Final stage unit ventilator - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old Yesterday, 08:16 AM   #1
crocs
Hey there, can anyone tell me the purpose of this part. What exactly it controlls besides a/c blower?
crocs is offline   Reply With Quote
Old Yesterday, 08:30 AM   #2
bendoscopy
My Ride: 330Ci M + 320Ci
Transmission: 5MT
Really not much else. From Pelican Parts:
The blower motor resistor (or final stage) varies voltage to the blower motor to achieve the desired airflow speed. It receives the driver demand signal from the HVAC control panel and sends a high current signal to control blower motor speed. The blower final stage unit can fail resulting in a malfunctioning or inoperative blower motor. The final stage unit is a high failure item on the BMW E46 and other BMW models as well.
BMW E46 330Ci M-Sport 2001 topasblau/grau 110k miles
BMW E46 320Ci Sport 2002 topasblau/hellbeige 125k miles
| drive tastefully
bendoscopy is offline   Reply With Quote
Old Yesterday, 09:43 AM   #3
MrMCar
My Ride: E30M3 Track Car
A very good question indeed.
The final stage resistor was first used (IIRC) on German cars on the MB 126 chassis. It was a large unit located inside the heater-A/C plenum and about the size of a 1/2 a carton of cigarettes. (Fags for our British brethren)
Rather that use the old school method of using a resistor pack with 3 different resistors for low, med-low, medium (high was a by pass and direct batt. voltage to the blower motor, giving you 4 speeds in total) they sought to give infinitely variable blower motor speeds.
This nessicated the use of transistors inside a housing. The unit produces a good deal of heat especially on the lower blower speed settings, so they needed a way to shed the heat out of the pack by placing it into the airstream of the heater-A/C plenum.
Over the years almost every one of these (regardless of car manufacturer) has undergone revisions to the internals, size/composition of the base and potting material and the revision of the number and length of the heat sinks. (the comb things)
IIRC the latest version for the E46 has 39 heat sink rods.
It's extremely important to FULLY install these when replacing. The idea is to get as much air as possible over the heat sink rods so the unit does not overheat and fail prematurely.
Don Fields
////MrMCar
www.mrmcar.com
MrMCar is offline   Reply With Quote
Sponsored Links
Advertisement
Old Yesterday, 12:36 PM   #4
crocs
Thanks guys, so it has nothing to do with valve actuators? i think theres 5.
3 of the actuators doesnt open the valve, so my guess is its the motor itself , right?
Old Yesterday, 07:33 PM   #5
Sapote
My Ride: 2000 323i auto wagon
control the fan speed and a meat tender is its after life.
Sapote is offline   Reply With Quote
Old Yesterday, 07:41 PM   #6
Sapote
It doesn't have to be like this and generates lots of heat. It can be designed to control fan motor speed and still stays cool as a cucumber. Imagine how big the hedgehog in the Tesla electric motor if using this design!!!! BMW could use PWM motor control method and there is just a fraction of transistor heat to cool. In fact 99% of electric motor drivers use PWM drive.
