Warbling noise coming from transmission? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-14-2008, 09:49 AM   #1
frogg320
My Ride: 2000 323i
This appears to happen only in second gear while engine braking, which is why I'm assuming it's a transmission noise. When the RPM's drop below about 2000, it starts with a quick, high pitched warbling noise...my girlfriend compared it to the sound the cars made on the Jetsons. As the car continues to engine brake it slows down and the tone gets deeper, sort of a pulsing groan.
I just changed the transmission fluid. Second appears to be the only gear it happens in, and I can only get it to do it under the conditions mentioned above. So here's my question:
Does anyone have any idea what the hell is wrong with my car?
Thanks.
-J
frogg320 is offline   Reply With Quote
Old 01-14-2008, 09:58 AM   #2
frogg320
My Ride: 2000 323i
(post revised)
Old 01-14-2008, 08:29 PM   #3
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
The noise you are refering to is transmission whine. Do you have an Auto or Manual?
Edit: Nevermind I just realized you mentioned engine braking so you must have a 5 speed, anyways the whine could be a faulty bearing, synchro or even low on fluid (Although I know you said you changed he fluid already)
Jared
Check out my Other DIY's
Ivegotissues666 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-15-2008, 12:39 AM   #4
frogg320
My Ride: 2000 323i
Well, I drained out 28 ounces of old fluid (WAY low), and it didn't whine before...but as they say in the Grapes of Wrath, extra crap in your transmission can make it smoother, so maybe the gunk was hiding the problem before.
How would I diagnose it if it's a bad syncro or bearing? (Keep in mind, it's shifting even better now after the fluid change...and there's no way it's low, it was still overflowing when I plugged it back up)
Also, is the whine bad for the transmission? So far I've been driving in such a way as to avoid making the noise. Do I need to worry about it?
-J
Old 01-15-2008, 07:36 PM   #5
Ivegotissues666
-J
No real way than to open up the transmission to tell for absolute sure, however I find it odd it happened right after the fluid change (What fluid did you use) It could possibly be the fluid.
Low on fluid was probably because you do lose some out of th brether cap the transmission has. How was the rear and front seals as well as the linkage seal they are prone to fatigue and leak as well.
Try changing to a different fluid and see if the problem persists. But in all honesty my transmission does the same exact thing in second gear only since I did the transmission swap and I have been driving for over a year like that with no issues getting in and out of gear and it doesn't whine all the time either.
Also another thing is that the Getrag trannies are supposedly noisy, however I haven't driven many others to compare so I can't confirm that unfortuantely.
Jared
Old 01-15-2008, 07:42 PM   #6
frogg320
My Ride: 2000 323i
I'm using Redline MTL, which lots of people swear by. I think my rear seal is bad, which is causing the leak...but I'm going to see if I can get away with not fixing it until the weather warms up.
This noise definitely started when I changed fluids...but I don't think I have a better one to use. Unless I should pour some of the old stuff back in?
Old 01-15-2008, 07:45 PM   #7
Ivegotissues666
I use royal purple synchromax so thats another option or buy a quart of the OEM BMW stuff
Old 01-16-2008, 12:54 AM   #8
frogg320
My Ride: 2000 323i
Easier said than done. They don't sell the OEM stuff in quarts, just 5 liter buckets. And from what I hear, it costs an arm and a leg. BMW dealerships...
They did offer to fill it up for me if I bring it in, though. Generous lot, they are!
Old 01-17-2008, 08:47 PM   #9
oc330cic
My Ride: 2002 330 CiC
The BMW transmission fluid us now available by the quart. Ask your dealer again. And if they won't sell it to you, BavAuto.com will. I know I saw it in their most recent catalog.
Mind you, I don't think that will solve your noise problem. Since you said it was way low on fluid, probably something in the tranny is on it's way out.
oc330cic is offline   Reply With Quote
Old 12-09-2019, 03:37 PM   #10
323ci99
My Ride: E46 323ci
Thanks.
-J
Hi,
I'm sorry for resurrecting such an old thread, but I'm having these exact same symptoms on my '99 E46 323ci.
Can you please tell me what the probLem really was and how you've solved it?
Thanks in advance!
323ci99 is offline   Reply With Quote
