Anatomy of OEM Fuel Pump - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-04-2020, 03:09 PM   #1
paraklas
My Ride: B30_TS2++
Year: 2001
Transmission: 5-Getrag
Thought I'd share some pictures of the OEM VDO/Siemens fuel pump taken apart. The brushes of this pump were near end of life and I had changed it about years ago, it was the factory pump.
I had no idea that petrol passes through the entire motor and brushes area. this means that the pump is lubricated/cooled by petrol nomatter the fuel level..
Removed the external shell with a cutting disk. rest can be taken apart by hand.
Old 01-04-2020, 03:16 PM   #2
wfx32
My Ride: AWD
Model: 330XI 08/2004
Transmission: auto
interesting, thanks. this must be how i killed the pump with low quality gas/petrol years ago.
wfx32 is online now   Reply With Quote
Old 01-04-2020, 04:02 PM   #3
fumigator
My Ride: 2007 335i sedan
Thanks!
Sent from my SAMSUNG-SM-G930A using Tapatalk
fumigator is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-04-2020, 04:05 PM   #4
RayPooley
My Ride: 320i SE Coupe
Cheers.
Old 01-04-2020, 06:13 PM   #5
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
It is weird to think that these electric pumps are totally submerged in fuel. Seems an empty tank would wear it out quickly.
Hint to the SULEV cars still under warranty!
Old 01-10-2020, 10:48 PM   #6
89325iguy
My Ride: 325i,'89,'03
Transmission: Manual
Wow, cool. I just replace my pump and filter, car has 236,000 miles on it and the change in performance was drastic. I also got new upstream O2 sensors but decided not to use them just yet because the engine feels so much better I dont wann eff with it right now.
My new pump and filter made a huge difference in performance, just as much as new B6 dampeners on the corners.
Ď87, Ď89, Ď03 in the works.
89325iguy is offline   Reply With Quote
Old 01-12-2020, 07:11 PM   #7
JonL
My Ride: 2004 325Xi
Year: 2004
Model: 325Xi
Transmission: Auto
If the pump is lubricated by gasoline, which is a pretty poor lubricant, I wonder if the life of the pump could be extended appreciably by adding a small amount of two-stroke oil to the fuel. I think a small amount would be tolerated by the cats.
JonL is offline   Reply With Quote
Old 01-12-2020, 07:42 PM   #8
VpointVick
My Ride: '03 325iT Mysticblau
It needs coolant far more than lubricant.
VpointVick is offline   Reply With Quote
Old 01-12-2020, 11:04 PM   #9
Cheap Trick
My Ride: E46
Year: 2002
Model: 330ci cabriolet
Transmission: auto
Adding any oil to the gas in not a good idea ! I don't believe there would be any measurable increase in fuel pump life but over time there will be many problems with other items related to the fuel system. BMW is not alone with this fuel pump arrangement - pretty standard in the industry.
Cheap Trick is offline   Reply With Quote
Old 01-13-2020, 01:32 AM   #10
Silverdogz
My Ride: '02 330Ci, '04 330i
Year: 2004
Model: BMW 330i ZHP
Transmission: Manual 6spd
Fuel pumps are designed to use the gasoline as both the coolant and lubricant.
DSC MK60 Replacement and INPA Install:
Silverdogz is offline   Reply With Quote
Old 01-13-2020, 02:56 PM   #11
Sapote
My Ride: 2000 323i auto wagon
The weak link of these pumps are the brushes and commutator. Could the OP remove the brushes to show their length and the rotor's commutator condition? They could easily use brushless motor instead and it would last longer than the car.
Sapote is offline   Reply With Quote
Old 01-14-2020, 03:46 AM   #12
Alex323Ci
OE ///MEMBER PLUS
My Ride: M3 & 323Ci (sold)
itís almost never the brushes. people getting over 200,000 miles and 20 years later on original pumps.
true it is a weak link, but not the weakest link.
running them low-empty overheating and poor fuel quality the biggest killers. followed by overworking them from crud-filled choked filters.
Old 01-14-2020, 07:55 AM   #13
paraklas
My Ride: B30_TS2++
Year: 2001
For science purposes i'll take the brushes out as well
Old 01-14-2020, 10:18 AM   #14
bonestockE36
My Ride: 2002 330i auto
All fuel electric pumps are completely submerged. It cools the rotor and prevents sparks from exploding the tank. Fuel lubricates the brushes plenty.
bonestockE36 is offline   Reply With Quote
Old 01-14-2020, 10:44 AM   #15
malapane
My Ride: E46 M3 & F30 320 ZSP
Very cool. Thanks for sharing.
I have the feeling that a fuel pump is in my near future, so this is especially useful.
What does the fuel level sensor arrangement look like? I have never had one out on an E46.
malapane is offline   Reply With Quote
Old 01-15-2020, 07:58 PM   #16
BullCityBimmer
My Ride: 1998 323i
Refineries use additives in the gas to assist in lubrication. Thatís why cheap gas can kill a pump
BullCityBimmer is offline   Reply With Quote
Old 01-15-2020, 10:13 PM   #17
JonL
My Ride: 2004 325Xi
Year: 2004
Model: 325Xi
Transmission: Auto
Exactly. Which is why it's *possible* that a small amount of additional lubricant might help pump life. 2 stroke oil is designed to stay mixed with gasoline, and it is designed to burn cleanly without ash or carbon deposits. I doubt it would be harmful to anything (at reasonable ratios, say 100:1 or less). Whether it would be helpful is unknown.
Old 01-15-2020, 10:15 PM   #18
JonL
My Ride: 2004 325Xi
Year: 2004
Model: 325Xi
Transmission: Auto
What parts fail due to those causes?
