new convertible top, the rear sits crooked - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 10-20-2019, 05:41 PM   #1
Sev1980
My Ride: 05 M3 02 330cic
So I got a new convertible top put on by a upholstery shop, I got it back 2 days ago and I'm noticing the 5th bow, basically the part that sits on top of the convertible top boot (right under the rear window), on the right side it sits nice and flush but on the left side it's sitting about half an inch high. Is this due to improper installation or due to the top being new and needing to stretch? I'm worried its the former....
help.
Sev1980
Sev1980 is offline   Reply With Quote
Old 10-20-2019, 05:43 PM   #2
Sev1980
Here's a few photos showing what I mean
ID:	786239   Click image for larger version
Sev1980
Old 10-21-2019, 12:47 PM   #3
All2kool
My Ride: 2002 325Ci
Did you try pulling it down a tad?
Previous:
All2kool is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-21-2019, 01:27 PM   #4
Sev1980
yeah, it goes back to where it was... doesnt seem to want to come down.
im worried the installer messed something up, it still seals, but just barely.
Sev1980
Old 10-21-2019, 01:34 PM   #5
All2kool
My Ride: 2002 325Ci
If it were me, I'd thoroughly wet the roof, cycle it a few times and see if that helps. If after it's fully dry and still not correct, back to the shop that did the work I would go.
Previous:
Old 10-21-2019, 02:26 PM   #6
Sev1980
thanks for the suggestion, i'll give that a try!
Sev1980
Old 02-13-2020, 09:43 PM   #7
Anticdubai
Hope you found solution, as post is ew month long.
No wetting-drying wont help. It is clearly wrong cutting/ fitting/installing by work shop.
Anticdubai is offline   Reply With Quote
Old 02-15-2020, 09:48 PM   #8
prodjay10
Is it the bow or the fabric? Can you see light when looking out from inside the car?
prodjay10 is offline   Reply With Quote
Old 02-15-2020, 11:50 PM   #9
MoparJim
My Ride: BMW
Year: 2004
Model: 330Ci convertible
Transmission: Auto
Improper installation...
MoparJim is offline   Reply With Quote
Old 02-16-2020, 03:55 PM   #10
prodjay10
Why is it improper installation?
Old 02-16-2020, 10:30 PM   #11
MoparJim
My Ride: BMW
Year: 2004
Transmission: Auto
If the installation was done properly it wouldn't sit like that.
Old 02-16-2020, 11:09 PM   #12
prodjay10
The material sometimes needs time to stretch.
Old 02-16-2020, 11:54 PM   #13
MoparJim
My Ride: BMW
Year: 2004
Transmission: Auto
I might agree with you if the top was sitting the same all the way across, but it's not. One side is tighter than the other. That is an installation failure.
Old 02-25-2020, 11:51 PM   #14
Sev1980
honestly its still like the way it was when installed but it doesnt leak so i just let it go...
Sev1980
Old 02-25-2020, 11:51 PM   #15
Sev1980
no its sealed
Sev1980
Old 02-26-2020, 12:10 AM   #16
prodjay10
There is a hard plastic holding the top down. You might be able to remove the screws and plate holding that down to pull the top/binding down a bit. Problem is that the plastic is pretty stiff. It'll be difficult to adjust. The aftermarket plastic parts usually aren't the perfect size or shape so things like this happen sometimes.
