e60 530d 214bhp engine into e46 320d compact 150bhp - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 05-01-2017, 08:56 PM   #1
ashcossie
My Ride: 320d compact
Hi just had timing chain snap on my e46 320d 150bhp 6speed compact, have allways wanted to go the 3.0d route with it, have brought a crashed e60 530d 214bhp auto, just looking for some advice on what other parts i will need to carry out the conversion
thanks
ashcossie is offline   Reply With Quote
Old 05-02-2017, 05:05 PM   #2
ashcossie
Planning on keeping the manual 6speed box and rear setup for now, and will upgrade after its up and running
Old 05-03-2017, 05:35 PM   #3
jd improved
My Ride: charged 330i smg
The M57n b30 of the e60 has a bigger clutch bell housing bolt pattern than the M47. The M57n of the e46 330d is the last 3L diesel with the small pattern same as M47
jd improved is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-03-2017, 09:14 PM   #4
ashcossie
is there anyway around that, by using a different box or bell housing
Old 05-03-2017, 09:27 PM   #5
ashcossie
so would the e46 330d 204bhp 6 speed box work ?
Old 05-04-2017, 05:30 PM   #6
jd improved
No, the e46 330d 204hp m57n is the last 3L Diesel with the small bellhousing. You should also have an m57n but with the bigger bellhousing.
I have some different motors and gearboxes at my garage. If I find some time at the weekend, I will have a look if it is possible to redrill some boltholes to fit a small bellhousing gearbox to a big bellhusing motor.
Old 05-06-2017, 01:20 AM   #7
ashcossie
thanks mate
Old 05-06-2017, 09:07 PM   #8
jd improved
Ok you its possible to fit your 320d gearbox to the 530d e60 motor if you redrill the two big boltholes on the sides of the block, the two holes on the top will fit directly.
Also you need an 530d dual mass flywheel. The 530d or 330d clutches don't fit to the input spline of your gearbox. But the 240mm clutch of your compact 320d will fit to that 530d dmf but i don't know if it holds the 500nm of tourque for long. So maybe you should look for an upgraded clutch.
I don't know what else you need. e46 330d motor mounts, maybe 330d oilpan!? It's not the easyest swap you want to do. The 330d and 530d motors are mainly the same but the small things that are different can make big trouble.
Old 05-11-2017, 01:55 AM   #9
ashcossie
thanks for the help mate, will let you no how i get on
Old 07-07-2017, 06:53 PM   #10
T-N-T
My Ride: 330d
oil pan different, bellhousing as above (but I redrilled the 2 holes that didn't match)
T-N-T is offline   Reply With Quote
