330ci M54 build - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Australia
Old 09-28-2015, 07:11 AM   #1
Davew
My Ride: 2004 330ci Msport
330ci M54 build
I have copied below from my thread in the FI section of the forum:
List of mods:
Stage 3 ported Technik head, 1mm Ferea oversize valves, double valve springs, titanium retainers, etc.
248/256 schrick cams
Raceware head stud kit
New hydraulic cam followers
M3 chain tensioner
New cam sprockets, chains, guides, etc. Chain are iwis race grade chains.
ATI super balancer
ESS TS2+ (Non ESS MS43 tune and setup)
S54 headers, modded with 2.5 collectors, Y piece into single 3 inch, two un-baffled mufflers. All 304 stainless steel
Besian vanos seals
Reservoir for liquid intercooler
Samco radiator hoses
Samco intake boot
BMW performance brake rotors
Zionsville competition radiator kit
Zionsville billet thermostat housing
80 degree Celsius mechanical thermostat
EMP Stewart water pump
Custom 65mm supercharger pulley
Turner sways front and rear
Turner urethane engine and trans mounts
Bilstein ride control coil overs
Custom in bumper cold air intake (K&N 6x9 inch filter)
UUC Twin Disc Clutch and Flywheel Package
SSG to 6 Speed Manual gearbox conversion
2.93 to 3.15 diff ratio change
OS Giken LSD
Subframe reinforcement
Solid Subframe bushes
Modified diff carrier (twin mount at rear of diff)
Bosch 42lb injectors
Aeromotive 340lph fuel pump
Remote pcv valve and catch can
BBS RSGT wheels
Now that I know I can and have tuned the car, it is time to build the bottom end, and some other mods I will reveal as they progress
An order has been finalised, but with a 4-5 week delivery time for the following:
Arrow precision connecting rods
JE forged Pistons (8.5 compression ratio)
Main and rod bearings
MLS head gasket
The crank has been sent out for lightening, knife edging, and journal linish (journals on crank are immaculate now), and balanced.
The block is at my work, I am making a full main caps to block girdle, and side plates for the block. Once the girdle is fitted, the block will be bored and honed, and the main bearing journals line bored. Head and block deck will have a light cut to ensure flatness.
As long as delivery times quoted are accurate, should be swapping out the engine in 6 weeks time
I will then get the car running with close to the current setup to run in, but with a new aftermarket MAF, and then there should be some new toys to show and tell
Davew is offline   Reply With Quote
Old 09-28-2015, 07:35 AM   #2
cosmos328Ci
My Ride: 400+whp. 500.4ftlb
Transmission: 5 Speed Manual
List of mods:
M3 chain tensioner
ATI super balancer
Besian vanos seals
Samco intake boot
OS Giken LSD
MLS head gasket
Sounds awesome.
Can't wait for the dyno.
Good luck and hope all your parts arrive on time.
M54B30, ESS TS2 Manifold, 4" Throttle Body, 108mm pulley - 4.25".
cosmos328Ci is offline   Reply With Quote
Old 09-28-2015, 07:54 AM   #3
Davew
Not concerned with the end power figure, I'm happy with the output now, but would like to strengthen and refine the engine. Staying with pump fuel, but will likely spray some water/meth to keep temps down and timing up
Sponsored Links
Advertisement
Old 09-28-2015, 08:00 AM   #4
cosmos328Ci
Nice, what power output are you at now?
Sounds like it will be rock solid by the time it is completed.
Old 09-28-2015, 08:20 AM   #5
Rajvosa
My Ride: 1M
Great build!
Rajvosa is offline   Reply With Quote
Old 09-28-2015, 08:29 AM   #6
Davew
Not entirely sure, last tuning session I had spark breakdown, dsc kept faulting, and I had no gear recognition (from ssg- manual conversion). I would say based on last best run, plus all issues are now sorted, it would have to be up between 270-280rwkw, 650rwnm, but this is just a vague guess. Maybe zha50 can add some independent comment, he is the only other person who has been in the car at its various stages. AFR's and ignition are in a good range at the moment, so I don't have a reason to spend time on the dyno before making changes.
Old 09-28-2015, 08:32 AM   #7
Davew
Originally Posted by Rajvosa View Post
Great build!
Thanks Rajvosa
Old 09-28-2015, 08:47 AM   #8
david4134
My Ride: BMW e46 325ci sport
nice
david4134 is offline   Reply With Quote
Old 09-28-2015, 09:02 AM   #9
KendrickC
My Ride: '03 325i
Year: 2003
Model: 325i
Transmission: 6MT
Yay!
'03 325 6MT Estoril Blue
KendrickC is offline   Reply With Quote
Old 09-28-2015, 09:29 AM   #10
Davew
What the car looks like currently
Old 09-28-2015, 11:01 AM   #11
cosmos328Ci
Nice work.
All the best with the build.
Old 09-28-2015, 03:31 PM   #12
Davconelectric
My Ride: 2 dog powered sled
Awesome Dave. Sounds like it's gonna be a full track engine
Davconelectric is offline   Reply With Quote
Old 09-28-2015, 04:09 PM   #13
Davew
Thanks Davcon, very similar set up to yours, just different rods, crank work (and girdle), and lower compression. Trying to get the engine to spin up quicker, to a higher rpm, and more boost
Old 09-28-2015, 05:56 PM   #14
cosmos328Ci
Hey Davew,
Will you increase the size of your injectors?
What is your injector duty cycle at peak power and WOT?
Cheers
Old 09-28-2015, 06:13 PM   #15
Davew
Bigger injectors are part of the end plan, will have to get back to you on injector duty cycle at WOT, with the Walbro 240 they were virtually maxed out with the 65mm pulley, but the aeromotive 340 has given me a touch of head room, but not enough
Old 09-28-2015, 07:29 PM   #16
cosmos328Ci
Kool.
I did some calculations and those 42's came up a bit short to be at 80% duty cycle, which is why I asked.
You gona stick with Bosch or go with ID's?
Old 09-28-2015, 07:55 PM   #17
zha50
My Ride: '04 325ci 5MT
Overall lots of small things associated with extra boost, such as the failing Bosch spark plugs was holding the top end back.
The biggest leap forward was getting the DME software to run properly as a manual and that changed the entire behavior of the car. The top end returned due to additional timing, but the overall drive ability of the car improved ten-folds. I'm sure Dave would agree.
The numbers on the TS doesn't quite reflect its character, the torque builds so early that you don't really feel like you have hit the 270+kw(as you don't get as sharp transient in the power curve) yet speedo says otherwise
Very interested to see the future of this motor Dave!
'04 325ci M-sport 5MT
- Bone stock -
zha50 is offline   Reply With Quote
Old 09-28-2015, 08:44 PM   #18
Jimmy_46
My Ride: bmw e46 m3
one crazy 330 and ill get to drive it, suck sh1t everyone
Jimmy_46 is offline   Reply With Quote
Old 09-28-2015, 09:03 PM   #19
cosmos328Ci
Thanks for the added info, sounds like a ball terra when the little problems are resolved.
LOL.
Old 09-28-2015, 10:00 PM   #20
Davconelectric
Haha
