tyre pressures - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-15-2015, 07:15 AM   #1
smhinto
My Ride: bmw e46 se 318i
tyre pressures
Dear All
I have BMW E46 318i SE Year 2000. After a recent service the guy stated that my tyres (Goodyear 225/40R 18 92W) were all under inflated. On checking the tyre pressures they were all set at 3.0 (bars) after the service.
According the the handbook for everyday use with just the driver in the car the pressures should be 2.0 (bars) all round.
Is this the case?? or is the service guy correct????
Secondly, all of my tyres are due replacement as they are all down to the minimum legal level of tread, but I have noticed that both rear tyres are worn more on the inside edge. Does this mean that the rear wheel need
re-tracking or is this normal ??
Kindest regards
smhinto is offline   Reply With Quote
Old 11-15-2015, 11:04 AM   #2
Dave1027
My Ride: '06 IR zhp coupe
2.2 bar. You may have an alignment issue causing uneven tread wear. I guess you phrase that as re-tracking. I'mm thinking too much negative camber which is common on these cars.
Old 11-15-2015, 02:32 PM   #3
Koninkaulus
My Ride: E46 323 Ci
With that tire profile you should have around 2.4-3.0 bars. One should always check for tire wear and adjust the pressure accordingly. 3 bars is more hard on bumbs and 2.4 is more comfortable, its your decision. Also check the pressure with 2 or 3 different gauges, they very well may show totally different numbers. 2.0-2.2 is just too low in my opinion.
edit: And yeah, get the rear looked at.
E46 323Ci Coupe
E36 318is Coupe
E36 325 Sedan
E36 318is Coupe
Koninkaulus is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-16-2015, 07:03 AM   #4
markusmarkus
My Ride: 2018 M240i
The correct tyre pressures should be on a label on the drivers door jam.
