2001 325ci swap with a 2005 330ci - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 08-28-2019, 04:22 PM   #1
D4rcyK
I have swapped the engines out, flashed the ecu with the 330 tune. It cranks but won't start. I didn't use any parts from the 325 except for the O2 sensor harness. I don't have the 325 engine anymore so I'm not able to swap any more components from it. Any suggestions where to start to figure out what the problem is?
D4rcyK is offline   Reply With Quote
Old 09-05-2019, 12:05 PM   #2
Effduration
My Ride: '05 330CiC
SO, you put a 330ci engine (M54B30) in a 325ci car ? is that right?
Did you keep the 325ci DME (Ecu) - which matched the car and then flash it to the 330 tune?
Do you have any codes ? Can your code reader (or INPA, etc) communicate with the DME? Sounds like you have an EWS pblm or possible a DME ground pblm. Who flashed your ECU? Do it yourself?
Figure out if you have fuel, or spark
The increasingly common method is to get it running using the original 325 DME then flash later
Effduration is online now   Reply With Quote
