Coding after engine Swap - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-18-2019, 07:53 AM   #1
sdrdavan
My Ride: E30 325, E91 320ED
Hi.
Short story long, i have a friend that bought manual 2000(pre Facelift) 325 with a blown engine in which we have now transplanted the engine from an 02(facelift) Auto 330i.
Before planning the swap i did some research and came to the conclusion that with the DME, EWS and key from the 330i it should be possible to remove the automatic part from the vehicle order and then just use that in the old car.
Engine is now in and starts with the old DME and EWS
However after trying to gain access to change the vehicle order via NCSExpert without luck on the 330 DME, i am no longer sure if that's the way to go. And am all so thinking if it would be easier to just flash the old DME with 330i tune.
What would you guys do? just flash the 3.0 tune or get the the new DME and EWS to work in the old car?
sdrdavan is offline   Reply With Quote
Old 02-18-2019, 11:57 AM   #2
armenh7
My Ride: 2002 325i
You don't use ncs-expert. You use winkfp. See if your winkfp has zusbnumber 7551616 available
armenh7 is offline   Reply With Quote
Old 02-19-2019, 04:40 AM   #3
sdrdavan
Sorry im still quite new at this.
So if i see get this right you recommend flasing the existing DME with the 330 "tune" useing winkfp?
I watched your video guides, and got my SP-Daten updated to V60.1
But if i enter comfort mode - Identify ECU famiily and enter 7551616 i get:
Error 704:
Error on determining the ZB number
Sponsored Links
Advertisement
Old 02-19-2019, 04:12 PM   #4
armenh7
My Ride: 2002 325i
Error 704:
Yes for your first question.
What ecu are you selecting?
Old 02-20-2019, 02:08 AM   #5
sdrdavan
So i had time to tinker with this yesterday evening, and found a matching Zusb via BMWfans where the hw number matched the ecu(MS43)
I was also able to read the current config number from the ecu in WINkfp, bit when trying to program the ecu i get a "ecu does not answer" message.
So at this point i am not sure if the problem is a bad K+DCAN cable(cheap of amazon) of if the ecu actually needs to be in boot mode(none of the guides i have seen suggest that it needs to)
Allso all the guides tell you to enter you VIN in WINkfp but i dont se the option to do so after selecting the Zusb file.
Old 02-20-2019, 10:34 PM   #6
armenh7
My Ride: 2002 325i
Pm me your phone number
Old 02-21-2019, 12:31 AM   #7
E46Newbz
Mind if I send you my number too? In a similar situation. Thanks.
Sent from my Phone using E46Fanatics mobile app
E46Newbz is offline   Reply With Quote
Old 02-21-2019, 12:32 AM   #8
armenh7
My Ride: 2002 325i
I don't mind but tomorrow is my only free day so make sure you guys have some time
Old 02-21-2019, 01:49 AM   #9
sdrdavan
Hi.
Thanks for the offer i will send you a PM, however i am in central Europe and 9 hours ahead of Cali time wise so i guess that needs to be considered, as well as a cost.
Old 02-21-2019, 07:37 AM   #10
Dude8383
My Ride: 91 332iS, 00 323iT/6
Hi.
WhatsApp should be free IIRC. It's a data call...
Dude8383 is offline   Reply With Quote
dme, engine, ews, m54, swap
Similar Threads
Thread Thread Starter Forum Replies Last Post
Check engine light- PO344 joelaporte99 General E46 Forum 1 02-06-2019 03:13 PM
manual swap coding issue Ernie D General E46 Forum 4 01-27-2019 07:58 AM
325-330 Engine Swap -- How Much??? BimmerJustin General E46 Forum 19 04-23-2003 04:22 PM
Possible engine swap. bear328 General E46 Forum 13 04-07-2003 07:41 PM
