Help - 330Ci Oil Service Time - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-16-2015, 06:15 AM   #1
mezzatron
My Ride: 330ci E46 MY04
Hi guys,
I bought a 2003 330ci M-Sport a few months back and the guy had it serviced at 149,500 + kms just before I bought it from him.
During the early periods the car would display oil service for 176,000kms. I was intending to do it at 160,000 anyway. But I've only driven the car for 1,500+ kms and the oil service is already showing 160,000. And seems like it keeps dropping.
Should I;
A) Service at 160,000 kms regardless;
B) Service whenever the kms match?
Is there something wrong here?
By the way I checked my driveway and garage, it's pretty clean. No oil leaks on the floor.
mezzatron is offline   Reply With Quote
Old 11-16-2015, 06:28 AM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
I change my oil by around 7500 miles anyway depending on how I have been driving the car. On my highway warrior, I will change it around 10k miles, but this is also because I have taken 1100 mile straight highway drives.
I have modified the oil change service reminder in my E46 to trigger at 1/2 of the factory setting as well. So it counts down from 7500 mile.
Typically the oil change service reminder is triggered by the amount of fuel used, not the actual mileage driving.
Solve your misfires, lean codes, rough idle -
Fuel pump failures -
Temp Info -
Hidden OBC Menu - Check Voltage, Temp, Fuel Level -
E46/E39 GM5 Door Lock Info -
Old 11-16-2015, 07:28 AM   #3
KendrickC
My Ride: '03 325i
Year: 2003
Model: 325i
Transmission: 6MT
^jfoj is correct. It changes depending on how much fuel is used, and not actual running mileage. I reset my counter when I hit 125,000 kms, and it showed 25,000 kms remaining for a while. As of right now (I'm at roughly 136,000 kms), and have had an oil change at 127,000 kms (when i reset my counter it was not after an oil change - just to have nice even numbers again).
Overall, just do your oil changes every 10,000 kms or so if you are running an LL-01 oil.
'03 325 6MT Estoril Blue
KendrickC is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-16-2015, 07:40 AM   #4
mezzatron
Appreciate that. I thought I was running out of oil too soon.
I am looking at servicing every 10,000kms. Which equals to 6200 miles. Is that safe?
Also would you happen to know what the icon in the green circle is?
It has flashed once while I was at high rev, possibly 2nd gear before shifting into 3rd. (Automatic Transmission)
And once while I was driving over a bumpy road. Wasn't too bumpy either.
Old 11-16-2015, 08:50 AM   #5
fn42
My Ride: 2001 330 xi
DSC light. indication that one or more of the wheels slipped
2001 330xi 5mt, 220k
2008 335xi 6mt, 140k
2001 Audi S8 6speed swap, 170k
fn42 is offline   Reply With Quote
Old 11-16-2015, 09:29 AM   #6
mezzatron
Thank you
Thought something may have been wrong
330ci, oil, service
