10w60 Rating? - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 05-04-2010, 12:01 AM   #41
Lude2S
My Ride: '05 M3,'99 Esprit TT
I run Redline oils in both engine of value I own. 10w60 in my M3 and 20w50 in my Lotus Esprit V8. The Esprit V8's recommend Mobil 1 15w50, but it is virtually impossible to find. Probably just me, but I swear both engines run smoother with Redline oil. I know my Esprit shifts alot smoother when I changed the trans oil to Redline. Oh, and I'm not doing it for the price. Redline costs more than Castrol, hands down!
Lude2S is offline   Reply With Quote
Old 05-04-2010, 03:02 AM   #42
Kringkily
My Ride: e46 m3 convertible
i just recently switched back to castrol tws and it seems to run the same as before. only stupid part is that bmw has the market on oil "specifically" for the M series. the freakin oil is way overpriced
Kringkily is offline   Reply With Quote
Old 05-04-2010, 06:38 AM   #43
Ivan01
My Ride: 2007 tsx 2005 M3
how much does bmw charge for an oil change?
Ivan01 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-18-2010, 11:43 PM   #44
I M Legend
My Ride: M3
M1 15-50 is available at Walmart in the 5 quart jug
I M Legend is offline   Reply With Quote
Old 05-18-2010, 11:53 PM   #45
braymond141
My Ride: 96 M3, 02 M3, 01 M5
Originally Posted by m3bergen View Post
Here's an interesting thread on TWS 10w-60 on the BITOG (Bob Is The Oil Guy) forum: http://www.bobistheoilguy.com/forums...56#Post1353856. All of the comments support the idea that TWS is a very, very good oil, particularly in its application in the m3 (more or less tailor-made by BMW/Castrol for the S54), and has a very advanced anti-wear package. Some of the posts from an Aussie who works in the lubrication industry (Exxon/Mobil, I think ) seemed to imply that TWS is a descendant of Castrol R and may contain some castor oil in its formulation. A separate post, also on BITOG, showed data from a German BMW forum comparing film strength of various oils. The TWS film strength, measured in kg/cm (whatever that is), was three to four times that of similar 15w-50 and 10w-60 oils, and almost as good as Motul 300V 15w-60, an ester-based racing oil.
Exactly what I was trying to say, just without the data to back it up. TWS is GOOD stuff.
Originally Posted by 330indy View Post
I had correspondence with Doug. He is truly an expert. Check out what he sent to me, in excerpts. ( by the way I posted on that forum a while back, having seen the light on TWS. ... by the way I was a hardcore M1 fan prior! )
START
Hi,
I first used Castrol's R 15w-50 (castor based) great smell - in 1978
In 1980 I commenced a Senior Technical position with a major International Company whereby I could try new technologies and the like
We (Castrol & I), first decided to test the product in late 1980 a wide range of engines;
Diesel
4cyl IL Isuzu, Kubota, Benz
3cyl IL Kubota
Petrol
6cyl IL Nissan
4cyl IL Mitsubishi
2cyl Horizontal (air coooled)
Castrol reformulated the "R" to a non castor lubricant early in the test programme
The tests involved stationary and mobile engines in ambient temps ranging from -6C to 50C
Regular UOAs were done to monitor the lubricant's condition and some engine tear downs were undetaken. The tests lasted until 1985 and covered hundres of thousand of hours of use
A number of minor formulation tweaks took place which I was a part of of course
Later (in 1986) an employee of mine (an Automotive Engineer) from IH - Mercedes Benz was employed with my help by Castrol as a Lubricant Engineer. This rekindled the testing regime again in 1989 but this time it was with HDEOs. He remains with Castrol today as a Senior Lubricant Engineer and we are still excellent friends of course
I continued to use Castrol R 10w-60 (from 1980) until 1999 in a variety of engine families and random UOAs were carried out
The lubricant 10w-60 is very durable and during the tests in the early 1980s were were able to get up to 4000hrs service before OC. We averaged about 2500hrs. We averaged 80km/h (50 mph) here in this test regime
Regards
Doug Hillary
PART 2
I cannot provide more data than you probably already have
But this might help you
1 - ALPINA worked on its formulation with Castrol/BMW
2 - It suits DI engines due to its viscosity namely HTHS @ 5.4cP
3 - It has an excellent Pour Point (-42C) which is much better than some lighter viscosity lubricants
4 - It was progressively developed from 1997 as a low chlorine/minimised phosphorous lubricant
Its part ester/part PAO base has been constructed over a period of 30 years on an excellent development path
In its early life is was used by Sauber-Mercedes winning at LeMans and in Formula 1 engines (Ford-Cosworth). It was used at one point by Porsche in some race engines. It was also used here in the V8Supercars ZF six speed gearboxes with great success
It is a bit like a heavy weight version of M1 0W-40 or Delvac 1 5W-40 in its formulation
END
It's $10.95 a liter here in Fresno, $9.xx with my wholesale account. It's not cheap but its not freaken overpriced either. Even if you're paying more, you don't have to do oil changes for 7,500 miles to 15,000. My 96 M3 costs me more to take care of (oil wise) with it's 3,000 mile changes using Mobil 1 Kragen oil.
braymond141 is offline   Reply With Quote
Old 05-19-2010, 08:45 PM   #46
IFX
My Ride: M156
Guess you should move to something a bit less expensive to maintain?
IFX is offline   Reply With Quote
Old 05-19-2010, 09:01 PM   #47
HU///MMELL
My Ride: m3
Scheaffer's Supreme 9000 5w-50 Racing Motor Oil for high revving engines FTW.
Do your own research and make your own bed.
HU///MMELL is offline   Reply With Quote
Old 05-20-2010, 09:40 AM   #48
aayaz
My Ride: 2006 E46 Grey M3
Oil change mileage reset
Anyone have a DIY on how to reset the oil change mileage after you change the oil yourself?
aayaz is offline   Reply With Quote
Old 05-21-2010, 10:04 PM   #49
m3forchau
My Ride: M3
Where else can you buy the 10w-60 besides the dealer?
2001 Imola Red ///M3
m3forchau is offline   Reply With Quote
Old 05-21-2010, 10:41 PM   #50
IFX
My Ride: M156
Tischer BMW^
ECS tuning..
Old 05-22-2010, 06:04 AM   #51
shanneba
My Ride: 2003 330Ci
Red Line also offers a 10w-60 now. If I had a M3 or M5/6 I would run the Red line oil.
For a different view of viscosity in high performance cars, you could also read the Dr. Haas writings on BITOG, he runs 5w-20 in his Ferrari.
http://www.bobistheoilguy.com/aehaas/
Old 02-10-2013, 08:03 PM   #52
Bmwe46m3777
My Ride: 2003 m3
I bought a 2003 M3 about 8 months ago and love it. It has 179000 miles. 6 speed and had some engine work: valve cover gaskets and new exhaust header spark plugs and overall tune up before I bought it. I changed my oil with Mobil 1 15w50 and a oem Mann oil filter. Walmart 15w50 Mobil 1: 5 quart jug $27.00 one extra quart $7.00 Mann oil filter Ebay 14.00 shipped, $20.00 to my mechanic to change it out. = $68.00 bucks for my oil change. Like the previous posters have said I believe Castrol and BMW to be partners in for big profit monopoly and BMW needed a answer when they started having the problems with the rod bearings problems. I do believe it to be a good oil but Mobil 1 15w-50 is a very good oil as well. It is to my understanding That they used Mobil 1 in the first e46 m3 sure at a lower viscosity and then went with the 10w-60 when they learned of the problems for the 9k at rpm. My car has been running cooler since switching to Mobil 1 it had the tws when I bought it. I have not burned a drop of oil in 8000 miles with it as well. I am sticking to mobil1 15w-50 and you can keep your $175.00 oil change. I do believe all the talk about oil sheer and oil thinning at high rpm in the m3 and that a thick oil needs to be used. I think the specs of the oil sheer on the tws 10w-60 and m1 15w-50 are very very close and the oil burn off point is close as well. You can ck the specs on the internet. I am confident that I am protected as well or better with my m1 15w-50........
Bmwe46m3777 is offline   Reply With Quote
Old 02-11-2013, 03:59 PM   #53
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Maximum mileage for me is 5,000 per oil change (synthetic). I always used the "BMW recommended" oil but since have used ENEOS and TOTAL - I am seeing the oil actually looks better after 5k compared to the Castrol, which kind of surprised me. I'd say 7,500k max between oil changes - certainly not the dealership recommended 15,000 intervals. We had two e46 M3s come into our shop that the owner(s) took them to the 15k interval religiously and there was SOOOOOOO much oil sludge buildup in the cylinder head that we literally had to scoop it out which took forever and I don't even want to think about what that has done to the oil passageways.
While ENEOS doesn't list the oil as "BMW approved" but the Total does. (both have the same ratings on the back of the bottles as the Castrol by the way)
Castrol pays a lot of money to have their name inside the engine compartment, just the same way that Porsche pays a lot of money to have Mobil 1 in the engine bay. They try to recoup some of that expense by marking the oil up - sad but true.
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 02-11-2013, 06:56 PM   #54
Bmwe46m3777
My Ride: 2003 m3
Thanks for the info scca-ziptie. Just ordered a oil filter and plan to change the oil soon. Hope to keep the M3 running for as long as possible. The 10w-60 may be better oil but the 15w-50 is working for me and I live in Florida so the 15w is not much of a problem for me on cold start ups. Fun reading the threads on the 10w60 TWS vs others on the internet will drive you nuts all day but is fun and I am sure I am not the only M3e46 owner who has fallen asleep in bed thinking about oil.
I will look into the other 10w-60 ies available but for now probably stick with the 15w-50 m1. I am sort of a believer to keep the same type of oil each oil change to keep all the additives from mixing from oil to oil. Not sure how much truth to that but I have read it a lot that once you use a certain oil it is good to keep the same oil after each change.
My cars pretty old anyway and I don't spend much time in the 7000-9000 rpm range as I dont want to blow the motor but Ya thats where the fun is. If I am getting on it I will usually shift at 7k even thought he car can pull more.
Old 02-11-2013, 07:28 PM   #55
scca_ziptie
Understood and copy that.
Old 02-11-2013, 08:34 PM   #56
taylor192
My Ride: 2003.5 M3
These threads always make me laugh. Just go the the black stone site and read the many many people running synthetic for 10K+ miles with lots of life left in the oil when sampled and little issue with the oil being dirty.
Change it at whatever interval you want, it's your money.
That said, with 90% city driving I covered the 15k mile interval in 9k real miles in about a year, so I'm sticking with what my car tells me.
Sent from my Nexus 7 using Bimmer App
Old 02-24-2013, 11:35 AM   #57
RobTraina
My Ride: Buying bmw soon
Just wondering,
Does anyone run AMSoil? I run it in my bike and works trucks and love it. Just wondering if anyone runs it in their BMW?
RobTraina is offline   Reply With Quote
Old 02-24-2013, 12:21 PM   #58
330indy
My Ride: M3, Z3, 330i
TWS is like a heavier duty 0w-40. With that said, pay extra attention to shear and heat stability, especially with extending OCIs, which given the bearing wear risk, is ill advised.
I switched to Redline 10w-60.
BMW...........................CCA
330indy is offline   Reply With Quote
Old 08-30-2015, 06:02 PM   #59
[email protected]
My Ride: e46 M3
You are absolutely right,have been using Mobil 1 15w50 for all my cars have been using it in my 1980 911sc with 290k miles never a problem using it in my e30 for the last 45k miles which car now has 245k miles no problem,, bottom line its the best for me. you could tell a good motor oil when it comes time to change your oil and changing it when motor oil is hot and when you drain it it holds together does not splatter all over the place that happens when you use cheeper made oils.[QUOTE=plaroud;9308086]I use the same oil, mobil 1 15w-50.
enar2@verizon.net is offline   Reply With Quote
Old 08-30-2015, 06:09 PM   #60
[email protected]
My Ride: e46 M3
Originally Posted by RobTraina View Post
Just wondering,
Very good oil,,know lots of people that use it.
