M54 severe power loss - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 05-02-2018, 10:55 AM   #1
aspex
Hi everyone,
I know this is an E46 forum but the issues with my M54 engined X3 could be resolved by your experiences with the same engine in an E46 I'm sure.
I really need some help before I go ahead and purchase a new Vanos or pull all my hair out with frustration. I've got a severe power loss in my 2005 E83 2.5 petrol. The engine cuts out and goes into limp mode every time I drive it. If I turn the engine back on immediately some power is restored. My generic OBDII scanner only shows the 2A82 code for the intake. No other codes. I've swapped the intake solenoid out for an alternative one although not a new one and the symptoms are the same.
In the last year, the car has had new cats, new CCV, new knock sensors, new fuel pump and filter, new Idle Control Valve, new DISA valve as well as new Vanos seals.
I've rechecked the CCV and pipes, and the DISA for faults and all's good.
The car sounds really throaty as if it's trying to take in too much air, a bit like it's got no airbox attached. If I disconnect the VANOS intake solenoid the engine runs better, sounds closer to normal but is still lacking power.
There is an oil leak from the oil filter housing and I'm wondering if this is allowing air to leak into the oil filter housing and therefore the oil system and reducing the pressure or supply of air-free oil to the intake solenoid?
Any other suggestions?
Many thanks for your help.
Regards,
Mark
aspex is offline   Reply With Quote
Old 06-20-2018, 09:40 PM   #2
hgriffin1
My Ride: 1999 E46
Have you changed the Cam sensors? Both Exhaust and intake...
Sent from my Pixel 2 XL using Tapatalk
hgriffin1 is offline   Reply With Quote
2a82 code, m54 power loss, vanos, x3
