BMW brake rotor facts and deductions - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 04-20-2018, 11:00 AM   #41
HayWagon
My Ride: 03 325iT
Originally Posted by DropTop6 View Post
Is the Brembo big brake upgrade worthwhile or just get cross drilled rotors for all 4 corners. My driving is a bit spirited but I am looking to replace rotors and pads soon. 2004 330Ci convertible with sport package. Thanks for your advice.
A big brake is overkill for a non tracked car. The big benifit is being able to soak up more heat to avoid fade. Not something you have to worry about too much on the street. It won't reduce your stopping distance as your stock brakes can likely overpower the traction your tires can provide. If you were running aggressive rubber, then it may help to go to a brake with a larger friction surface. A big brake kit would also add to unsprung mass, and mess around with your brake bias.
Also no point in cross drilled rotors. They can be more prone to cracking.
Good pads, quality oem spec rotors, good fluid and enjoy.
Sent from my tractor.
HayWagon is offline   Reply With Quote
Old 04-20-2018, 12:19 PM   #42
Zimo32
My Ride: E46 325, E53, E63 M6
The type of brake rotor does little to absolutly nothing for brake performance. If you want more stopping power get a high performance brake pad. Drilled rotors WILL crack every time you track them if they get enough heat. The only reason you would get drilled rotors is for the "Look", not for performance.
When you beat your blank rotors up to the point they look like this from heat then you should upgrade to a bigger brake kit. If these were drilled they would be cracked all the way through instead of surface cracks from heat. And again this will only happen on the race track. I can tell you for experience that a higher performance brake pad will feel like you doubled or even tripled your braking power without doing anything to rotors or calipers.
Zimo32 is offline   Reply With Quote
Old 04-26-2018, 01:06 PM   #43
SaberLily
My Ride: E46 xi
Year: 2001
Model: 325xi
Transmission: MT
Zimo32, I second that. Big brakes should be for track when stock doesn't cut it.
A quality rotor will do the same as any other quality rotor. Cheap rotors, whole other story when they skimp on metal (less mass to absorb heat).
On a car with good condition brakes I've never encountered a situation where I've thought "I need more braking power".
Sent from my [device_name] using E46Fanatics mobile app
TEST DON'T GUESS! - South Main Auto Repair
SaberLily is offline   Reply With Quote
Old 04-28-2018, 10:37 AM   #44
DropTop6
My Ride: 330Ci Convertible
69 year old fart that loves his drop top
Thank you, Thank you, Think you. I have owned several 911's and this car is a peach. I think it may be my last hot rod. It is much more fun than the 911's, in a different way. Again I appreciate the response on the brakes.
DropTop6 is offline   Reply With Quote
Old 04-28-2018, 01:07 PM   #45
Solidjake
Shifting
Solidjake's Avatar
My Ride: 2013 328i 6MT
Btw for brake fluid get Castrol SRF... it's literally THE best fluid you can get. It's expensive but the benefits and feel is insane
Old 08-01-2019, 01:44 PM   #46
Fafa330
My Ride: BMW E46 330i
Hello, in relation to brakes, I need help on E46 330i front rotors, I need to replace mine but can't find any 330 ones in my area..is there any other model e.g X5 E53 maybe that uses same as ones on E46 330i front?
Sent from my SM-N950U using Tapatalk
Fafa330 is offline   Reply With Quote
Old 08-01-2019, 05:10 PM   #47
Alex323Ci
OE ///MEMBER PLUS
My Ride: M3 & 323Ci (sold)
I donít know about outside of USA, but hereís the part number and looks like Z4s also use it.
https://www.realoem.com/bmw/enUS/partxref?q=34116864047
http://photos.performanceIX.com/viewPhoto.php?PhId=95eeb7e241a6a9f6967c119c671778e6
Old 08-01-2019, 09:18 PM   #48
Fafa330
Thanks Alex, seems am still stuck haha Z4 is another rare car only seen one over here.
