Convertible "Cap" or Cover Gets Stuck - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 06-17-2014, 01:09 AM   #1
mayor111
My Ride: 2003 BMW 330Ci Convt
Question Convertible "Cap" or Cover Gets Stuck
Hey Guys,
I'm not sure what this is called (see picture #1) but it gets stuck in the downward position every time I put my top down (see picture #2). There are two of these, one on each side of the Top, pretty much aligned with the rear seats.
Do I need to grease it so it goes back up? The other side doesn't have the issue... Is something broke that holds that into position when the top is down? The only way I get it to go up is to manually push it up.
Picture #1 (what is this?)
Picture #2 (gets stuck in this position when the top is down)
Thanks,
Mayor111
03 330Ci Convt_a_
mayor111 is offline   Reply With Quote
Old 06-17-2014, 01:36 PM   #2
pukhkan
My Ride: 330ci Vert
theres a spring underneath that retracts it into closed position, that's possibly broken/unhooked
pukhkan is offline   Reply With Quote
Old 06-17-2014, 02:07 PM   #3
taylor192
My Ride: 2003.5 M3
There is a spring that pulls the cover back into position.
Old 06-17-2014, 07:35 PM   #4
SilberVogel
My Ride: 2002 330Ci Conv.
As mentioned above, you're missing the spring. Here's a thread that may help you better visualize what's going on: https://forum.e46fanatics.com/showthread.php?t=1020015
DIYs help you save money with repairs; let
help you save money with the parts.
SilberVogel is offline   Reply With Quote
Old 06-21-2014, 01:32 PM   #5
mayor111
Lightbulb
UPDATE:
I just got back from my BMW Dealership - they had the parts in stock and I wanted to post pictures (of the part #s too) so that way you all have the right information. I have seen a ton of posts on this but I didn't see anyone post pictures of the parts and the part #s - so here is what you need to fix the Convertible Covers if the rod or spring breaks (doesn't matter if you need the left of the right - only the cover itself is side specific):
Total Cost: $10.50
Plastic Rod:
Spring:
Everything installed:
This literally took me 10 min to install - and I have zero "mechanic" skills.
Thanks!
Mayor111
03 BMW 330Ci Convertible
Old 06-25-2014, 10:15 AM   #6
MVaughan77
My Ride: 2001 325Ci
I would like to know what the cover piece is called because the drivers side one is missing. Good post though because I will be needing the rods and springs also.
2014 Ford F150 XLT SCrew 5.0L 4x4
2011 Jeep Grand Cherokee Limited 5.7L
2001 BMW 325Ci Convertible 2.5L
MVaughan77 is offline   Reply With Quote
Old 06-25-2014, 11:35 AM   #7
mayor111
The official name is: Hinged Convertible Cover
They offer it for LEFT or RIGHT and in 3 colors - you said you need the Driver side - so here you go (Part #'s are from BAVAUTO.com):
Hinged Convertible Cover - Left - Beige
Part # : 51 43 7 022 397
Hinged Convertible Cover - Left - Black
Part # : 51 43 7 022 393
Hinged Convertible Cover - Left - Grey
Part # : 51 43 7 022 395
Old 06-25-2014, 11:44 AM   #8
MVaughan77
My Ride: 2001 325Ci
Great! Thank you! I ordered the rods, springs, and the covers just a moment ago. All the little things add up when trying to make a car look new!
Old 06-25-2014, 12:36 PM   #9
fmzip
My Ride: '08 328xi / '15 S4
There are two different caps depending on modal year. The ones called out above are for model years up to 9/2003 just in case somebody else stumbles across this thread
http://www.realoem.com/bmw/showparts...1&fg=50&hl=174
fmzip is offline   Reply With Quote
Old 05-20-2015, 10:09 PM   #10
ThePitts
My Ride: 2001 325Ci
Both of my covers are missing and I'm not sure exactly which parts I need to order.
Looking at the diagram, obviously I need the two covers plus the springs and push rods.
However, there's also a few other parts noted in that area: cam followers (41437147719 and 20), and a sleeve (41437147717). Will I need these as well? if so, will it be obvious how all these go together?
I checked prices on ECS and they came to around $104. If I don't need the cam followers and sleeves, I can save about $35.
Thanks for your advice.
ThePitts is offline   Reply With Quote
Old 06-12-2015, 06:26 AM   #11
leonardo_
My Ride: 323CI Cabrio
Thanks for this, just made my day!!!
leonardo_ is offline   Reply With Quote
Old 06-19-2015, 10:54 AM   #12
Phoenix330ci
My Ride: 04 330Ci Convertible
Exactly. My 04 uses a different set up. The spring iis on the rod. Also BMW beefed the rod up on the new part.
If I get a chance in the next day I'll post a pick of old vs. new.
Phoenix330ci is offline   Reply With Quote
Old 06-21-2015, 06:24 PM   #13
E46-Cabrio
My Ride: E46 330CI Cabrio
YES, please take some pics how the rod is connected to the chassis, stil can't figure it out, only the older models are easy.
Thanks.
E46-Cabrio is offline   Reply With Quote
Old 06-22-2015, 07:53 PM   #14
audiavant
My Ride: '02 325ci
I would also be sure to lube the sh*t out of the tabs that are in the grooves.........'specially if U are still running original parts.....jm2c ' - ))
audiavant is offline   Reply With Quote
Old 06-25-2015, 08:34 PM   #15
CharlieFoxtrot
My Ride: 02 330Ci
Year: 2002
Model: 330Ci
Transmission: automatic
I thought one of my covers was missing, until I went to install the new one and found the spring was off and the cover had just fallen into the top-up position and stayed there.
YMMV
CharlieFoxtrot is offline   Reply With Quote
Old 07-24-2015, 08:21 PM   #16
bbp1
My Ride: 2003 M3 Vert
Thank you for this. Picked up parts today. Install was a breeze with your picture.
bbp1 is offline   Reply With Quote
Old 07-27-2015, 06:11 PM   #17
Dsch555
My Ride: 2004 330ci Cabriolet
Guys, thanks for this post. I have an '04, 330 and need to find out how to remove the "cover" to put in a new one. The little tab that the spring/rod combo hooks onto broke off and I have nothing left to attach the spring to. (I even tried to drill a hole in the small amount of the tab that was left and it snapped off too.) Does the cover just slide out or snap out of place? I don't want to damage the tracks or the "lateral trim panel" itself...
Dsch555 is offline   Reply With Quote
Old 07-27-2015, 06:16 PM   #18
audiavant
My Ride: '02 325ci
U can just gently spread the opening to remove the small panel. The remaining piece of tab broke too, but i was able to drill a small hole in the side piece that the tab was attached to. (Hope that makes sense ; - ))
Old 01-30-2019, 04:57 PM   #19
dannybjax
I feel stupid here but I bought these springs and plastic rods any mine seem to be way to short. That is, when I attach one end to the little hole in the tab on the cover and begin to pull it bends and pops out before I can connect the other end. What am I doing wrong?
dannybjax is offline   Reply With Quote
Old 01-30-2019, 07:57 PM   #20
All2kool
My Ride: 2002 325Ci
When attached to the cover, the spring should come up about 2" short from reaching the corresponding hole in the top mechanism. If your distance is greater than that, your spring is too short. Trying to make it work will result in the cover breaking where the spring attaches but I have a great solution for that. Let me know and I can re-post the fix should you need it.
Previous:
All2kool is offline   Reply With Quote
