Wire sleeve broken in engine/exposed wires. Is this a major issue to fix asap? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-13-2019, 10:58 AM   #1
peleke4
My Ride: 2003 bmw 330ci
Hello Everyone,
I have pictures attached to make this clearer.
There's this cable sleeve in the car engine that's broken and the wires are exposed. Just curious what those wires are for? Am I taking the risk of a major issue bound to happen if I keep those wires exposed? Will simple electric tape be enough to solve the issue? Or is it best to buy a new cable sleeve and fully cover the exposed wire? I appreciate any help on this
ID:	765827   Click image for larger version
ID:	765829   Click image for larger version
peleke4 is offline   Reply With Quote
Old 01-13-2019, 11:14 AM   #2
swordsman11868
My Ride: 2003 325i
Transmission: Autotragic
I used some electrical tape to cover the exposed areas and reinforce the plastic cover thatís still there.
I'm just here to change the world.
BMW Wiki:
Are you getting hot air no matter where you set your A/C in your E46? Check out this ancient thread! Chime in with your experience:
swordsman11868 is offline   Reply With Quote
Old 01-13-2019, 11:59 AM   #3
Col. Sanders
My Ride: 02 325it
Home Depot sells flex loom and maybe Harbor Freight, Buy a pack and just slide it over your existing harness and maybe tape the ends to give it that factory look
Col. Sanders is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-13-2019, 01:19 PM   #4
orb
My Ride: 340i | 325Ci
You can buy the loom from BMW
61136933301 is the part IIRC
orb is online now   Reply With Quote
Old 01-13-2019, 02:21 PM   #5
tcphoto
My Ride: E92 335 MT Coupe
Just pickup a 10' pack at an auto part or hardware store and replace it. You will also need zip ties to secure in place.
tcphoto is offline   Reply With Quote
Old 01-13-2019, 02:29 PM   #6
Archbid
My Ride: 330cic, 325i Touring
Year: 03
Model: 330cic
Transmission: 6-Speed, auto
3/8" Flame Retardant Polypropylene Split Wire Loom Tubing - 10 Feet - Black https://www.amazon.com/dp/B01MTR0AF1..._H95oCbDHFFKC0
If it split once it will split again. Get new loom and small zip ties.
Archbid is offline   Reply With Quote
Old 01-13-2019, 03:37 PM   #7
peleke4
Thanks for all the help. I plan to buy the tubing and just place it over the exposed parts. But I do want to tape it up to reinforce it. Does anyone have good suggestions for a tape that will hold up to the heat of the engine?
Old 01-13-2019, 04:44 PM   #8
LeverThis
My Ride: 2004 325i automagic
I was thinking about trying Tesa tape 51036 for this kind of thing:
https://www.amazon.com/Tesas-Advance.../dp/B01I2MLN2Q
Any thoughts on this?
LeverThis is offline   Reply With Quote
Old 01-13-2019, 04:58 PM   #9
tcphoto
You're overthinking it, replace the loom and spend a little time cleaning the engine compartment.
Old 01-13-2019, 07:40 PM   #10
Effduration
My Ride: '05 330CiC
+1 on this
Looks like the power steering reservoir could use a new o-ring in the cap
BMW Part # 32411128333
Effduration is online now   Reply With Quote
Old 01-13-2019, 10:53 PM   #11
DBecker
My Ride: e30,e34,z3,e39
That part of the harness is the connection on the front of the engine: the thermostat heater, exhaust VANOS solenoid and exhaust cam position sensor.
From the factory it was routed between the reservoir mounting lugs then above the thermostat, well protected from the mechanical fan. There was no wire tie, or any other cable retention.
Your best option for an original look is to cut away the degraded section, replace with split loom and cover tightly with a top-quality electrical tape. If you stretch it tightly the corrugation of the loom will show through, but not the seam cut or join section.
A full original look would require releasing the contacts from the connectors and feeding the individual wires through a closed loom, but you are unlikely to be able to do that successfully.
DBecker is online now   Reply With Quote
Old 01-13-2019, 11:34 PM   #12
Megalocnus
My Ride: 05 330i ZHP/MT
+1.
Some time ago I bought a wire harness just to try if there is a way to replace a branch of the loom. It cannot be done without disassembling and reassembling the electric plugs of all wires inside the branch.
Megalocnus is offline   Reply With Quote
Old 01-14-2019, 12:15 AM   #13
jmo69
My Ride: 03 325xi 98 328is
Sometimes just flipping the O-ring helps and putting the end of a cotton swab in the vent hole helps.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
jmo69 is offline   Reply With Quote
Old 01-14-2019, 01:07 PM   #14
Archbid
Year: 03
Model: 330cic
Tesa tape is super, and I use it to keep looms clean behind panels. But here it is absolutely not necessary. Just use the loom and cable ties and move to the next project.
Old 01-14-2019, 02:15 PM   #15
peleke4
Originally Posted by Effduration View Post
+1 on this
Thanks I'm going to buy that part. And by the way, it appears that a lot leaked out as you can see in the picture. Is it okay to get by with the amount that's still in there?
Old 01-14-2019, 02:19 PM   #16
peleke4
And by the way, the local BMW is charging $13 for that o-ring (BMW Part # 32411128333)
I could probably find it much cheaper on Ebay or something
Old 01-14-2019, 02:59 PM   #17
Archbid
Year: 03
Model: 330cic
Level indicator is built into the cap, just keep it above minimum.
Old 01-14-2019, 03:59 PM   #18
peleke4
Thanks for the head's up. I checked and turns out the fluid is low. Is there a specific type of ATF to use? Could I use the following (picture attached). If you advise not to use the Castrol I have, what brand do you recommend?
Old 01-14-2019, 04:10 PM   #19
Archbid
Year: 03
Model: 330cic
Needs to be dexron iii atf
Old 01-14-2019, 04:34 PM   #20
fanatichuman
My Ride: 2001 e46 330xi
1.47$ at fcp
Sent from my MI 5 using E46Fanatics mobile app
fanatichuman is offline   Reply With Quote
