BMW E46 330cd swap on Samurai - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 03-16-2017, 03:59 AM   #1
rsrider
My Ride: BMW 330cd
Hello, I apologize for my English but I'm using google translate.
My name is Thomas, I'm Italian and I have a problem with a BMW engine.
I do off-road and I created a prototype based on suzuki samurai with whom I would like to take part in competitions.
On this prototype suzuki I installed an engine BMW E46 330Cd 2004, unfortunately I can not switch it on.
I have problems with the ECU, and EWS.
I have the original BMW engine with wiring and sensors, the ECU, the EWS with the ignition key, the key, the instrument panel, and the accelerator pedal.
At first I was able to start the engine, but then turning it off probably incorrectly blocked the EWS me.
Now I look for a way to start the engine, I'd rather permanently delete the part of the key and the EWS.
Can you help me?
Thank you
Thomas
Salve, mi scuso per il mio inglese ma sto usando google translate.
Mi chiamo Thomas, sono Italiano e ho un problema con un motore BMW.
Faccio fuoristrada e ho creato un prototipo su base suzuki samurai con cui vorrei partecipare a delle gare.
Su questo suzuki prototipo ho installato un motore BMW E46 330cd del 2004, purtroppo non riesco a farlo accendere.
Ho problemi con l'ECU, e EWS.
Della BMW originale ho il motore con il cablaggio e i sensori, la centralina ECU, l'EWS con il blocchetto della chiave, la chiave, il quadro strumenti, e il pedale dell'acceleratore.
All'inizio sono riuscito a far accendere il motore, ma poi probabilmente spegnendolo in modo non corretto mi ha bloccato l'EWS.
Ora io cerco un modo per poter accendere il motore, preferirei eliminare definitivamente la parte della chiave e EWS.
Potete aiutarmi?
Grazie
rsrider is offline   Reply With Quote
Old 03-16-2017, 11:16 PM   #2
M Rated
My Ride: 540i/325i/330i/323iT
Try using the DanielF EWS delete 3.0 file
Find out more here -
https://forum.e46fanatics.com/showthread.php?t=1082287
M Rated is offline   Reply With Quote
