Advice for Cooling shroud and Clutch fan install - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 10-14-2018, 05:23 PM   #1
red73mustang
My Ride: 2002 E46 325xi Sedan
Doing the water pump, thermostat housing and radiator hoses and I just destroyed my cooling fan shroud trying to force it in between the radiator and clutch fan. Tried to thread the fan on while the shroud was in place but could not get it started. What's the secret to getting this back together?
Thanks, Chet
red73mustang is offline   Reply With Quote
Old 10-14-2018, 10:28 PM   #2
Bidno
My Ride: 2002 325i
Lower the shroud with the fan inside catching lower and side clips on the radiator. And then thread the fan remembering it's reverse threaded. Just thread it snug; if you overtighten you'll regret it next time. Generally I'Ve had to get underneath to verify the shroud caught bottom clips and side locators. Seems easy to mis-locate
Don't spend much on fan parts without considering converting to puller fan used with manual transmissions (search here for "fan mod"). This replaces two current fans plus shroud with single electric fan plus shround - and is a snap to remove and install. GL
Bidno is offline   Reply With Quote
Old 08-14-2019, 12:34 AM   #3
Steven003
Just thread it snug; if you overtighten you'll regret it next time. Generally I'Ve had to get underneath to verify the shroud caught bottom clips and side locators. krogerfeedback _sl_
Steven003 is offline   Reply With Quote
