Took a look and passed- E46 Touring w/M56 engine - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > E46 BMW > E46 Touring
E46 Touring
The E46 touring forum. Talk about your sport wagon E46 here.
Old 07-22-2019, 06:18 PM   #1
Effduration
My Ride: '05 330CiC
Just sharing here...
I have been looking for the next engine swap project. Seller in my area posted an '03 325i (rwd) touring with 145k. Auto trans
Dark green on tan interior. Hood and tailgate have dents large enough to replace each. Interior was good for its age. No rust, and the rest of the car looked pretty good. I was pretty interested until I lifted the hood and saw the M56
Seller said it overheated and needed an engine swap. I have an M54B30 ready to go. I was thinking engine swap and then a manual swap down the road.
Seller was asking $1,000.
I thought about it. Looked into what it would take to swap it into a 330i rwd manual wagon ( fuel tank, etc) and passed. There is some value to some m56 parts (valve cover, fuel tank) but it all added up to a lot of effort.
Did I make a mistake on passing ?
Effduration is offline   Reply With Quote
Old 07-23-2019, 08:38 AM   #2
Dave
Moderator
Dave's Avatar
My Ride: 323,330,M3,M3,M3
I'd have to see it, but $1k as the starting point on a rust free car is tough to beat if you're OK with the color combo. You can always get a new hood... the tailgate would be a bit tougher. Hard to say without pics.... but it sounds like a deal you're not likely to beat.
Perhaps you think multi-million dollar ad campaigns make a beer taste better. Perhaps you're mouthing your words as you read this.
Dave is offline   Reply With Quote
Old 07-23-2019, 10:26 AM   #3
Effduration
My Ride: '05 330CiC
Okay thanks for input, so maybe it isn't too bad...I just agreed to buy it for $800. I have a "freshened" M54B30 with new piston rings and con-rod bearings ready to go in.
I will swap engine, fuel tank & lines, maybe a harness or two and a valve cover, a little coding, maybe a little wiring and hope for the best.
If that works, I'll consider a manual swap. An interior swap to black would be nice too.
I have previously replaced M54's, done engine rebuilds & head gaskets, & did a manual swap on a E39 530i which is now my DD.
Maybe I'll sell the M56 fuel tank and valve cover to help defray costs..
Sponsored Links
Advertisement
Old 07-25-2019, 02:37 AM   #4
blarf
My Ride: 325iT, 540iT
If you want to keep it as a 2.5L, I'd buy it. If not, I'd pass. Converting it to a non-SULEV configuration is almost certainly illegal (and will be pretty obvious if you have to get it smogged), and none of the 3 liter (or normal 2.5) stuff will bolt up to the SULEV stuff.
If you have a non-SULEV donor car to go along with the motor, the patience to go through the wiring and parts diagrams go for it. If not...
Tooooools for rent
blarf is offline   Reply With Quote
Old 07-27-2019, 04:35 PM   #5
ewcmr2
My Ride: Many
M56 tank is worth $4-500.
Hardest part of tank/evap swap is the need to drop rear subframe to replace hard lines.
ewcmr2 is offline   Reply With Quote
Old 07-28-2019, 09:42 AM   #6
George Hill
My Ride: BMWs
I have not done a SULEV to ULEV conversion. Sounds like you have experience with this, can you list the wiring differences involved? What parts are SULEV specific that will not bolt up to a ULEV (that would be kept) ?
Why not cut the hard lines out? I would think worst case you would have to only slightly lower the subframe t get the new line in.
Current Garage... '00 R11S, '09 HP2S, '12 R12GSA,
, '04 Gray 325iT,
Instagram @ HillPerformanceBimmers
Email to
George Hill is offline   Reply With Quote
Old 07-28-2019, 10:27 AM   #7
Effduration
My Ride: '05 330CiC
UPDATE:
After careful consideration, I ended up NOT buying the E46 touring with the M56 engine. It is still avail in Lawrence, MA and f anyone is interested, PM me and I will connect you with seller.
Primary reason: A local '05 X5 in need of head gasket but in otherwise good to very good condition popped up for $1500. Seemed like better opportunity for me.
In thinking about the E46 (which also needed a head gasket) prior to walking away, I had settled on replacing the head gasket with engine in car (done before) and seeing how it ran as a stock M56.. A swap to M54, and manual swap would have been something to think about doing after that. I was aware of what the fuel tank and valve cover were worth, but stripping and selling the M56 parts was too much of a time suck for me. Went as far as speaking with current ebay sellers of M56 fuel tanks and was told the trick to removing the tank in one piece is to remove the right rear suspension.
Oh, in MA where I live they don't test emissions on pre-'04 model year cars. I believe the E46 wagon would have passed inspection regardless what engine I had in it.
Old 08-30-2019, 12:30 AM   #8
Onizukachan
My Ride: F31d Msport
Year: 15
Model: F31
The nice thing about the SULEVs, besides the MPG they get, is that you can swap the tank if you are willing to cut the hard filler tube. And they are closer fuel wise to the m3 I understand with the PWM non return fuel system. When this one goes in another 50-70k I'll swap the tank to m3. or Crush it. Lol.
If I were to give my
a first name, I'd probably name it "Alan".
Mostly because I like puns.
Onizukachan is offline   Reply With Quote
Old 08-30-2019, 10:14 AM   #9
ewcmr2
My Ride: Many
No need to cut anything to remove M56 tank, everything unbolts and slips out of chassis.
Old 09-02-2019, 01:32 AM   #10
Glenn16
Agreed..Nothing is to be removed anything in order to clip. Just wait few days, everything would be slipping out so just be patient untill then dqfansurvey _sl_
Glenn16 is offline   Reply With Quote
