Lug nuts - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 07-25-2013, 08:43 PM   #1
akoonjb
My Ride: 330ci 06
Lug nuts
Hey guys I just bought a set of mrt gt7s black and I'm looking some blue lug nuts. Those sexy metalic ones. I'm not trying to spend more than 80 $ on them. Let me knoe ehat you guys recommend. Thanks
Sent from my SPH-L710 using BimmerApp mobile app
akoonjb is offline   Reply With Quote
Old 07-25-2013, 09:22 PM   #2
Mflara20
My Ride: 04 330i
Lug nuts
There you go.
http://www.motorsporthardware.com/
Mflara20 is offline   Reply With Quote
Old 07-25-2013, 09:46 PM   #3
akoonjb
My Ride: 330ci 06
Re: Lug nuts
Thanks. But I'm really looking for that brigh blue. Any other sites ya recommend?
Old 07-29-2013, 12:22 PM   #4
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Fairly certain that a stud conversion + blue lug nuts is going to run more than $80.
http://www.evasivemotorsports.com/mm...tegory_Code=L1
They have lug nut sets that fit within your budget though.
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 07-29-2013, 12:51 PM   #5
akoonjb
My Ride: 330ci 06
Re: Lug nuts
Ya I found a set thanks. I don't see a point in converting to studs. Its a pain to swap wheels
Old 07-29-2013, 01:02 PM   #6
VMRWheels
VMRWheels's Avatar
What? If anything it would make swapping wheels easier! I love having studs.
Old 07-29-2013, 01:17 PM   #7
Llink78
My Ride: 2002 330i
Wheel studs are my next mod. I hate lug bolts.
Llink78 is offline   Reply With Quote
Old 07-29-2013, 10:46 PM   #8
akoonjb
My Ride: 330ci 06
Re: Lug nuts
Maybe I'm wrong nd got the terms mixed up. Lug nuts attach the the hub onto the wheel stud. Lug studs are the screw in deal qhere u take the bolts out nd the wheel drops... that's what I'm thinking...
Old 07-29-2013, 11:13 PM   #9
Astheros
My Ride: BMW
Re: Lug nuts
Awesome. Didn't know they made neo Chrome lug bolts. Picking up a set of those muvius ones. S I ck
BimmerApp on Samsung Galaxy S4
Evil men will triumph so long as good men stand by and do nothing.
Astheros is offline   Reply With Quote
Old 07-30-2013, 11:23 AM   #10
VMRWheels
VMRWheels's Avatar
Your car came with lug bolts, which screw directly into your hub. Lug nuts screw into a stud, which protrudes from a car's hub.
Old 07-30-2013, 12:01 PM   #11
akoonjb
My Ride: 330ci 06
Re: Lug nuts
I really hope not cause I ordered lug nuts sir.... I'm gonna take one off this very moment
Old 07-30-2013, 12:02 PM   #12
akoonjb
My Ride: 330ci 06
Re: Lug nuts
I bought 18x8.5 and went with nankang ns2 225/40/18. My buddy said to grt bigger tires in the rear. Is there a point?
Old 07-30-2013, 12:41 PM   #13
VMRWheels
VMRWheels's Avatar
If you have not done a stud conversion, lug nuts will not work. You will literally have nothing to screw them into.
This is what a hub looks like with studs.
Your car has something like this:
Your car should utilize lug bolts:
Which would screw into the hub without the studs. If you bought lug nuts, there will be no protruding threads to screw them into without a stud conversion.
As far as the tires go, if you are running an 18x8.5 square setup, I would just keep the 225/40/18s all around, so you can rotate your tires.
Old 07-30-2013, 06:45 PM   #14
akoonjb
My Ride: 330ci 06
Re: Lug nuts
Well you were right. Now who manufactures colored lug studs. Almost impossible to find
Old 07-30-2013, 06:53 PM   #15
Llink78
My Ride: 2002 330i
Buy a set and have the heads powder coated if you want.
Old 07-30-2013, 07:00 PM   #16
VMRWheels
VMRWheels's Avatar
The only ones I can think of that are close to what you're looking for are Mevius, however they are more expensive than you are looking to spend.
Old 07-30-2013, 07:03 PM   #17
akoonjb
My Ride: 330ci 06
Re: Lug nuts
I like the merivus ones. Little pricy but the look would be amazing. My cars lugs are 12x1.5 correct? Now getting a 60mm lug would have it stick out slightly? Mrr gt7 wheels...
Old 07-30-2013, 07:12 PM   #18
VMRWheels
VMRWheels's Avatar
Your car has a 12x1.5 thread pitch, but you need a 26-27mm shank length. Also, I'm assuming your wheels use conical bolts, but you may want to verify that just to be sure. Ball-seat bolts will not work properly with conical-seat wheels.
Old 07-30-2013, 07:47 PM   #19
akoonjb
My Ride: 330ci 06
Re: Lug nuts
Thanks I really appreciate all the helpful information. Ill have to look at it again. If I was to get longer extended shank lengths would it affrct my wheels?
Old 07-30-2013, 07:49 PM   #20
VMRWheels
VMRWheels's Avatar
Visually, they will look no different. I would not recommend running longer bolts with your wheel setup (assuming no spacers), as it will damage your car actually.
