e46 wagon crank no start - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > E46 BMW > E46 Touring
E46 Touring
The E46 touring forum. Talk about your sport wagon E46 here.
Old 08-13-2019, 08:35 PM   #1
jaydrift
Hey everyone on here. I'm new to the bow world. i always loved e46 and i finally got a 2000 e46 325i wagon with an automatic transmission. I'm here to really need. i got a running donor 2002 e46 330i sedan with a 5 speed manual. i wanted to swap everything over to the wagon which i did. so far i swap 330i motor, manual transmission, rear diff, driveshaft, engine harness, 330i news, ket tumble and body eco. but I'm having a problem crank no start issue. it sounds like its not communicate with the ecu and can't hear the fuel pump prime. I'm lost at this point i try calling shops to help but they would not be able to cause this is a big project. so if anyone did what i did and had the same issue please help thanks
jaydrift is offline   Reply With Quote
Old 08-14-2019, 09:28 AM   #2
George Hill
My Ride: BMWs
If I understand your post correctly you took a 325 automatic car and swapped in a 3L/5MT? You used the DME, EWS and Key from the 3L car, also correct? The condition you have now is it cranks but does not start? You saw the 330 run and drive, correct?
Do you have any faults?
Do you have fuel pressure?
Do you have spark?
Those should be your (3) main causes for what you are seeing. Start there and report back.
Lastly, you may think about putting the automatic final drive back in the car. The gear ratio is a bit shorter and will give you a sportier driving experience with the sacrifice of a little fuel economy on the highway.
Current Garage... '00 R11S, '09 HP2S, '12 R12GSA,
, '04 Gray 325iT,
Instagram @ HillPerformanceBimmers
Email to
George Hill is offline   Reply With Quote
Old 08-14-2019, 11:28 AM   #3
armenh7
My Ride: 2002 325i
Doesn't seem like you swapped over the EWS. You can't just swap ECU's.
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
