Xi Lowering / Have Your Cake & Eat It Too - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 4.73 average. Display Modes
Old 11-24-2015, 03:05 PM   #41
Rob43
My Ride: 03 331Ci 5spd R1200R
Originally Posted by groundshock View Post
I'm at work right now, car is in the shop. This was a week after I installed the springs. It's settled a bit lower since then.
Admittedly, if I could find a solution to the boots cracking, I'd be pretty happy after a set of camber plates and a proper alignment. I know -1.7 isn't the end of the world, but new tires are new tires.
In a day or two try to post up a pic like the ones in post #35, then we'll really see what things look like. Inexpensive Camber or Camber/Caster plates will easily solve your camber issue, figure ~$139 for a set. And like I said, they're creative ways to slightly raise it up a little, if you install camber plates, that will be the time to do it.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
(DynoDynamics
Dyno Video)
Old 11-24-2015, 03:25 PM   #42
boblaz
My Ride: 03 BMW 325XiT
Won't the camber plates themselves raise the front?
boblaz is offline   Reply With Quote
Old 11-24-2015, 03:27 PM   #43
groundshock
My Ride: 04 330Xi
I'll already be in it to replace the damned axles or boots, so we'll see what happens at that point. I'll post up a decent side pic as soon as I can.
Side note: As far as the front outer CV boot thing, I honestly don't think that the lowering has anything to do with it. I checked the axle angles with the front suspension loaded when I was under it for an oil change a couple weeks back, and they're barely off-center. I really think that the issue with these CV boots tearing is the extreme steering angles that this car is capable of. We have to make a hard, hard turn into our driveway due to confined space in our alleyway, and I think that's what killing the boots. I wonder if there isn't a 'size bigger' or other solution to the boots that could be used in lieu of the OEM size to mitigate the constant tearing.
2004 TiAg 330xi Sedan
2008 GTI DSG 5Dr
groundshock is offline   Reply With Quote
Old 11-24-2015, 03:38 PM   #44
Rob43
This type of Camber Plate is designed to be the same height as the OE strut bearing, so it shouldn't add any height to the chassis.
Rob43
(DynoDynamics
Dyno Video)
Old 11-24-2015, 03:48 PM   #45
Rob43
This could be your opportunity to figure this out for the E46F forum members, maybe take a new boot to the parts store or the dealer & start to compare it to different boot designs from different BMW's & different cars entirely. You might get lucky and find something that's 10% to 15% bigger that fits perfectly, this is some of my methods that I used on how I figured out this lowering thread.
Rob43
(DynoDynamics
Dyno Video)
Old 11-24-2015, 04:55 PM   #46
groundshock
My Ride: 04 330Xi
I have a few contacts at a couple local parts shacks that I can ask. Let me do some digging. I'll report back.
I don't know why I don't just give up on this damned thing already with all the other headaches it's given me, but there's just something about it I can't let go of.
2008 GTI DSG 5Dr
Old 11-24-2015, 05:52 PM   #47
Rob43
I know what you mean & I feel the same way....
Rob43
(DynoDynamics
Dyno Video)
Old 11-24-2015, 08:38 PM   #48
zander271
My Ride: 6spd ZHP/5sp XI
Rob43
I've already been secretly researching this. Don't blow my cover Rob!
I am the CV boot whisperer.
Old 11-24-2015, 08:46 PM   #49
Rob43
OMG, everyone stand back, The CV Boot Whisperer Is At Work !
In all seriousness, get this solved & you'll be a God amongst the regular Xi owner.
Rob43
(DynoDynamics
Dyno Video)
Old 11-30-2015, 02:56 PM   #50
groundshock
My Ride: 04 330Xi
Update: The parts guys that I had look into this weren't helpful. Apparently they don't have access to a lot of info on boots, or availability on boots at all. I'm at a standstill.
2008 GTI DSG 5Dr
Old 11-30-2015, 03:16 PM   #51
Rob43
How much of a rush are you in ? It's possible you could have some product in your hand within 30 days, but you'd be an early "tester" at this point. Price should be reasonable.
Rob43
(DynoDynamics
Dyno Video)
Old 11-30-2015, 03:33 PM   #52
groundshock
My Ride: 04 330Xi
Sooner than later for me. Car is daily driven, but it's less than 15 miles a day. I'd be open to be a guinea pig.
2008 GTI DSG 5Dr
Old 11-30-2015, 03:36 PM   #53
Rob43
One way or another, you'll have some info within 48 hours.
Rob43
(DynoDynamics
Dyno Video)
Old 11-30-2015, 03:36 PM   #54
groundshock
My Ride: 04 330Xi
Excellent.
2008 GTI DSG 5Dr
Old 11-30-2015, 06:01 PM   #55
Rob43
Excellent.
Do you need 2 boots or 4 boots ?
Rob43
(DynoDynamics
Dyno Video)
Old 11-30-2015, 06:25 PM   #56
Dreamliner330
My Ride: 330xi
Nothing...nothing, other than stock will provide a stock quality ride. I made the mistake of switching to H&R springs and selling my originals. I switched to Koni shocks and Eibach springs and I still wish I never touched my suspension.
Also, this thread completely ignores the angle the drop puts the CV joints at.
Dreamliner330 is offline   Reply With Quote
Old 11-30-2015, 07:38 PM   #57
griffine46
My Ride: 2005 325xi
Xi Lowering / Have Your Cake & Eat it Too
I've been going strong lowered about 3.25 inches and no ripped cv boots yet after 3 months. One of mine was ripped from stock height and it's just held together with rubber cement and it's fine as well
griffine46 is offline   Reply With Quote
Old 11-30-2015, 08:16 PM   #58
Rob43
That's fine & I completely understand your concerns.
But if everyone used this logic, no Xi owner would ever try to lower their BMW or change out to non OE components. So it's not realistic for everyone to use this thinking, some guys want it low at any cost, while others want less of a drop (or no drop at all) & a smother ride.
Everyone has different expectations.
Rob43
(DynoDynamics
Dyno Video)
Old 11-30-2015, 08:47 PM   #59
76m2002
My Ride: 2002 325iT
Year: 2002
Model: 325iT
Transmission: 5-speed
I've also been talking with an aftermarket cv boot manufacturer that has product that might fit, and wants some angle measurements and to know where the rips are occurring. Years ago when I put the H&R springs on my car it dropped significantly, and the cv joint angle was quite steep, but now I can't find the measurement. I just put Eibach springs and the drophats on my car, and am going to take some measurements.
For comparison, can someone give me some measurements from the ground to the apex of the front and rear wheel well with stock springs and with H&R springs? That way I can jack my car to those heights and measure the cv joint angles and compare them all.
Also, if your boots have ripped, where did they rip? In the valley of the pleat, or at the ridge?
76m2002 is offline   Reply With Quote
Old 11-30-2015, 10:03 PM   #60
griffine46
My Ride: 2005 325xi
I will send you a pm with the location where mine is ripped! I am very interested, I still need to replace mine that's being held together with rubber cement
