Rain water leak passenger side front & rear footwells - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > E46 BMW > E46 Touring
E46 Touring
The E46 touring forum. Talk about your sport wagon E46 here.
Old 01-11-2020, 05:41 AM   #1
Huggie71
Hey guys just joined and thought id share this post incase helps others ***x1f44d; had leak coming in front under glovebox A pillar looked like vapour seal or windscreen leak but no...also rear footwell soaked atleast 2 inch of water in heavy rain. Anywho after months of searhing found it ***x1f601; turned out to be the roof bar ***x1f644; rubber seals had perished and rain water ran down all pillars filling the passenger rear and front footwells which has now broken my yaw/speed sensor under passenger seat carpet ***x1f614; fml. Anyway i hope this helps someone as it puzzled me for months ***x1f44d;
Huggie71 is offline   Reply With Quote
Old 02-06-2020, 11:20 AM   #2
runnr548
My Ride: 97 328ti,325i,328i's
I believe I have the same issue. New gaskets ordered. We shall see!
runnr548 is offline   Reply With Quote
Old 02-06-2020, 05:24 PM   #3
jagmandan
My Ride: E46 325xit -> 330xit
Thanks for posting this. I don't have water issues now, and my car is mostly garaged, but this is something I should check. My roof rails are removed... been long enough that I don't recall how I sealed the underside. The trim openings are covered with racer's tape which holds up remarkably well (years).
jagmandan is offline   Reply With Quote
Old 02-14-2020, 05:30 AM   #4
aesir
My Ride: 01 325iT
I'm having the same issue I believe. What gaskets did you order?
aesir is offline   Reply With Quote
Old 02-16-2020, 12:03 PM   #5
jdamore44
My Ride: '03 M3, '01 325xiT
I'll be ordering 6, 7, 8. ... about 60 bucks on ECS for both sides.
jdamore44 is offline   Reply With Quote
Old 02-16-2020, 01:13 PM   #6
VpointVick
My Ride: '03 325iT Mysticblau
Those don't actually seal any water out of the body. You can achieve what you're after just by putting some RTV on the screws that attach #3 to the roof.
VpointVick is offline   Reply With Quote
Old 02-16-2020, 01:24 PM   #7
jdamore44
Well thats good to know!
Sent from my SM-G950U using Tapatalk
Old 02-16-2020, 01:32 PM   #8
VpointVick
Those gaskets simply isolate the roof rails from the body and prevent noises from the parts rubbing together as the body flexes. They might need to be replaced for cosmetic reasons since the hinge point where the flap that covers the mounting screws is quite weak and could fail when you go to access them (a couple of mine did, was fortunate enough to find a touring to grab gaskets off of in the u-pick yard for spares), but the area below the plastic trim strip is where it needs to actually be water tight.
Old 02-17-2020, 03:23 PM   #9
yjsaabman
My Ride: '03 325i Touring
When I had the dreaded glovebox drip on my 2001 it was the front right sunroof drain that was off. Car would stay dry when parked nose uphill, but when parked nose downhill it got soaked. Reattached and secured the sunroof drain and all was well. Sunroof drains being off or clogged are a top cause for water leaks.
Sent from my SM-G970U using Tapatalk
yjsaabman is online now   Reply With Quote
