ZHP engine and 6-speed transmission into 330ci - parts and task lists - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 11-25-2019, 05:27 PM   #1
Archbid
My Ride: 330ci Convertible
Year: 03
Transmission: 5-Speed Manual
I was looking for a 6-speed and found a 6 speed and much lower mileage ZHP engine for a low price, so I decided to swap. Now that it is done, I wanted to share my very detailed part and task lists for anyone else doing a swap.
Two PDFs
- Parts
- Tasks
And here is a link to an Excel file with both:
https://www.dropbox.com/s/wisaljsdia...arts.xlsx?dl=0
Archbid is offline   Reply With Quote
Old 11-25-2019, 05:38 PM   #2
Archbid
Year: 03
For those that don't want to open docs, here is my part list:
Item, Part #, #, Cost, Vendor
Shifter
ZHP 6 speed knob, 25117896886, 1, $75, BMWminipartsstore
Shifting arm, reinforced, 25117523846, 1, $0, Included with transmission
Bush bearing oval, 25117519670, 2, $12.7, FCP Euro
Shifter bearing pin - left, 25117529078, 1, $5.48, FCP Euro
Shifter bearing pin - right, 25117529079, 1, $5.48, FCP Euro
Shift rod circlip, 25117571899, 1, $1.25, FCP Euro
Shifter bearing (ball socket), 25111220600, 1, $4.62, FCP Euro
Shifter (selector) shaft seal (15X21X5), 23117531360, 1, $21.25, FCP Euro
Selector Rod Joint, 25117580281, 1, $22.49, FCP Euro
Shifter bushing - shifter idler arm rear mount, 25111222015, 1, $34, Marin BMW
Driveshaft
ZHP driveshaft, 26117523913, 1, $0, Included with transmission
M3 flex disc, 26112226527, 1, $60, FCP Euro
Flex disc nuts, 07129900047, 6, $7.98, FCP Euro
Center support bearing, 26127501257, 1, $25.08, FCP Euro
Butyl tape, 26127511140, 1, $4.74, FCP Euro
Intermediate ring, 26117514120, 1, $4.72, FCP Euro
Driveshaft End Bushing - Corteco, 26117526611, 1, $5.97, FCP Euro
Transmission
6-Speed transmission GS6-37BZ, 23007532498, 1, $500, Craig’s List
Transmission plug, 23117531356, 2, $21.04, FCP Euro
Torx Asa-Bolt - M8X50 - transmission, 23001222887, 3, $6, BMW SF
Starter mount torx bolt M10X65 - transmission housing, 07129904681, 2, $9, BMW SF
Torx bolt M12x90 transmission housing, 23001222894, 2, $14, BMW SF
Torx bolt M12x50 transmission housing, 23001222891, 2, $10, BMW SF
Clutch
Clutch kit - Luk - pressure plate, clutch disc, release bearing, pilot bearing, clutch fork, and alignment tool, 21207531556, 1, $226.39, FCP Euro
Twin Mass Flywheel - Luk, 21207533868, 1, $383.37, FCP Euro
Flywheel bolt (M12X1,5X29,15), 11227519572, 8, $46.56, FCP Euro
Clutch fork pin, 21511223328, 1, $9.95, FCP Euro
Clutch release spring clip, 21517570284, 1, $4.29, FCP Euro
Clutch fillister screw (M8X16-ZNS3 MK), 07119906045, 6, $4.62, FCP Euro
Rubber clutch line grommet, 21521165819, 1, $3.43, FCP Euro
Mounts
Engine mount nut, 22116779973, 2, $7.08, FCP Euro
M3 engine mounts, 11812283798, 2, $78.86, FCP Euro
Hex nut (transmission mount), 22116779970, 2, $0.74, FCP Euro
Engine
ZHP Engine, , 1, $500, Craig’s List
AC belt - Contitech, 11287512762, 1, $5.22, FCP Euro
Idler pulley, 11287841228, 1, $14.99, FCP Euro
Water pump pulley + belt, 11511436590, 1, $32.85, FCP Euro
Drive Belt Tensioner Pulley - INA OEM, 11281748131, 1, $10.2, FCP Euro
Intake
CVV Valve , 11617501566, 1, $23.99, FCP Euro
Oil separator hose - valve cover to CVV, 11611432559, 1, $13.39, FCP Euro
Oil separator hose - connecting hose to CVV, 11617504535, 1, $13.78, FCP Euro
Breather hose - vent valve to dipstick tube, 11157532649, 1, $8.42, FCP Euro
Breather hose - Return - Oil separator hose to valve cover, 11617504536, 1, $12.49, FCP Euro
Air filter housing clip, 13719071752, 1, $5.93, FCP Euro
Vacuum hose - CRP, 11731259994, 1, $3.83, FCP Euro
Mercedes vacuum power adapter - O2Pilot mod, 1170780681, 1, $4.14, FCP Euro
Check valve for vacuum system, 11611312737, 1, $13.81, FCP Euro
Seals
DISA gasket, GA-BM-DISA-ORING-M54-S, 1, $5.65, German Auto Solutions
Intake manifold gasket, 11611436631, 1, $53.26, FCP Euro
Engine air distribution o-ring, 11617502761, 6, $5.94, FCP Euro
Dipstick upper o-ring, 11431717666, 1, $0.21, FCP Euro
Dipstick lower o-ring, 11431740045, 1, $5.85, Amazon
Oil filter housing gasket, 11421719855, 1, $9.09, FCP Euro
Valve cover gasket kit, 11129070990, 1, $18.49, FCP Euro
Valve cover grommets, 11121437395, 15, $10.35, FCP Euro
Oil pan gasket, 11131437237, 1, $19.99, FCP Euro
Oil pan bolt, 11131740000, 21, $25.41, FCP Euro
Oil pan long bolt 1, 11131435806, 1, $3.02, FCP Euro
Oil pan long bolt 2, 11131435807, 1, $1.48, FCP Euro
Throttle body gasket, 13547504729, 1, $4.99, FCP Euro
Crankshaft position sensor o-ring, 12141748398, 1, $0.87, FCP Euro
Rear main seal kit, 11141438274, 1, $117, FCP Euro
Coolant plug, 07119904539, 1, $1.98, FCP Euro
Coolant washer, 07119963200, 1, $0.18, FCP Euro
Power steering pump hose gasket, 64508390601, 1, $0.25, FCP Euro
VANOS
VANOS seals, BS001, 1, $60, beisansystems.com
VANOS anti-rattle kit, BS002, 1, $60, beisansystems.com
OFHG VANOS line banjo washers, 32411093596, 2, $2.46, FCP Euro
VANOS gasket, 11361433817, 1, $6.75, FCP Euro
VANOS piston bolt, 11361748745, 2, $10.56, FCP Euro
VANOS oil line, 11361705532, 1, $27.99, FCP Euro
Exhaust
Exhaust flange gasket, 18107502346, 2, $32.5, FCP Euro
Exhaust flange copper nuts - Volvo, 18301737774, 4, $1.92, FCP Euro
Exhaust hanger lower bracket, 18101433250, 1, $7.09, FCP Euro
Exhaust transmission hanger, 18301436331, 1, $6.79, FCP Euro
Exhaust hanger bolt, 07119902957, 1, $3.72, FCP Euro
Secondary air injection gasket, 11727505259, 1, $2.54, FCP Euro
Body
Reinforcement plate bolts, 17511, 16, $9, Bolt Depot
Reinforcement plate bolts , 17743, 16, $1, Bolt Depot
Cooling
Water pump - BMW, 11517509985, 1, $0
Water pump o-ring - Reinz, 11511711484, 1, $1.59, ECS Tuning
Thermostat - Borg-Warner, 11537509227, 1, $48.99, FCP Euro
Heater hose - engine inlet and water valve - Rein, 64218376999, 1, $13.87, FCP Euro
Coolant return hose - Rein, 11531436410, 1, $18.95, FCP Euro
Heater hose - radiator and expansion tank - Rein, 64218376153, 1, $27.73, FCP Euro
Heater hose - water valve and radiator - Rein, 64218363198, 1, $13.53, FCP Euro
Radiator - Nissens, 17119071518, 1, $74.99, FCP Euro
Heater hard line - inlet pipe, 11531705210, 1, $30.81, FCP Euro
Cooling hard line, 11537502525, 1, $40.85, FCP Euro
Electrical and Sensors
ZHP Cluster manual convertible, 62108036649, 62107905493, 62107919673, 1, $119, eBay
Oil temperature sensor, 13621433076, 1, $11.35, FCP Euro
Fluid level sensor, 17137524812, 1, $27.18, FCP Euro
Maintenance
Transmission fluid - liter, Red Line D4ATF, 2, $15, NAPA
BMW Coolant 4 liter container, BMW, 2, $40, BMW
Mann-Filter*X Metal-Free Oil*Filter, HU 925/4, 1, $7.49, Napa Auto Parts
Rotella T6 4 liter container, Rotella T6, 2, $40, O’Reillys
Old 11-25-2019, 08:46 PM   #3
Archbid
Year: 03
And here are the tasks
Fluids
  1. Drain oil and replace plug and washer - 18Nm (25 ft-lbs)
  2. Drain transmission fluid and replace drain screw - 35Nm (26 ft-lbs)
Breakdown
  1. Separate transmission from block
  2. Remove old clutch and pressure plate:
    • Remove 11 transmission bolts (and organize!)
    • Remove pressure plate
    • Remove clutch release lever, pivot and throwout bearing
    • Clean bell housing
    • Remove flywheel
  3. Remove water pump
  4. Clean timing chain cover
  5. Remove thermostat
  6. Remove alternator
  7. Remove belts
  8. Remove and clean engine mount brackets
  9. Remove and clean oil filter housing
  10. Remove starter motor
  11. Detach injector harness
  12. Remove AC compressor
  13. Remove and clean AC mount bracket
  14. Remove DISA
  15. Remove throttle body
  16. Remove ICV
  17. Release pressure and detach fuel rail
  18. Remove air distributor
  19. Remove intake manifold
  20. Remove CCV
Clean Engine
  1. Clean rear engine
  2. Clean block
  3. Clean valve cover and beauty covers
  4. Clean manifold and air distributor
  5. Clean dipstick tube (bottom)
Vanos and Valve Cover
  1. Remove coils
  2. Remove valve cover
  3. Detach VANOS
    • Unplug solenoid connector
    • Unplug exhaust connector
    • Detach VANOS oil line
    • Put rags down for oil!
    • Remove VANOS caps (allen)
    • Remove plugs
    • Remove bolts (more oil will come out)
  4. Repair VANOS seals
    • Remove housing bolts
    • Remove 2 solenoid connectors and exhaust sensor plug
    • Remove oil line
    • Remove engine hanger
    • Remove cover plates (allen)
    • Remove plastic caps and replace o-rings
    • Remove fasteners in cylinders
    • Remove unit
    • Unbolt housing (remember spring)
    • Remove pistons and replace seals (and bearing spacer)
    • Seat seals 5 mins in smaller bore then remove
    • Seat seals 5 mins in larger bore then remove
    • Reinstall seals and bolt covers - 10Nm
    • Remove and replace gasket. Clean with brake cleaner
    • Replace housing
    • Install torx bolts (reverse thread) -
    • Install housing nuts and bolt xcross pattern — 8Nm
    • Torque torx bolts - 8Nm reverse thread
    • Re-install caps
    • Re-install cover plates 50Nm (37 ft-lbs)
    • Reconnect exhaust and intake camshaft position sensor
    • Reconnect solenoid connector
    • Reattach support bracket - torque
  5. Reconnect VANOS oil feed line - replace washers - 19mm 32 Nm (24 ft-lbs)
  6. Re-install valve cover with new gasket - 10Nm (7 ft-lbs)
  7. Re-install coils
Seals
  1. Replace air distributor o-rings
  2. Replace DISA seal
  3. Replace crankshaft sensor o-ring
  4. Re-install oil filter housing with new gasket
    • 2 plugs, oil pressure, oil temp switches - 8.5Nm (6.26 ft-lbs)
    • 6 bolts - 22 Nm (16 ft-lbs)
  5. Remove and clean oil pan
  6. Replace rear main seal
    • Short bolts - 10Nm (7 ft-lbs)
    • 13mm bolts - 22 Nm (16 ft-lbs)
  7. Replace oil pan gasket and reinstall
    • 8.8 -16Nm (106 in-lbs)
    • 10.9 - 14Nm (10.3 ft-lbs)
Intake
  1. Install hard lines - 10Nm
  2. Install oil temp sensor 8.5Nm (6.26 ft-lbs)
  3. Replace CCV
  4. Install intake manifold with new gasket - TORQUE BOTTOM NUT
    • M7 Nuts - 15 Nm (11 ft-lbs)
    • M8 Nuts - 22 Nm (16 ft-lbs)
  5. Clean ICV with throttle cleaner
  6. Re-install ICV - 10Nm (7 ft-lbs)
  7. Re-install throttle body with new seal - 10Nm (7 ft-lbs)
  8. Install evap breather hose
  9. Re-connect fuel line to rail
Accessories, Belts and Pulleys
  1. Install new thermostat
    • 3 Identical Bolts 9.9 Nm (7.3 Ft Pounds)
    • Housing bolt right M8X30 24 Nm (17.7 ft-lbs)
  2. Install water pump
    • Mount to block*- 10Nm (7.4 ft-lbs, 89 in-lbs)
    • Install pulley with anti-seize - 10Nm (7.4 ft-lbs, 89 in-lbs)
  3. Re-install passenger and driver side engine mount brackets - 22Nm (16.2 ft-lbs)
  4. Re-install AC mounting bracket - 22Nm (16.2 ft-lbs)
  5. Install new idler pulley 45Nm (35 ft-lbs)
  6. Clean and re-install drive belt tensioner 24Nm (18 ft-lbs)
  7. Install new drive belt tensioner pulley 45Nm (33 ft-lbs)
  8. Clean and re-install AC belt tensioner 24Nm (18 ft-lbs)
  9. Install new AC tensioner pulley 45Nm (33 ft-lbs)
Transmission and Driveshaft
  1. Replace selector shaft seal
  2. Replace CSB on driveshaft
  3. Replace bearing on driveshaft
  4. Install new clutch and flywheel:
    • Bolt new flywheel star pattern - red Loctite (40 ft-lbs)
    • Install clutch disc and pressure plate (18 ft-lbs)
    • Re-attach fork, pivot, and throwout bearing
    • Grease all pressure points and splines
  5. Remove old slave cylinder and hoses from transmission
  6. Attach transmission mounts to transmission 21Nm (15.5 ft-lbs, 186 in-lbs)
  7. Bolt transmission to engine
    • M12x50 (12 & 1 o'clock positions looking fwd) - 72Nm (53 ft-lbs)
    • M12x90 (4 & 9 o'clock positions looking fwd) - 72Nm (53 ft-lbs)
    • M8x50 (5, 6 & 8 o'clock positions looking fwd) - 21Nm (15 ft-lbs)
    • M6 Hex for shield (3 o'clock position looking fwd) - 'Goodntight' (7Nm)
Detach Drivetrain
  1. Unbolt exhaust and drop
  2. Remove heat shields
  3. Detach transmission support crossmember - MARK LOCATION
  4. Remove flex disc
  5. Detach CSB - MARK LOCATION
  6. Detach differential and remove driveshaft
  7. Detach slave cylinder
  8. Detach shifter
  9. Remove shifter arm
Prep Car
  1. Drain block and replace plug 18Nm (25 ft-lbs)
  2. Drain power steering fluid
  3. Drain washer fluid reservoir
  4. Disconnect washer reservoir
  5. Remove cabin filter and enclosure
  6. Remove walls at back of engine bay
  7. Remove radiator frame and bumper
  8. Jack car
  9. Remove gravel pan and reinforcement plate
  10. Disconnect battery
  11. Disconnect and remove headlights
  12. Disconnect fog lights and horns
  13. Disconnect washer pumps
  14. Disconnect main power cable at drug bin
  15. Disconnect ground strap
  16. Unplug old engine harness at ECU
Remove Engine
  1. Remove airbox from engine bay
  2. Disconnect SAP hose
  3. Disconnect brake booster
  4. Disconnect intake boots and MAF
  5. Disconnect fuel lines
  6. Remove belts
  7. Disconnect and remove steering pump
  8. Detach AC compressor from block
  9. Detach radiator
  10. Disconnect cooling system
  11. Detach lines from heater core
  12. Disconnect steering cooler from radiator
  13. Detach engine mounts from engine
  14. Suspend engine
  15. Separate rack, pump and reservoir
  16. Detach rack from front subframe
  17. Disconnect steering giubo
  18. Detach front control arm inner ball joint and remove front subframe and mounts
  19. Remove headlight level sensor
  20. Detach sway bar brackets
  21. Remove engine from bay
  22. Remove existing coolant hoses from engine bay
Swap Parts
  1. Remove and repair harness
    • Boots on connectors
    • Fix wire loom
  2. Swap starter from old engine and install M10x65 (starter bolts) - 42Nm - (31 ft-lbs)
  3. Swap alternator
    • Alternator to crankcase M8 - 21Nm
    • Idler pulley to alternator - 45Nm
    • Attach positive terminal - M8 - 13Nm
  4. Swap power steering pump and reservoir
    • Mounting bolts (3) - torque - 22Nm (16 ft-lbs)
    • Power steering pump pulley screws - 22Nm (16 ft-lb)
    • Reservoir - 22Nm (16 ft-lbs)
  5. Swap O2 sensors pre- and post-cat - 37Nm (50 ft-lbs)
  6. Swap SAP check valve and replace gasket - 10Nm
  7. Install new SAP vacuum hose to solenoid
  8. Attach engine harness to new engine - Connections
    • Exhaust VANOS Solenoid
    • Exhaust camshaft position sensor
    • Thermostat heater
    • Intake camshaft position sensor
    • IAC
    • Throttle
    • Oil temp and pressure sensors
    • Alternator
    • EGR
    • Knock sensors
    • Crankshaft position sensor
    • Oil level sensor
    • Vacuum solenoid
    • Injectors
    • Intake temp sensor
    • Intake VANOS solenoid
  9. Attach old harness electrical box to new engine - 10Nm (7 ft-lbs)
  10. Torque dipstick tube support 22Nm (16 ft-lbs)
Engine Bay Prep
  1. Clean engine bay
  2. Clean gravel pan and reinforcement plate
  3. Install new heater core hoses in engine bay
  4. Connect shifter mount to frame - use lithium grease on ball joint
Drivetrain
  1. Connect driveshaft to differential flange (E12 torx) - 83 NM (61 ft-lbs)
  2. Preload CSB, apply butyl tape and connect - 21Nm (15 ft-lbs)
  3. Attach and torque flex disc to engine output shaft (10.9) - 60Nm (44 ft-lbs)
Install New Engine
  1. Move engine to bay
  2. Connect flex disc to drive shaft (10.9) - 60 Nm (44 ft-lbs)
  3. Attach AC compressor - 20Nm (15 ft-lbs, 177 in-lbs)
  4. Connection: AC compressor
  5. Attach engine mounts to engine - 45Nm (33 ft-lbs)
Front Subframe
  1. Attach engine mounts to subframe - 45Nm (33 ft-lbs)
  2. Attach front subframe to frame (10.9 grade) - 109Nm (81 ft-lbs)
  3. Attach front control arms inner ball joint - 89.5Nm (66 ft- lbs)
  4. Re-attach sway bar mounts - 22Nm (16 ft-lbs)
  5. Connect ground strap - 22Nm (16 ft-lbs)
  6. Connect power steering hoses to pump
  7. Re-attach steering rack to subframe - 44Nm (32 ft-lbs)
  8. Center steering
  9. Connect steering column giubo - clamping screw - 22Nm (16 ft-lbs)
  10. Top up steering reservoir
  11. Re-install light level sensor and inspect wiring
  12. Connection: Xenon level sensor
Connect Transmission
  1. Torque clutch slave to transmission - 22Nm (16 ft-lbs, 192 in-lbs)
  2. Connection
    • Reverse sensor leg from O2 sensor harness
    • Secure harness to rear of head with zip tie
  3. Torque Transmission Crossmember
    • Transmission mounts 21Nm (15.5 ft-lbs, 186 in-lbs)
    • Transmission Cross member to Chassis: 21Nm (15 ft-lbs, 186 in-lbs)
  4. Fill transmission A4DTF (1.7l) - 35Nm (26 ft-lbs)
  5. Install shifter bushing, circlip and cup
  6. Assemble shifter trim and 6-speed knob
Engine Connections
  1. Connect coolant hard lines to hoses
  2. Connect evap air hose
  3. Connect fuel filter vent line to f-connector
  4. Connect fuel lines
  5. Connect brake booster hose
  6. Connect hose to SAP pump
  7. Connection: SAP
  8. Install upper boot and MAF
  9. Connection: Engine harness at ECU
  10. Reinstall DISA - 10Nm (7 ft-lbs)
  11. Attach washer fluid reservoir
  12. Connections
    • MAF
    • DISA
    • O2 sensors
    • Washer fluid level sensor
    • Washer fluid pumps
    • Main power lead at drug bin
  13. Install belts
Radiator
  1. Install expansion tank level sensor
  2. Install radiator and reconnect radiator lines
  3. Fill coolant - 8.4 liters
Start Car
  1. Reconnect battery
  2. Fill oil - 7 liters
  3. Top off steering fluid
  4. Bleed cooling system
  5. Check oil
  6. Start car
Re-attach Exhaust
  1. Install heat shield - 10Nm
  2. Repair hose to exhaust flap
  3. Install muffler
    • Chassis plate - (13mm) - 22Nm (16 ft-lbs)
    • Muffler hanger to chassis (13mm) - 22Nm (16 ft-lbs)
    • M8 from hanger to muffler 15Nm (11 ft-lbs)
    • Exhaust pipe to manifold with copper anti-seize- 15Nm (11 ft-lbs)
  4. Reconnect rear v-strut
    • Large bolts (10mm) 59Nm+90
    • Small bolts (M8x16) 22Nm (16 ft-lbs)
  5. Re-attach Front End
  6. Install alternator vent ducts
  7. Re-attach front end
    • Attach bumper to brackets (M10) - 55Nm (41 ft-lbs)
    • Connect fog lights and horns
    • Connect headlight washer line
    • Front radiator support - 10Nm (89 in-lbs)
    • Tighten radiator core retainers
  8. Install and connect headlights
    • Install headlights
    • Reconnect headlight trim
    • Reconnect headlight washer spray extensions
  9. Reconnect hood release
  10. Connections:
    • Fan
    • Coolant temp sensor
    • AUC
  11. Connect external trim clips and screws
  12. Attach reinforcement plate - 59Nm (44 ft-lbs) + 90° + 30°
  13. Attach gravel pan
  14. Drop car
Engine Bay
  1. Replace bulkhead at master cylinder - attach heater hose bracket
  2. Reinstall engine vanity covers
  3. Reinstall cabin air filter housing - attach harness
  4. Reinstall air box
  5. Route harness/power cables
  6. Install fan cowl
Final Check
  1. Check oil
  2. Check coolant level
  3. Check steering fluid level
  4. Check brake fluid
  5. Fill washer fluid
  6. Check codes
Cluster
  1. Install ZHP cluster
  2. Code cluster
Sponsored Links
Advertisement
Old 11-26-2019, 11:17 PM   #4
SFTOrange
Thanks for the detailed list. I’ve been following your other thread. This will be a great reference for the future.
SFTOrange is offline   Reply With Quote
