Radiator now cracked, (is there a chance something is blowing my parts?) - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-15-2019, 12:38 PM   #21
tech4tech
My Ride: 2004 325i 70k miles
Year: 2004
Model: 325i
Transmission: Auto
I recently replaced my radiator with Nissens from fcp euro (~ $75) and was very pleased with the results. It fit without any issues, and came with some extra o-rings. It also came with 2 different plugs: one for automatic, one for manual transmission, so that is something you need to be careful about when you install.
tech4tech is offline   Reply With Quote
Old 05-15-2019, 01:59 PM   #22
DOB2009
My Ride: 325i
Originally Posted by armenh7 View Post
It's manual but the nissens comes with necessary o-rings
Thanks for advice/help guys. I'm going to go with the Nissens brand radiator. I have a buddy with jack/stands available to help this weekend, so I might as well just drain the block and go with the OEM BMW coolant like I wanted to originally, then replace the drain plug/crush washer. (unless this is some hard step I should avoid). I'm not going to save much $ attempting to re-use 3 blended coolants, possibly with debris in there from never flushing / multiple coolant part blowouts.
I THINK that is all I should need now besides maybe some lubricant for the hosing to go on easier?
I'm just trying to come up with a master order list at this point and get everything purchased for the weekend.
DOB2009 is offline   Reply With Quote
Old 05-15-2019, 02:07 PM   #23
DOB2009
My Ride: 325i
Thanks, I'm ordering from here now.
Old 05-15-2019, 04:43 PM   #24
jmo69
My Ride: 03 325xi 98 328is
Originally Posted by LeverThis View Post
Nevermind then about the atf cooler o rings ...
The ATF cooler doesn't attach to the radiator, it attaches to the expansion tank/mount.Click image for larger version
Sent from my SM-G950U using E46Fanatics mobile app
Alternative to expensive xi control arm bushings https://forum.e46fanatics.com/showthread.php?t=1231503
Bad outer xi ball joint? https://forum.e46fanatics.com/showthread.php?t=1127077
2003 325xi auto Stahlgrau
1998328is 5sp
jmo69 is offline   Reply With Quote
Old 05-16-2019, 10:58 AM   #25
DiceyOne
My Ride: 1999 328i
Send a message via AIM to DiceyOne
Most ppl on this forum like to point fingers at the expansion tank being the weak link but I'm a firm believer that most ppl have never actually taken the time to clean their radiator fins.
A while back I took compressed air (~50psi, don't over do it or fins may become damaged) and shot it in from the front and rear of the (original) rad and it was so dusty that I had to wear a dust mask. It looked like the car was on fire.
Obviously remove the parts that are in the way like the fan and/or bumper/air scoop. I would highly recommend doing this outside and on a day with steady wind. There was dust and sand all over the place. So what that means is even if your expansion tank has failed it was probably due to the fact that the rad is no longer able to provide the heat exchange capacity that it used to and therefor all other components are working harder.
This is good practice to help your A/C system also.
To prevent dirt going all over your engine you may want to drape a sheet over the front of the block or just plan on giving the engine bay a wash afterwards. It will be very dirty I promise.
DiceyOne is offline   Reply With Quote
Old 05-16-2019, 12:05 PM   #26
swordsman11868
My Ride: 2003 325i
Or wash with medium pressure water instead of air?
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 05-16-2019, 03:28 PM   #27
josephmech
My Ride: 2001 325i sedan 5m
I replaced my radiator with CSF all aluminum I was leaking coolant out getting light to come on
also went with mishimoto aluminum expansion tank needed to file the parts so they would fit but now no leaking
josephmech is offline   Reply With Quote
Old 05-21-2019, 07:10 PM   #28
BMOne
My Ride: 325CI 03
I'm experiencing the same thing as OP every few months it seems something leaks from the cooling system. I did a complete refresh 3 years ago except the radiator. Last leak was that hose sensor. This time there's another slow leak that I need to look into. Temps seem fine and usually sit at 96c but rarely I've seen them climb to 98c.
BMOne is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
*** Sub frame Damage *** Sign here if you have this Problem (Letter to BMW) 02BMW330ci General E46 Forum 1518 05-02-2019 09:30 PM
FS: Misc. Headlight parts from 05 Bi-xenon. versace7866 Lighting & Mobile Electronics (I.C.E.) 33 10-10-2008 07:16 PM
Just installed s/c...getting rid of old parts bigjae1976 Engine & Performance 11 04-19-2008 10:32 AM
Parts needed for Expansion Tank Replacement blackie2 General E46 Forum 4 04-08-2008 10:20 AM
FS: 03 BMW M3 & Parts yipses BC, AB, Saskatchewan, Manitoba 9 03-25-2008 12:32 PM
