site Sponsor
Originally Posted by Minnoe07 View Post
When tanks gets about 1/3 full on the track, you will get stuttering on long sweepers. It gets really annoying and I'm sure it wreaks havoc with your a/f ratios. Surge tank is definitely a good fix. Until then, I just keep the tank over 1/2 full but if I had the money, I would just buy the kit.
Think about a 900hp gas guzzler on ethanol! This combination required a full tank every 30min session. JP has datalogs of misfires and dangerous AFRs when he would track this M3.
Old 08-24-2013, 04:56 PM   #10
dan avoN7
My Ride: A car
What do we have here
Radium FST Kit Very impressive to see person, great quality!
Just getting started with the install
Thanks for the great service Lab22! Ordered Wednesday and received Friday
dan avoN7 is offline   Reply With Quote
Old 08-24-2013, 11:31 PM   #11
Moosecakes
My Ride: 02' SMG M3
Jelly!!!! I gotta pickup a kit from the guys over at lab22 when I can swing it!
Moosecakes is offline   Reply With Quote
Old 08-25-2013, 03:12 AM   #12
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Wow, that's a clean looking ride Dan!
Old 08-25-2013, 06:38 AM   #13
Commanderwiggin
Very Nice!!
Old 08-25-2013, 10:24 AM   #14
02black330ci
My Ride: spaceship
Nice interior!! Very clean and so much race going on, why cause "Race Car".
02black330ci is offline   Reply With Quote
Old 08-26-2013, 08:05 AM   #15
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
I absolutely Love this kit....i gotta figure out how to fit this kit in my M3
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline   Reply With Quote
Old 08-28-2013, 05:39 PM   #16
Radium
Past Site Sponsor
Originally Posted by lrinco01 View Post
I gotta figure out how to fit this kit in my M3
FYI: The RADIUM BMW FST Kit is independent of the HPF turbo kit's fuel system.
It also solves the fuel pressure drop (lean condition) found with HPF Stage 2.5 M3s because all of the (selectable) FST pumps outflow the BMW pump.
