Xi Lowering / Have Your Cake & Eat It Too - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 4.73 average. Display Modes
Old 10-22-2015, 12:29 AM   #21
ItsAllAboutTheXI
My Ride: 2004 TiAg 330xi
Originally Posted by Rob43 View Post
Has something recently changed ? When we last talked, you didn't even want to spend $500 on your Xi's suspension.
I just looked at your pic & your Bimmer looks good. The drop hats will lower the front about 1/2" more but in turn will "Lift" the rear end slightly more so be prepared to install thinner rear spring pads to even things out.
Rob43
Not really. Still holding off, but I like to be thorough in my research. If I even lower my car I'll probably wait till March-April at this point. I could use the extra clearance this winter.
ItsAllAboutTheXI is offline   Reply With Quote
Old 10-24-2015, 08:50 AM   #22
jtyghter
My Ride: 03' 330xi
Do u have a part number for those? what's the difference in thickness?
jtyghter is offline   Reply With Quote
Old 10-24-2015, 10:50 AM   #23
Rob43
My Ride: 03 331Ci 5spd R1200R
You can get:
1) 3mm
2) 5mm
3) 7.5mm
4) 10mm
5) 14.5mm
But I'd tell you to wait & assess your new look after you've driven it for a day or two. Since this job has nothing to do with the front, just wait & estimate the proper drop you need. BTW, please post up 2 or 3 good quality close up side pics with the lens at ~2.5 feet off the ground; maybe a before & after.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
(DynoDynamics
Dyno Video)
Old 10-24-2015, 10:56 AM   #24
jtyghter
My Ride: 03' 330xi
Yeah I was planning on waiting just to see how it looked. I had no idea there was that many sizes. Ill take the pics like u described also.
Old 11-03-2015, 01:23 AM   #25
Rob43
What's your status, have you installed your drop hats yet ?
Rob43
(DynoDynamics
Dyno Video)
Old 11-03-2015, 09:20 PM   #26
jtyghter
My Ride: 03' 330xi
Rob43
Haven't had a chance yet.. Definitely Thursday or Friday of this week though
Old 11-03-2015, 09:23 PM   #27
Rob43
Great.
Pictures, Pictures, Pictures.....
Rob43
(DynoDynamics
Dyno Video)
Old 11-07-2015, 04:02 PM   #28
jtyghter
My Ride: 03' 330xi
Got the drop hats on today I'll give it a day or two to settle and take the after pics
Old 11-07-2015, 07:36 PM   #29
Rob43
That sounds good.
What's funny is there were two Xi Drop Hat jobs done today, East Coast & West Coast.
Rob43
(DynoDynamics
Dyno Video)
Old 11-08-2015, 09:10 PM   #30
zander271
My Ride: 6spd ZHP/5sp XI
Xi Lowering / Have Your Cake & Eat it Too
That was me LOL. West coast drop hat installer checking in.
Old 11-08-2015, 09:55 PM   #31
Rob43
Yep !
Rob43
(DynoDynamics
Dyno Video)
Old 11-11-2015, 06:58 PM   #32
jtyghter
My Ride: 03' 330xi
Before drop hats
Old 11-11-2015, 06:59 PM   #33
jtyghter
My Ride: 03' 330xi
And after
Old 11-11-2015, 07:01 PM   #34
jtyghter
My Ride: 03' 330xi
It's hard to see difference in pics but after a few days I have definitely noticed small drop at least 1/2inch I'm satisfied!
Old 11-11-2015, 07:41 PM   #35
Rob43
Your Xi looks Real Good, congrats on your Drop Hat success !
Here are edited side by side pics showing your Xi as equally as possible.
Rob43
...............Before...........................After
ID:	617618   Click image for larger version
(DynoDynamics
Dyno Video)
Old 11-21-2015, 06:44 PM   #36
nallman
My Ride: 2004 330xi
What is the difference between the xi Eibach Pro Kit and the stock RWD springs?
I was thinking of pulling the trigger on the Eibachs for my 04 xi.
nallman is offline   Reply With Quote
Old 11-21-2015, 11:17 PM   #37
zander271
Eibach springs are more stiff than stock, but not as stiff as H&R springs. I have the H&R springs and honestly I would say I like the feel of the Eibachs better(I have them on my ZHP). To get more of the raked/even lowered look you will need to get the drop hats if you do go the EIbach route.
For the XI you want to get Koni yellows and Rob43 9 way adjustable rears. You have 3 options for springs. Ebay(ask rob), Eibach, and H&R.
Old 11-24-2015, 12:14 PM   #38
groundshock
My Ride: 04 330Xi
Just a bit of an update to this thread - I've got about 8-9K on my setup, OEM shocks/struts with new OEM strut mounts and the Eibach XI-specific spring kit. Still infinitely impressed with the ride and handling, but I've now run into a few somewhat expected issues.
Issue #1 - Front alignment. Camber is not adjustable to under -1.7 degrees in the front. After settling, it really cambered out. Can't correct it without camber plates. Yes, I did wait this long to have it aligned due to the tires being shite already and honestly just being lazy and it being summer where I could get away with a crap set of tires. Now that winter is here I've bought new tires and I'm up against that issue which has to be corrected ASAP or the new tires will be shot.
Issue #2 - CV Boots. Both front CV axles have torn boots. I replaced the driver's side axle when I installed the springs. So there's that. I knew this was a risk I'd be taking. I do not have a solution to the issue at this point.
Just thought you guys should be aware. I really feel like the front has settled unnecessarily low, however I haven't measured it to see the difference in arch height or wheel gap vs. the rear. I'd definitely feel more comfortable with a 1/4 to a 1/2 inch higher in the front, at least from what I can tell by looking at it. YMMV.
2004 TiAg 330xi Sedan
2008 GTI DSG 5Dr
groundshock is offline   Reply With Quote
Old 11-24-2015, 01:48 PM   #39
Rob43
^ Post up some quality close up side veiw pictures of your Bimmer.
The lower you go, the more negative camber you automatically get, why don't you raise
it up the 1/4" to 1/2" you want ? They're creative ways to accomplish this.
Rob43
(DynoDynamics
Dyno Video)
Old 11-24-2015, 02:55 PM   #40
groundshock
My Ride: 04 330Xi
I'm at work right now, car is in the shop. This was a week after I installed the springs. It's settled a bit lower since then.
Admittedly, if I could find a solution to the boots cracking, I'd be pretty happy after a set of camber plates and a proper alignment. I know -1.7 isn't the end of the world, but new tires are new tires.
2008 GTI DSG 5Dr
