e46 316 N42 to 325 M54 engine swap - WIRING HELP!!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 11-30-2016, 07:57 PM   #1
chinmasterj
My Ride: e46 Compact
Hi anyone who is reading this,
I'm looking for some help. I've got a 316ti compact thats engine has died.
This has meant upgrade time in the form of a 2.5 M54 from a 352ci.
The engine is in but the car will not turn over. The fuel pump primes, I've jumped the starter, the ECU/DME, EWS, transponder is swapped in from the 325. Since its not cranking over at all I dont think its the EWS. I've got a cable and the BMW TIS software and have logged into the ECU and checked and realigned the EWS.
The looms all in, apart from one plug which does not seem right. The wires going from the chassis harness to the engine harness are all different colours.
Close up of each plug:
I've now probably spent 4 hours searching for answers so I'm hoping one of you might have that little nugget of knowledge that might help?
Any advice would be greatly appreciated!_a_
chinmasterj is offline   Reply With Quote
Old 02-21-2018, 12:34 PM   #2
j2sound
My Ride: 316ti Se Compact
Did you ever get to bottom of this? Iím in same situation
Sent from my iPad using E46Fanatics
Written off... Reshelled... Headgasket failure... Repaired... What next...?
View my full reshell and then head gasket replacment here:
j2sound is offline   Reply With Quote
