Manual Shifter Sloppy - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 01-10-2020, 04:28 AM   #1
asm123
My Ride: 2005 M3 6spd
Hey everyone,
The shifter in my e46 M3 6MT with ~130k miles has been quite loose ever since I bought it at 100k miles. It's just general slop –*no specific direction, just loose overall. I really noticed it after driving some stock manual bimmers with tight shifters. Any ideas on what parts to replace that could help tighten up the shifter the most? All suggestions appreciated. Thanks
asm123 is offline   Reply With Quote
Old 01-10-2020, 09:47 AM   #2
Alan
Alan's Avatar
My Ride: 2006 M3
If its getting notchy and loose - this may be the problem: shifter cup:
https://www.ecstuning.com/b-genuine-...yABEgLS7_D_BwE
Or you can get the whole kit that addresses slop in multiple components:
https://www.ecstuning.com/b-genuine-...yABEgJsVvD_BwE
Alan is offline   Reply With Quote
Old 01-11-2020, 07:42 AM   #3
tedavis01
Do the rebuild. I have the same issue but only replaced the top end including the cup and it did not fix the issue.
tedavis01 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-12-2020, 12:09 PM   #4
asm123
Thanks for the help...I think I will go with the rebuild. How hard of a job is this if anyone has done it?
Old 01-13-2020, 01:22 AM   #5
mrgizmo04
My Ride: '05 ///M3
If your tranny is off the car then easy, otherwise there are parts that are very tight in there in terms of space to work.
Sent from my SM-G950U using Tapatalk
mrgizmo04 is offline   Reply With Quote
Old 01-13-2020, 09:26 AM   #6
smolck
My Ride: 2003 330ci (manual)
The problem is almost certainly EVERYTHING. But most commonly its the "shift rod joint" which connects the shift rod to the trans itself.
This kit has all you need with better parts. If you want stock parts, ECS has that kit too.
https://www.ecstuning.com/b-assemble...5117507695kt3/
Check out my BMW Blog
Check my Youtube channel for DIY's and fun stuff
smolck is offline   Reply With Quote
Old 01-13-2020, 07:58 PM   #7
tedavis01
Job is not too hard. I rebuilt the top end but did not fix the problem, have to fix the bottom end.
Old 01-14-2020, 12:52 AM   #8
mrgizmo04
My Ride: '05 ///M3
What do you classify as top end vs bottom end on the shifter?
Old 01-15-2020, 09:51 AM   #9
smolck
Sounds like he means the parts included in the kit I linked. The shift rod joint is the main piece that will tighten up the slop. The carrier bushings where the shift carrier connects to the trans is another one that flexes as well as the joint at the rear of the carrier, its just aft of the hole in the floor where the shifter is. All of those are “under” the car and thus probably what could be called “lower”.
Old 01-15-2020, 01:12 PM   #10
mrgizmo04
My Ride: '05 ///M3
But what is top end? Shifter knob?
I don't really like that kit as it forces you to buy parts that don't wear and don't need replacement, but it can be used as a guide. You won't need new clips or dowel pins. What wears out in the shift rod joint is the foam piece which is like $3 (item # 14 in realoem link below) vs buying the entire shift rod joint for no reason for $25.
From realoem diagram, you need to buy part numbers 7, 2, 10, 14, 4. (All in the correct quantities, obviously).
https://www.realoem.com/bmw/enUS/sho...diagId=25_0375
Old 01-18-2020, 10:15 PM   #11
tedavis01
By top end I mean everything you cAn get to from inside the car which is about half the process. The lower end is under the car work like connection to trans.
Old 01-19-2020, 02:23 AM   #12
spark90703
My Ride: 2003.5 E46 M3
not a easy job.
I removed the exhaust to get more room.
you need to replace the washers or add more washers to all the joints on the shifters.
add as much washers as you can to get the shifter tight.
spark90703 is offline   Reply With Quote
loose shifter, manual, shifter, shifter bushing, slop
