330xi Vibration under acceleration - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-11-2020, 12:13 PM   #1
BHarris
My Ride: 2005 330XI
Transmission: GM Auto
Hey all,
This is my second time reaching out about my issue. I had thought I solved it but no. So, my car vibrates between 25-40 mph. It starts exactly at 25 and peaks around 30, then fades out towards 40. My ears aren't good enough to pinpoint the sound, and I feel it through the steering wheel too. Originally the vibration existed between 12 & 17 mph and felt the same as it does now. I ended up replacing the CSB & the guibo which eliminated the original vibration at the lower speed but developed the current (25-40mph). I replaced both of my front axles in an attempt to fix this and it marginally reduced overall vibration. The car also has the clunk at low speeds in the front end and a clunk when coming to a stop in reverse the first time after its been sitting for a while (backing out of a parking spot in the morning and breaking results in a clunk when I come to a stop, it's worse the colder it is).
When I replaced my CSB the driveshaft came apart before I was able to mark it. However I saw two arrows stamped into the drive shafts which seemed to be factory alignment tools.
Any thoughts or opinions would be greatly appreciated,
Thank you!
2005 330xi
BHarris is offline   Reply With Quote
Old 02-11-2020, 12:40 PM   #2
77'911
Have you tried to rotate the wheels to eliminate that factor? I'd also look at the motor and transfer case mounts. The coupler in the steering column can also tighten things up if replaced. I'm assuming you've eliminated the front end(tire rod assemblies, lower control arms/bushings, etc..)?
regards
77'911 is offline   Reply With Quote
Old 02-11-2020, 12:40 PM   #3
77'911
regards
Sponsored Links
Advertisement
Old 02-11-2020, 01:01 PM   #4
BHarris
My Ride: 2005 330XI
regards
yes, I have rotated the wheels multiple times and nothing has changed.
everything up front looks good with the exception of the control arm bushing, which I am assuming my clunk is and my tie rod arms are both new.
I did the youtube motor mount tests and nothing seems to be wrong but I'm not eliminating them, I plan on getting to them eventually just for added smoothness.
Do you know how to check the transfer case mounts?
2005 330xi
Old 02-11-2020, 01:50 PM   #5
Brewtus79
My Ride: M3 Vert, 330xi, X5
Year: 2002
Model: M3, 330xi, F15 X5
Transmission: 6 spd manuals
How about play in the sway bar links causing the clunk? Check them for slop. FCABs will give some vibration similar to warped rotors, but can be differentiated from the latter bc the vibration and shimmy are there when not applying the brakes.
Sent from my SM-G950U using Tapatalk
Brewtus79 is offline   Reply With Quote
Old 02-11-2020, 03:04 PM   #6
77'911
My rule of thumb on drive line mounts, more then 60k and 15 years, change them out. Our motor mounts on an 02 330xi were absolutely shot at 60k. Have not gotten to our transfer case one, but I can see the cracking in it. It's time.
On joints like the tire rod ends, ball joints, use a large pair of channel locks to squeeze down on them. If any movement up and down, replace.
https://www.homedepot.com/p/Channell...-480/303692256
Even though your arms are new, does not mean you can't have a bad one. I just had to replace the lower control arms, upper ball joints and bushings due to a shop installing crap after market units that were bad from the get go. Don't trust anything, all is suspect, until proven otherwise.
I don't know what your hearing is like as mine is horrid. Having said that, there are a number of items in back that could cause a clunk:
1) broken rear springs at the bottom
2) bad shocks or mounts
3) sway bar bushings and links
4) bad exhaust hangers (as soon as we bought our car, I replace all of these along with drive line mounts, automatically. It gets rid of a lot of issues right off the bat).
regards
Old 02-11-2020, 03:10 PM   #7
jmo69
My Ride: 03 325xi 98 328is
I had a shake while braking before I did my FCABs, gone after replacement.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
jmo69 is offline   Reply With Quote
Old 02-11-2020, 05:54 PM   #8
Brewtus79
Year: 2002
Cant argue with that. I suppose the vibration felt is less pronounced than the warped rotor sensation, say just when the rotors are starting to wobulate.
Old 02-16-2020, 03:33 PM   #9
jmo69
I had a bad outer ball joint that would clunk when I drove into my driveway, replaced them with e36 non M outer ball joints, clunk went away. later on I did the e36 centered rubber bushings and took care of the brake shake.
Old 02-16-2020, 03:39 PM   #10
BHarris
My Ride: 2005 330XI
I've been planning on doing the FCAB for a while now, however it only seems that the drivers side one had play in it when I have the car up in the air. Is that normal or should I be looking for the cause of that?
2005 330xi
Old 02-17-2020, 10:52 AM   #11
77'911
I'd also check that they are pressed in correctly to the specific xi spec. Many techs will just press them in half way which does not provide enough support for the control arm. This can cause vibrations. Sorry I don't have the spec handy, I'm out of country and don't have my Bentley Manual with me.
Old 02-17-2020, 07:30 PM   #12
BHarris
My Ride: 2005 330XI
Thank you
2005 330xi
Old 02-18-2020, 09:17 AM   #13
the fly
My Ride: '95 m3, '03 m3
The FCABs on XI are fluid-filled, and tend to have worse longevity because of it. If it hasn't been replaced in 50k miles, you will feel a difference.
Need FCABs? I sell them pre-pressed...
the fly is offline   Reply With Quote
Old 02-19-2020, 02:30 PM   #14
jmo69
With the contention that you should change your FCABs consider Poly or the e36 M3 centered solid rubber. I've got these in my xi and have installed them in 2 others with no ill effects. https://www.fcpeuro.com/products/bmw...3-31129069035l
Old 02-22-2020, 03:56 PM   #15
BHarris
My Ride: 2005 330XI
Alright so good and bad news..... the bushings definitely needed to be replaced and it makes a huge difference on the highway, however the clunk is still there. I'm beginning to think it's sway bar related. Also I noticed I need a new tie rod end boot as it's torn. I'm assuming this is a recent development as there is no play in the tie rod itself.
2005 330xi
Old 02-22-2020, 04:14 PM   #16
jmo69
If you think the sway bar is the cause of the clunk, pull the end links off, you can drive the car without the sway bar. More body roll but drivable. I had a broken link and all I had was a rattle on bumps.
Old 02-23-2020, 11:27 PM   #17
Alpinerunner
My Ride: 1990 M3
This is sound diagnostic advice. However, if you noise is under acceleration, it's extremely unlikely that your issue is suspension... those issues usually come up on under braking or over bumps. Vibration under acceleration is most likely the driveshaft. An older (original) driveshaft with shot (froze) U-joints will kill a CSB in short order. I had the same issue in my 2004 325xi wagon. Violent banging around 30mph. CSB was replaced at around 135k, and at 192k, problem was back. A fully new rebuilt driveshaft fixed the issue.
Alpinerunner is offline   Reply With Quote
Old 02-24-2020, 08:48 AM   #18
King Hill
King Hill is offline   Reply With Quote
Old 02-24-2020, 05:57 PM   #19
BHarris
My Ride: 2005 330XI
great idea, that will definitely be tested when I get the opportunity to.
2005 330xi
Old 02-24-2020, 05:58 PM   #20
BHarris
My Ride: 2005 330XI
I think that is going to solve the problem. However I'm going to replace the engine and transmission mounts before hand to eliminate both of those options as they are both due to be replaced.
2005 330xi
