Replaced my fuel pump. Fires, won't run. Pumping fine. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 05-17-2019, 03:01 PM   #1
DrunkUncas
FU to https://forum.e46fanatics.com/showth...1#post18544469
Pump primes, then squirts when cranking into a bucket.
Car fires once, then dies- exactly like it did before pump replacement.
Relay bench tested. No current codes, but my TPS has occasionally been giving me an EML when I punch it in a higher gear.
Ground on passenger side engine good.
Ideas?
Solved: Check your MAP
DrunkUncas is offline   Reply With Quote
Old 05-17-2019, 03:09 PM   #2
Luke_palma
My Ride: 2001 BMW M3
Run live data of when car dies. What happens. Fuel trims short and long term. Any misfire knocking data.
Sent from my SM-G955U1 using Tapatalk
Luke_palma is offline   Reply With Quote
Old 05-17-2019, 03:10 PM   #3
Luke_palma
Will car run if u give it gas after startup
Sponsored Links
Advertisement
Old 05-17-2019, 03:25 PM   #4
DrunkUncas
Won't run. Gives it a kick to a little over a grand and dies immediately.
Can I run live data on Torque Pro?
Old 05-17-2019, 03:44 PM   #5
Luke_palma
Not sure. Most scantools and software should let you. Biggest thing is to record what happens when you start up and what happens when it dies. That will make sure you're chasing the right problem (fuel) and its not something else.
Old 05-17-2019, 03:49 PM   #6
Luke_palma
Also try starting car with maf unplugged. Buddy had the issue where maf was so screwed the afr was completely off and car wouldn't run. Unplugging it makes it run off default values. Remember car needs air fuel and spark. One of these missing or wrong will cause a car to die
Old 05-17-2019, 07:13 PM   #7
DrunkUncas
DING DING DING!!!!!
Thanks again, buddy.
Old 05-17-2019, 08:14 PM   #8
Luke_palma
Glad you got it figured out!! Sorry a pump was wasted but good pm nevertheless.
Old 05-17-2019, 08:43 PM   #9
DrunkUncas
119k miles. Preventative maintenance, and an upgrade should I decide to blow it.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Cobalt ss for auto-x car beanfree New England 74 02-20-2009 01:00 AM
URGENT : Need experienced Fanatics help for Fuel Pump/Fuel Sender/Sucking Jet Pump e46addicted DIY: Do It Yourself 6 05-30-2008 04:58 AM
My car died after ignition today! exmike General E46 Forum 4 05-14-2008 01:35 PM
SMG Pump Longevity or when was yours replaced? Montescew ///M3 Forum 4 04-25-2008 04:42 AM
Fuel Pump Relay and MAP Cooling Thermostat tgodel General E46 Forum 1 04-17-2008 09:03 AM
