Brake flexi stuck in caliper - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old Yesterday, 12:23 PM   #1
Chrisbish2000
Im currently replacing the rear brake lines on my coupe so i'm doing the flexi pipes aswell. Of course the hard line nut was rusted into the flexi (Wish it came off as easy as It does in those YouTube videos) I ended up just cutting the hard line off still in the flexi as I'm replacing both anyway. As some may know the rear brake flexi pipe also screws into the caliper and needs to be removed to be replaced.
My flexi is stuck in the caliper on both rears and it will not screw out. I've tried penetrant and heat but it can't get in there very well, convinced it's glued in. Anyone had this problem? Im not really looking for advice lol I just want to tell someone haha. I've been looking up new calipers all day as I've been here for 6 hours trying to remove it and had enough.
I was looking forward to doing the job in one day but every single job I do I spend 90% of it trying to remove something that's stuck.
Chrisbish2000 is offline   Reply With Quote
Old Yesterday, 01:04 PM   #2
RRRM8E
My Ride: 330Ci
I have got them off other BMWs by cutting the rubber hose at the fitting and using a socket. PB Blaster is your friend.
Try Rockauto for rebuilt calipers at good prices.
RRRM8E is offline   Reply With Quote
Old Yesterday, 01:19 PM   #3
Spannerhead
My Ride: '02 330i/5 slicktop
Is the nut rounded or intact? That will affect your approach. And yes, PB Blaster is the best. Brush off as much rust as you can before you apply the penetrant, and always make sure you use flare nut wrenches.
Current:
Past BMWs:
Past Other: '85 GSL-SE '88 JZA70 '86 4K quattro '85 RX-7 S '85 RX-7 GSL
Spannerhead is offline   Reply With Quote
Sponsored Links
Advertisement
Old Yesterday, 01:51 PM   #4
Chrisbish2000
Oh the hard line nut was rust welded into the flexi. Hence why I'm replacing the flexi. I cut the metal brake line above the nut and put a 6 point socket over it which should be better than a flare wrench but no, would not move and rounded with the force and crumbling rust. I've been putting penetrant on it for a week leading up to this. I burned it with fire also. Nothing. They have become one lol.
I might try cutting the flexi and using the socket. That's an idea thanks.
