325ci: Gear Box Oil Capacity - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-15-2020, 09:21 PM   #1
325ciLover
My Ride: 2004 325ci
Can't seem to find the exact capacity for my 2004 5 speed manual transmission. I have one brand new quart and about 1/2 of another.
Sent from my ONEPLUS A6000 using Tapatalk
325ciLover is offline   Reply With Quote
Old 01-15-2020, 09:27 PM   #2
Newbimer
My Ride: 2005 325i
Not sure about yours but most of them are filled the same way as the trany...fill until it starts to run out and its full I think its around 2 liters, but I could be wrong.
Newbimer is offline   Reply With Quote
Old 01-15-2020, 09:29 PM   #3
325ciLover
My Ride: 2004 325ci
By gear box, I mean the transmission.
Sponsored Links
Advertisement
Old 01-15-2020, 09:42 PM   #4
Newbimer
My Ride: 2005 325i
My Mistake. The trany takes 11 liters if its completely empty (i.e. new or rebuilt). If you are just doing a change gasket/filter it most likely will take around 6L. If you are not flushing it out to replace most of the old dirty fluid with new before refilling. If you want to replace as much of the old as you can it could be 10 or more Liters, depending how dirty the fluid is. When I did mine it took 22L to get it running clean, and another 6 to fill it. YMMV. Search this site to find the flushing and filling procedure. Make sure you read all the cautions about this procedure, before you use it!
Old 01-15-2020, 09:44 PM   #5
325ciLover
My Ride: 2004 325ci
I think you're referring to an automatic transmission.
Old 01-15-2020, 09:47 PM   #6
Brewtus79
My Ride: M3 Vert, 330xi, X5
Year: 2002
Model: M3, 330xi, F15 X5
Transmission: 6 spd manuals
2 liters will do it. It probably takes less, but not sure how much less so dont know where the 1 and 1/2 quarts will leave you.
Sent from my SM-G950U using Tapatalk
Brewtus79 is online now   Reply With Quote
Old 01-15-2020, 09:49 PM   #7
325ciLover
My Ride: 2004 325ci
Yea that's my fear. According to my records I used 1.4 quarts back in 2017 when j first bought the car. But would be shitty to be just an eek shy.
Old 01-15-2020, 09:52 PM   #8
Brewtus79
Year: 2002
You ought to be good then. Is what you have left in the partial what remains from the last time you changed it?
Old 01-15-2020, 10:01 PM   #9
325ciLover
My Ride: 2004 325ci
Yep. Bought her in 2017 with 135,000 miles. I changed the gear oil immediately and had some left over. Remaining 2nd quart is at my dad's so can't tell how much I have for sure. But my records say I used 1.4 quarts which leaves over 1.5 quarts.
Old 01-15-2020, 10:25 PM   #10
Brewtus79
Year: 2002
Sounds like you have your answer.
Old 01-15-2020, 10:58 PM   #11
325ciLover
My Ride: 2004 325ci
I've contemplated trying 50% D4 redline atf and 50% redline MTL. Anyone else try this?
Old Yesterday, 07:15 AM   #12
markusmarkus
My Ride: 2018 M240i
What state do you live in? If itís Minnesota then straight D4ATF is the way to go.
Old Yesterday, 07:23 AM   #13
malapane
My Ride: E46 M3 & F30 320 ZSP
I will be doing this soon.
I just did it on my other manual. I have the remainder of the second quart still and I can verify this evening, but I am pretty sure you can just finish 2 drain and fills with 3 quarts on the 5 speed.
I also will be doing half MTL and half D4 ATF. I live with cold winters, but won't be driving this one so much in the winter. I used straight MTL in my other one with 169k miles. It has been driven fairly hard and I wanted the extra protection for my daughter who is just learning to drive and is pretty hard on the synchros. I haven't noticed the MTL to be too heavy.
I am more gentle with mine, but like a little extra protection since mine isn't low mileage either with 148k.
malapane is offline   Reply With Quote
Old Yesterday, 07:27 AM   #14
Antti
My Ride: 330CI / 316 1.8i
Year: 2005
Model: 330CI M-Sport II
Transmission: Automatic
My recommendation with experience of different gear oil types.
Buy that OEM gearbox oil from BMW dealer.
For example, my car had that yellow sticker. I took photo of it and went for BMW.
They sold me correct amount oil ready in bottle. Price was approx 30$.
It is perfect. Smooth gear changes, no matter how cold we have. -35c, it is fine.
BMW E46 330CI M-Sport II 2005 Individual Black Sapphire metallic /Showroom
BMW E46 316 1.8i Sport 2005 Mysticblau metallic /Showroom
Renault Clio RS197 2007 Ultra Red
Antti is offline   Reply With Quote
Old Yesterday, 10:55 AM   #15
RRRM8E
My Ride: 330Ci
Did you consult the Owner's manual?
RRRM8E is offline   Reply With Quote
Old Yesterday, 06:47 PM   #16
jdstrickland
My Ride: '94 325iC & '00 323i
I'm not sure how much it takes, but the rule of thumb is to fill it through the fill hole until the oil comes out. My '94 325 5 spd takes 1.22 qts. I can't imagine your car taking very much more. You should have a puddle forming on the floor at about the same time as you get done pouring in the partial bottle. I think I would do the full quart first, then top it up with the partial quart.
Old Yesterday, 06:53 PM   #17
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
The Bentley manual states the Getrag 5-speed takes 1.1 quarts and the ZF 5-speed takes 1.3 quarts.
Old Today, 12:15 AM   #18
Antti
Year: 2005
I think my small block 316i manual box took approx 1,1 litres.
