DIY: Replacing front control arm balljoints - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 12-02-2019, 04:59 PM   #21
77'911
Originally Posted by EvaJuli View Post
Just ordered these, new FCAB, & inner joints....weekend project coming up.
Question is, can you get a ball joint separator in there or you need a pickle fork for the knuckle side (not the inners).
I had to use a pickle fork. Replaced all the lower control arms wt bushings, upper ball joints, new lollipop brackets, all factory bmw. Been solid for months now. It was pricey, but worth it.
regards
77'911 is offline   Reply With Quote
Old 12-02-2019, 11:30 PM   #22
jmo69
My Ride: 03 325xi 98 328is
I was able to get the Harbor Freight tool in to drop the arm without damaging the boot. The Joint had only been in there a few years however. I just took my time and didn't go nuts tightening the separator and lots of pounding on the control arm to help it come loose. It was a tight fit and I had to tap the separator into place. https://www.harborfreight.com/3-4-qu...tor-99849.html You'll need it for the inners anyway.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Old 12-06-2019, 12:13 PM   #23
EvaJuli
My Ride: E46 325XiT
ok who has tips for removing the ball joint without an air hammer?
I do have a 20ton press.
EvaJuli is offline   Reply With Quote
Old 12-06-2019, 08:33 PM   #24
EvaJuli
My Ride: E46 325XiT
I won!
Old 12-07-2019, 12:27 AM   #25
jmo69
I won!
With a 20 ton press you should be able to remove anything lol. With the right press tools I could probably do it with my home built 8 ton benchtop press. You still need to remove the "cap" over the bottom of the joint.
1998 328is 5sp
Old 12-07-2019, 10:23 AM   #26
EvaJuli
My Ride: E46 325XiT
I pressed one of the control arm bushings in about 2mm rotated mis-aligned with the marking points....do i need to remove and re-press it in or can this be adjusted when they do the front end alignment?
Any thoughts?
Old 12-07-2019, 11:10 AM   #27
Rickna
My Ride: '02 330xi - '09 IS-F
Year: 2002
Model: 330xi
Transmission: AT
The original xi ball joints are offset, E36 ball joints are centered. So you don't have to line up the marks.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 12-07-2019, 12:34 PM   #28
EvaJuli
My Ride: E46 325XiT
Im talking about the bushings that are offset, not the ball joint.
You can get centered bushings but i am using OEM and they are offset.
Old 12-07-2019, 06:17 PM   #29
Rickna
Year: 2002
Model: 330xi
Transmission: AT
Oop, I went off on a tangent...
2001 BMW 330xi
2009 Lexus IS-F
Old 12-07-2019, 06:39 PM   #30
EvaJuli
My Ride: E46 325XiT
I put them on anyways....i cant even think about pressing it out and in again. what a pain.
Ill see how the alignment sheet looks.
Old 12-10-2019, 09:51 PM   #31
jmo69
IDK what that will do to your alignment, my guess the toe will be off along with the caster. That's the nice thing about the e36 bushings and ball joints being centered.
1998 328is 5sp
Old 12-12-2019, 12:39 PM   #32
the fly
My Ride: '95 m3, '03 m3
You should have used me. I press FCABs for various different Bimmers and XIs are the biggest PITA of them all -- partly due to the length of the bushing.
Need FCABs? I sell them pre-pressed...
the fly is offline   Reply With Quote
