My new 2002 M3 6 Speed. My Build. - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
Old 10-09-2018, 03:09 PM   #41
wolfalp
My Ride: M3 vert
Garry, congrats on the M3, I smile every time I drive or even walk by mine. They are fun cars. Best of luck with the repairs.
BTW your pictures are not showing for me.
wolfalp is offline   Reply With Quote
Old 10-10-2018, 04:52 AM   #42
Aussigazza
My Ride: E46 330i and M3
Year: 1999
Model: Now 330i
Transmission: 6 Speed M3
THey are thumbnails to pics in imgbox.
What are you using to read the thread. Are you having problems with anyone elseís pics?
Garry
Aussigazza is offline   Reply With Quote
Old 10-10-2018, 07:12 PM   #43
armenh7
My Ride: 2002 325i
Pics work fine for me
armenh7 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-11-2018, 03:22 AM   #44
Aussigazza
Year: 1999
Model: Now 330i
Exhaust and Fender Linings
Got Beluga Racing muffler modified to fit my car. Borderline liveable...
Also Pu lhs bottom/front fender liner in. Need to get a new brake cooling pipe mount. Too bent to mount liner to.
Garry
Old 10-12-2018, 02:17 PM   #45
wolfalp
My Ride: M3 vert
I use IE and no problems with others pics
Old 10-13-2018, 01:40 AM   #46
Aussigazza
Year: 1999
Model: Now 330i
RHS Mudguard Lining.
Put in rhs front lining. Rear part also needs replacing.
Garry
Old 10-14-2018, 04:18 AM   #47
Aussigazza
Year: 1999
Model: Now 330i
Replaced wiper blades. Both Bosch type wiper blade adaptor clamps that join the blade wing to the end of the arm broke. Brittle.
Ordered 2 new ones. Pn 61618233577.
Garry
Old 10-15-2018, 03:27 AM   #48
Aussigazza
Year: 1999
Model: Now 330i
Front RHS Door Speaker Dead
While replacing the speaker cover that had a hole in it, found that one of the wires to the cone had broken off.
Tried soldering back together but made the wire too tight.
Bugger.
Update
Lengthened the wire and still no noise.
Found that pushing the diaphragm down a bit made it work.
Made a cardboard ring that I placed between the speaker an its mount.
Ring went across the diaphragm half way. This lowered it and it works.
Looks like magnet and electromagnets are not aligning.
Probably lowers the response of the speaker, but it now is off my urgent list.
Garry
Old 10-17-2018, 05:58 AM   #49
Aussigazza
Year: 1999
Model: Now 330i
Planning to Adjust Front Clip
Found a pic of how the front clip on attaches to the carbon fibre bumper. Few clips and screws under guards and 4 clips on the bumper. The bumper clips look adjustable so I may be able to get everything aligned. I appear to be missing the pads on top of the bumper that gives the nice even gap instead of a wavy top edge. Will come up with something.
Garry
Old 10-17-2018, 06:44 AM   #50
cwaltz666
My Ride: 02 M3 Vert, 04 ZHP
Step 1 with owning an e46 of any model: Get used to dash lights, they will never go away
Chris Walter
2002 E46 M3 Vert 6spd
2004 ZHP sedan
@spicy_tunah <-- Instagram
cwaltz666 is offline   Reply With Quote
Old 10-17-2018, 07:59 AM   #51
Aussigazza
Year: 1999
Model: Now 330i
I have fixed my 330 for dash warning lights and minor fixes for blown lights on the M3 and no lights for quite a while. Service and replace parts as required. E46s are getting old and electrical and plastic parts are failing. At least you can still get them.
Major gripe is previous owners who broke bits and did not replace them, or did not replace fasteners etc.
Garry
Old 10-17-2018, 11:40 PM   #52
Aussigazza
Year: 1999
Model: Now 330i
More Missing Bits
2 of the front clip mounts missing...
Also the packing on top of the bumper.
Garry
Old 10-18-2018, 11:45 PM   #53
Aussigazza
Year: 1999
Model: Now 330i
Foam on Top of Bumper
Found some foam to replace the missing pieces on top of the carbon fibre bumper. A kids swimming board!
Cuts beautifully in a band saw.
Widest is 20mm and angle was 11.5 degrees.
Only did middle until I replace ball clips that are missing.
Garry
Old 10-19-2018, 04:58 AM   #54
Aussigazza
Year: 1999
Model: Now 330i
Love the Beluga Racing Exhaust
Definitely love the sound. Std exhaust to the muffler. Thought they were cheap as their website shows $1k US less than their EBay site...
If it did not come with the car, no way I would have paid that much.
Oz $ plus shipping would make this very expensive option.
Garry
Old 10-21-2018, 03:17 AM   #55
Aussigazza
Year: 1999
Model: Now 330i
Camber Calcs
Want to work out the priority for putting in camber adjustment.
Put a 610mm straight edge on front wheels and a level. At top of straight edge there was a 6mm gap. This has std height. Also has pin in the top plate.
On back there was 25mm. This is lowered about 50mm.
Correct my maths memory, but the angle is:
Tan^-1(6/610) or about 0.6 degrees neg camber on front.
2.6 degrees on back.
Front std is meant to be 1 degree on front and 2 degrees on back.
Looks like I can put the 50mm lowered front back on and get camber in spec as the pin is removed on the lowered struts' top plates.
Need to replace the lower control arms to get rear in spec.
Rear toe out still need some to be addressed somehow.
Update on thinking:
Rear is over the required neg camber std.
It is at max extension on the length of the control arm.
Should be able to bring it back to std by shortening lower arm?
Garry
Old 10-23-2018, 04:45 AM   #56
Aussigazza
Year: 1999
Model: Now 330i
Checking Front Camber
Never got the start and finish camber values after getting a full alignment done. Was told everything was at max and all over the place.
Did some calculations and wondered why one side was twice the other. Ie 0.6 and 1.2 degrees. 1 degree is meant to be the std.
Took the caps off and the 0.6 degree side still had the pin in it! They screw off with an Allen driver. Better than hitting them with a hammer.
Put it at max and it came to 1.2 degrees.
Left them there.
I want to lower front end, but do not think I will get it into spec.
Will put on a K-Mac camber top plate before swapping new struts in.
Will check and adjust rear next as I think they need to have the lower control shortened to reduce high negative camber.
Will get it all checked again (elsewhere) after front done
Garry
Old 10-24-2018, 12:36 AM   #57
Aussigazza
Year: 1999
Model: Now 330i
Itís the Small Things Sometimes
After getting rego and new plates, the rear right screw hole mount was broken and rotated. Could not get the screw in. Left side was cracked.
Bought new ones from EBay Lithuania (weird the number of BMW parts for sale from Lithuania).
They go into a hex sided hole that is blind. Ie no access on the other side.
Used long nosed pliers and broke them up.
The screws were too long and would have broken the ends of the new mounts.
Cut them shorter and all good.
Garry
Old 10-28-2018, 11:54 PM   #58
Aussigazza
Year: 1999
Model: Now 330i
FRont Bumper Properly Mounted.
2 clips, spacers and ball mounts at over $100Aus and got the bumper properly mounted.
Having the 2 inner ball mounts lifts and pulls back the bumper.
Inserted my foam spacers in the middle and got a nice even gap.
The rhs is nice already, the lhs needs a bit more work.
Will get to it when I do the lower headlight eyebrow.
Garry
Old 11-06-2018, 01:44 AM   #59
Aussigazza
Year: 1999
Model: Now 330i
Bit More Progress
Put foam in the front bumper under each headlight and now have a nice even gap. Due to fender bender on rhs, it is close but not perfect. Will leave alone unless it pisses me off.
Ordered a new lcd for the oem head unit and a rebuild kit, including pistons, for the front brake calipers. Will post on lcd installation.
Looking for a hk door or deck speaker at good price as shipping kills me, and a motor or complete rotating lh door mirror.
Need a rhs brake duct metal mount so I an eventually fit the central plastic engine guard.
Also a bit of painting needed. May get a can and do small stuff myself.
Garry
Old 11-07-2018, 11:17 PM   #60
Aussigazza
Year: 1999
Model: Now 330i
Power Steering Dead
My new aftermarket hose (brand name from ecs) that goes between the reservoir and oil cooler blew off the oil cooler. Genuine part ordered. Been ok for a few weeks.
Garry
