The Comprehensive E46 Brake Upgrade Guide - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 06-14-2019, 09:28 PM   #41
swordsman11868
My Ride: 2003 325i
Transmission: Autotragic
So Iím gong to need brakes sometime this year
Iíd like to put on drilled rotors for the look. I donít track or do canyons.
Whatís the consensus on drilled? Did they solve the cracking issues?
If I install Eline (Chinese) from Amazon will they last 50k miles? Or will I have to redo it in 20k?
I put brakes on so seldom I donít even know what the industry standards are.
Thanks.
I'm just here to change the world.
BMW Wiki:
Are you getting hot air no matter where you set your A/C in your E46? Check out this ancient thread! Chime in with your experience:
swordsman11868 is offline   Reply With Quote
Old 06-14-2019, 10:42 PM   #42
YoitsTmac
My Ride: 01 330Ci "Mia"
For these cars, drilled isnít much of an upgrade if at all. Theyíre more expensive, more prone to cracking, and blanks do great. I would just get better blanks.
BMWCCA GGC: 530872
YoitsTmac is offline   Reply With Quote
Old 06-15-2019, 07:37 PM   #43
swordsman11868
My Ride: 2003 325i
While I agree I was just going for looks.
BMW Wiki:
Old 06-15-2019, 09:29 PM   #44
YoitsTmac
Your car, if you want it, go for it! My first brake DIY was drilled rotors, be prepared that because of the holes, thereís a, whatís the word. It was so long ago, but there was an unforeseen noise that came under medium to hard braking. I think it was because of how air is under pressure or vacuum in the holes as the pads clasp the rotor. YMMV of course.
BMWCCA GGC: 530872
Old 06-21-2019, 08:00 PM   #45
swordsman11868
My Ride: 2003 325i
Is the cheap (Eline) ok in your opinion or should I go with the more expensive Brembo/Stoptech/etc rotors?
BMW Wiki:
Old 06-22-2019, 09:59 AM   #46
YoitsTmac
I think eline is what I had. Although there wasnít anything inherently wrong with the product, the way it performed is not something Iíd ever want to do again. The noise, honestly the way the steel looked. It looked like a cheap product, and there something always just. Weird, about the feel of the brakes. Nothing insane just, off.
Itís like when you eat the same fast food at a different location than usual - itís fine to eat, but itís not the same as what youíre used to, but you itís close enough and you accept it as the same. But given the choice between that new location and the old, youíd probably prefer the original choice. Hope that analogy makes sense.
BMWCCA GGC: 530872
Old 06-23-2019, 08:35 PM   #47
swordsman11868
My Ride: 2003 325i
Thanks for the info.
After having done some reading it looks like Zimmerman are made in Germany and FCP has a drilled set for sale.
Now I just need to decide which pad to use. :-/
Thereís a lot of choices!
Suggestions?
BMW Wiki:
Old 06-24-2019, 02:41 PM   #48
YoitsTmac
PFC-Z pads. Great possible modulation when cold, one or two good stops makes it bite right at the top and hard. Lots of brake dust if that's important to you though.
BMWCCA GGC: 530872
Old 07-17-2019, 01:51 AM   #49
Aussigazza
My Ride: E46 330i and M3
Year: 1999
Model: Now 330i
Transmission: 6 Speed M3
I have spare new rear M3 rotors and M3 calipers.
Your write up talks about machining the front carriers to put M3 on 330i.
Already have csl upgrade on front.
What is required to put the rear M3parts on my 330i?
Garry
Aussigazza is offline   Reply With Quote
Old 07-25-2019, 11:59 AM   #50
Zaknin
My Ride: 2002 330xi
Year: 2002
Model: 330xi
Transmission: A5S390R
Anyone noticed that rear calipers are different between 330i and 330xi\xd ? Xi\xd calipers are 34216768423\34216768424 , and RWD calipers are 34216765883\34216765884
https://www.realoem.com/bmw/enUS/par...883&series=E46 RWD 42\22
https://www.realoem.com/bmw/enUS/par...423&series=E46 AWD 40\22
Interesting enough - both 40\22 and 42\22 calipers are listed as proper rear calipers for Euro 325i
So is it any real life difference between 330i and 330xi? I'm planning to rebuild my calipers\buy rebuilt ones, and I'm curious about if installing RWD calipers will get any measurable pros\cons
2002 330xi Klankenberg
Drive 2 profile
Zaknin is offline   Reply With Quote
Old 12-30-2019, 06:30 AM   #51
VpointVick
My Ride: '03 325iT Mysticblau
I picked up a set of xi trailing arms Friday in anticipation of doing this swap and got to wondering if I should bother with the intermediary step of using 330i calipers and rotors or if I should go straight to where I'll ultimately end up, which is the 996 calipers on Rally Road brackets and CSL rotors. In researching that I noticed that Rally Road suggests using E38 750i rear rotors as that gets you the 327x20 rotor size, but retains the 325i's 6-1/2" parking brake drum. Does anybody have any input to further confirm this? I was kind of surprised that I hadn't seen this as an option anywhere else.
I'm still going to use the xi RTAs that I got as it will be much easier to clean them up and have them rebuilt and ready to go when it comes time to do my swap, but I thought that it might deserve mention in this already great thread.
VpointVick is offline   Reply With Quote
Old 12-30-2019, 08:09 AM   #52
Overboost
//Binary is in my DNA
Overboost's Avatar
My Ride: 2002 325i
I think the Xi uses the 185mm parking brake drum, same as the 330. The 325 like mine uses the 160mm parking brake drum and the 750i info is something I have not heard of either. 160mm is so small, I can't imagine the 750i using that size but lets find out!
The parking brake is something I still need to deal with on my BBK. Some have made 12.5mm spacers pressed and pinned into the rotor drums and some have fabricated special shoes with a set of 325 and 330 shoes together.
The 750i rotor sounds interesting for sure. Can you provide a link to the Rally Road 750i rotor suggestion info? I looked on their site and can't find it
  • To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
The older I get... The faster I was...
No Fear
Overboost is online now   Reply With Quote
Old 12-30-2019, 08:59 AM   #53
VpointVick
This is absolutely right, and the reason that I went and got these trailing arms out of the yard.
I cross referenced every which way on RealOEM, and while the E38 750i doesn't appear to use any of the same parking brake hardware as the E46 325i, it does appear to be the same general diameter.
I've seen the suggestions for sleeving the drum section of the rotor, fine until you need to replace rotors, and even custom shoes, fine until you need to replace shoes, and found neither to be ideal and thus opted to do it right and swap the trailing arms, axles, and output shafts.
Rally Road mentions the 750i rotor just in passing on the page for their rear 996 non-M brackets. I should probably reach out to them for clarification, you'd said that you got great customer service from them. I'll do that after the holiday.
Originally Posted by Rally Road
The E38 750i rear rotors are the same 328x20mm size and offset as the E46 M3 rear rotor, but have a smaller parking brake to help retain that function.
Old 12-30-2019, 09:07 AM   #54
Overboost
Overboost's Avatar
My Ride: 2002 325i
From my research, the E38 parking brake drum is 180mm, a little smaller than the 185mm of the 330/xi rear rotors but not small enough for the 325.
I am also avoiding the ring for the exact same reason of the ability to swap rotors without additional machining and as far as the shoes go, the current ones have been on there 18 years and still good so I can't imagine wearing out a custom set in any amount of time.
I would try shooting Eric a message from his website, he called me in less than an hour. He is probably working today.
No Fear
Old 01-02-2020, 01:38 PM   #55
VpointVick
Alright, I've got that sorted. Rally Road was referring to using the 750i rotors when doing the 996 brake upgrade on your E36 M3 as they have a 334x32 dimension with the same 180mm parking brake drum as the E36 M3. Unfortunately this won't work for the E46 325i's 160mm parking brake, so the 330i trailing arm swap is completely necessary unless you want to sleeve your parking brake drum or use custom pads.
Old 02-15-2020, 01:47 PM   #56
4004
Is there any reason rear upgrade kits are not widely available for OEM M135 etc upgrades? The dust shield seems to be a direct replacement from 330 to M3. Is it due to the parking brake/hoses/caliper replacement not being made with a revised bracket?
4004 is offline   Reply With Quote
Old 03-16-2020, 10:58 AM   #57
Notaligned
My Ride: 328Ci
Without knowing anything about brake bias or pedal feel... There were threads with some information before.
- Rear 135i does not fit with 330 disc offset is wrong: https://forum.e46fanatics.com/showpo...2&postcount=33
- Rear 135i fits with e46 m3 disc, 2mm of the disc is not swept: https://forum.e46fanatics.com/showpo...4&postcount=39
I don't know the implications, if any, of a 2mm rust ridge that never wears on the outside edge of the disc.
Notaligned is offline   Reply With Quote
Old 04-06-2020, 02:39 PM   #58
srebrin
How does the car behave in winter? How does the braking system work?
srebrin is offline   Reply With Quote
Old 04-13-2020, 10:39 AM   #59
Archbid
My Ride: 330cic, 325i Touring
Year: 03
Model: 330cic
Transmission: 6-Speed, auto
Originally Posted by matt270avian View Post
(Optional) Speed Bleeders. Not needed, but allows the brakes to be bled quickly and you don't need a second person do do them. Worth every penny -
Anyone know which size speed bleeders for the 330 calipers?
Archbid is offline   Reply With Quote
Old 04-13-2020, 11:07 AM   #60
VpointVick
The thread pitch is 1.25.
