323Ci (M52tuB25) to M54B30 Complete Conversion, with MS43.0 DME and Drive By Wire - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Thread Tools Search this Thread Rating: Thread Rating: 244 votes, 5.00 average. Display Modes
Old 01-31-2015, 12:21 AM   #61
daniel_f.
My Ride: 330iC
Have a look at the fourth thread in my signature
No further development on MS4x from me.
Old 02-29-2016, 11:45 AM   #62
tangerine-dream
My Ride: 330i Wagon
Assistance w/ ECU Wiring on 2.5L to 3.0L Engine Swap
First Reply: Well I have embarked on this endeavor w/o regrets. Currently my car is at Edwards AFB Auto Hobby Shop and I will continue the installation starting Thursday-Saturday. Basically I wanted to ask shm21284 about the ECU approach to changing the flat pins to round pins (existing) or vise-versa. If you could text me you mobile or send me an email that would be super! Marc: 415.505.0181 or [email protected]
Thanks!!
tangerine-dream is offline   Reply With Quote
Old 03-20-2017, 10:55 PM   #63
BMW_Racing
My Ride: 2003 BMW M3
Hey shm21284...thanks for the great write up on your swap. I have almost completed the same swap except we are taking an M54b25 and dropping it into a 2000 BMW 323i. We are also doing an auto to manual swap at the same time. We took the M54b25 using the MS43 ecu.
Old motor out...
New motor in...
We have the motor all installed and are 99% complete with wiring swap. I had a question.
You mentioned the single wire that needs to be connected for the injector power.
The circled item is the injector power wire. The DME switches the injector signal on the ground side. Essentially, a single power wire needs run to port 87 on the fuel injector relay. On the 323/328, there is an extra port 87 open on the relay, so you only need to retrieve the correct wire from a donor car, de-pin it, and re-pin it into the relay's connector, X6327. This then runs to a white 8-pin connector X6053.
Starting with the injector relay, K6327, and connector X6327:
On my 323i Port 87 is already occupied with a wire.
I populated Pin 7 on the 8-pin connector.
The Pin that comes out of Pin5 on the Port 87 runs through the fuse panel...
Does Pin 7 need to connect to Pin 5 on the Port 87 even though Pin 5 is being used for something else?
BMW_Racing is offline   Reply With Quote
Old 03-21-2017, 12:31 PM   #64
mikeetastic
My Ride: lots of 3
Originally Posted by BMW_Racing View Post
Hey shm21284...thanks for the great write up on your swap. I have almost completed the same swap except we are taking an S54b25 and dropping it into a 2000 BMW 323i. We are also doing an auto to manual swap at the same time. We took the S54b25 using the MS43 ecu.
this thread might be helpful for you as both as ms42 to mss54
https://forum.e46fanatics.com/showthread.php?t=1120893
mikeetastic is offline   Reply With Quote
Old 03-21-2017, 01:21 PM   #65
BMW_Racing
thanks for the great link. That is the swap we did as a warm-up.
We took an S54 out of an M3-vert and put it into the e46 Touring. This swap was pretty straight forward as 'most' of the electrical parts played nicely with each other. Our problem is converting a non-drive-by-wire car into drive by wire. We have the added advantage of using the newer, MS43 ecu which accommodates the DBW pins, of which their are 6.
S54 into e46 Touring:
Donor Motor out-
Donor Motor back in e46 Touring-
Thanks again for the suggested link. I know somebody out there knows the answer.
Old 02-13-2018, 03:05 AM   #66
jwads
My Ride: ZHP swapped 323iT
Transmission: 5MT
Question on the fuel system. I'm preparing an M54B30 o swap into an M52TUB25 wagon. I see the fuel filter is different w pressure regulator integrated. What line needs to be run that i don't already have? Is it PN 16126752186
This writeup is super helpful too so thanks for putting in the effort OP.
Sent from my Pixel using Tapatalk
jwads is offline   Reply With Quote
Old 02-14-2018, 06:20 AM   #67
jdjg
My Ride: e39, m52tub30
Year: 1999
Model: e39
Transmission: Manual 5 speed
you can still use your current M52TÜ fuel system
I leaver my M52TÜ when I stroke and put the MS43 DME
jdjg is offline   Reply With Quote
Old 02-14-2018, 11:40 AM   #68
shm21284
My Ride: 323Ci M54B30 / MS43
OP here. I did convert to the MS43 fuel system. Regarding the fuel lines, I was able to reuse and adapt all my MS42 fuel lines. A little flexing and some new rubber lines and it was good to go. No need to replace the plastic hard lines. On the MS42, there are two rubber lines that run to the engine (feed and return). You can reuse one of these for the MS43 system, which has only a feed line to the fuel rail.
shm21284 is offline   Reply With Quote
Old 12-26-2018, 04:00 PM   #69
beemaboyz
hi, how did you wire up the oil pressure sensor?
i have then red oil pressure light on the cluster
beemaboyz is offline   Reply With Quote
Old 02-05-2020, 05:27 PM   #70
Mez_e46
Hey guys I did the M54B30 swap into a 2000 328ci and this thread was of great help. I was able to start the car and drive but my abs system is not working. My speedo on the cluster as well is not working. I see a traction control light and abs light on the dash. I was wondering if any of you guys dealt with the abs issues when doing the swap.
Also I would like to mentioned that I have changed My rear end an LSD thus came with the blue wheel speed sensor and the car has the grey speed sensor. I was able to plug the sensors together but when i scanned the car it gave me 3 codes for wheel speed sensor. I don't get a code for the rear right wheel speed sensor.
Any input is greatly appreciated
Mez_e46 is offline   Reply With Quote
Old 02-05-2020, 08:24 PM   #71
Mez_e46
Hey guys I just swapped from an M52 to an M54B30. My speedometer doesn't work and my abs system doesn't work. I have an M3 rear end which comes with the blue wheel speed sensor and the car came with the grey speed sensor.
Who has completed the swap and what's the fix? I searched and could not find anything.
