New E46 Sunroof Repair DIY - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 04-01-2006, 11:58 PM   #21
Marknoir
My Ride: 2004 325iT
Sunshade
Great DIY
I tried to fix it today. Removing glass was easy, as was replacing clips and installing shade back. My problem is that shade "driver" is bent up somewhat and just slides over the rear clip. I don't know how to bend it down. M
Marknoir is offline   Reply With Quote
Old 04-03-2006, 01:08 PM   #22
sandy44
My Ride: 2001 330xi
Thanks 'lincomatic' for the great write up and all the pics. Really made my job easy this weekend, when I replaced the clips. However I have a question regarding the glass adjustment.
After installing the glass and everything, the sunroof and the shade open up nicely without any hitch, but when I try to close the sun-roof it travels forward about 80% , stops and then retracts to about 50% and stops.
I strongly suspect that this problem is related to the glass adjustment. I think that the rear end of the glass is too high. Can you please provide any quick fix to this ??
Thanks !!
sandy44 is offline   Reply With Quote
Old 04-03-2006, 01:29 PM   #23
Canuck328i
My Ride: 09 Altima Cpe
Thanks !!
Bump...
Mine does this too, basically started doing it on its own - tried the "reset" procedure (holding in the button) and it didn't fix it. Can anyone help us out?
Mark
Canuck328i is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-03-2006, 01:53 PM   #24
luckysnafu
My Ride: F30 328|90 332(s52)
I have the same problem as you guys after fixing my sunroof as well. I would try to reset the motor first and then clean the tracks and lubricate. I haven't tried any of these yet but I will try to reset my motor after work today and see if it helps any.
Check out this thread here - https://forum.e46fanatics.com/showthr...hlight=sunroof
and this one - https://forum.e46fanatics.com/showthr...hlight=sunroof
- I was told by the dealer that whenever this happens, all you have to is "reset" the moonroof by pushing and holding for at least 10 secs, the button towards the CLOSE position.
I guess that clears the sunroof "memory."
- Mine has been working for over a year since the dealer first diagnosed the problem as a bad sunroof motor and wanted $350 parts and labor for the R&R. It still does that same funky behavior every month or so, but all I do is reinitialize the motor using the technique described by interalejo. You don't hold the button forward (towards the front of the car), or backward, but instead push and hold it straight up. Mine takes 20 sec. to initialize, and when it does, you can hear a quick 'buzz-buzz'. Problem solved - kinda.
luckysnafu is offline   Reply With Quote
Old 04-03-2006, 04:57 PM   #25
sandy44
My Ride: 2001 330xi
I tried to re-initialize too, Does that buzz-buzz , but the problem still remains. Next I am gonna try to allign the glass again + re-initialize. And my last resort would be to WD40 the tracks. Would post my results soon !!
Old 04-03-2006, 09:37 PM   #26
luckysnafu
I too tried to reinitialize the motor but it didn't make a difference. I will wait to see if adjusting the glass helps sandy44 before adjusting mine.
Old 04-04-2006, 08:17 AM   #27
Canuck328i
The reset didn't work for me either - I'll try again though.
It seems like a safety thing, like it gets to a point then senses an obstruction so it backs up. Maybe it's some type of positioning switch in the motor that is malfunctioning.
Oh, one other thing - the shade is fairly stiff to slide across (especially when compared to my wife's 328). I wonder if this is simply a lubrication issue, and the motor is reversing as a safety measure because it thinks there is something in its way...
Mark
Old 04-04-2006, 09:27 PM   #28
Canuck328i
Worked on this problem today. The motor reverses at the instant it tries to slide the shade forward - this originally seemed like an "intermittent" problem, but in reality it was because the shade was already forward a bit on those times when it worked.
Short story is I removed the glass and lubed everything up - used Fluid Film on all moving parts, including the shade "catch" bracket on the driver's side. Now everything slides nice and smooth, and no bounce-back problem with the sunshade.
Mark
Old 04-05-2006, 03:08 PM   #29
luckysnafu
^ Sweet, thanks for the info man. I will be taking mine apart this weekend to clean the rails and lube everything.
Old 04-06-2006, 10:58 AM   #30
sandy44
My Ride: 2001 330xi
After an hour of re-adjusting the glass and all, guess what !!! No Luck. I'll also try lubricating the moving parts and all. Hope that works .. Thanks for the update guys !!
Old 04-17-2006, 07:48 PM   #31
go330ci
Help!!!
I tired to fix the sunroof & I had a problem which no people had ever mentioned. I couldn't move the sunshade driver all the way forward as there's a long piece of metal inside the sunshade driver track (circled in green). Anybody know what's that. Thanks in advance for any input.
go330ci is offline   Reply With Quote
Old 04-17-2006, 11:52 PM   #32
SilverStreakTeg
My Ride: 2006 325ci
Does this happen in the newer e46's or did they more or less fix that problem, this whole write up kinda is scaring me as to what to find down the line?
Sponsored by: DetailedImage.com
SilverStreakTeg is offline   Reply With Quote
Old 04-18-2006, 10:52 AM   #33
manydubs
My Ride: 1995 BMW M3 Coupe
I did this a couple weeks ago and it was an easy DIY. However, my driver was completely broken off ans laying behind the rail area.
I removed and the sunroof shade still pushes back from the sunroof itself. It slide really smooth now.
manydubs is offline   Reply With Quote
Old 05-02-2006, 07:46 PM   #34
Milla
My Ride: Too many to list
wow, amazing. and when I went to the dealer he said they needed to pull down the WHOLE inside roof.
[ 1997 TECHNO VIOLET M3/4/5 VF SUPERCHARGED | 2000 IMOLA RED M5 DINAN S | 2001 PHOENIX YELLOW M3 | 2002 JET BLACK M5 | 2003 ESTORIL BLUE X5 4.6is ]
I support
Want to meet other enthusiasts in the area?
is for you!
TWITTER/millakins & INSTAGRAM/millakins
Milla is offline   Reply With Quote
Old 05-02-2006, 07:52 PM   #35
PYRITE
My Ride: 1965 Ford Mustang
You absolutely rock dude!
PYRITE IS SOLD!!
Welcome "KRYPTONITE"...
PYRITE is offline   Reply With Quote
Old 06-05-2006, 10:34 AM   #36
EIAlfonso
My Ride: 2011 535xi M Sport
Well after nearly two years of my shade being busted it kind fell on me this weekend so I think it's time to fix it.
One of the metal clips, that looks like it's part of the cover itself, bent and broke off.
My question is can this be replaced or do I have to buy an entirely new shade?
Here's a picture of what I'm talking except one of the metal prongs on my cover is busted.
EIAlfonso is offline   Reply With Quote
Old 06-05-2006, 10:43 AM   #37
bimmer07
Banned
bimmer07's Avatar
My Ride: //////////M
Send a message via AIM to bimmer07
anybody have the part # for this new motor??
Edit: the part # for the updated module is 67 61 6 92 87 56 and the part # for our old one is 67 61 6 92 46 85 according to real oem ours was ENDED on 9/2002 but the other one was added on 9/2002 so i think ya.
bimmer07 is offline   Reply With Quote
Old 07-29-2006, 12:32 PM   #38
EIAlfonso
My sunshade driver was bent, luckily the repir kit came with a new one, how do you install that piece?
Do I need to remove the headliner?
This is what it's supposed to look like but mine is bent upwards and out of the track
The new piece supplied with the repair kit is much wider and sturdier. I'll take pics later
Old 07-29-2006, 09:58 PM   #39
Jet 163
If i want to take just the sunshade out to reupholster it, do i need to remove the glass?
Jet 163 is offline   Reply With Quote
Old 07-29-2006, 11:53 PM   #40
EIAlfonso
I belive so, the only way to remove it is by unscrewing the clips from the top and you can't access them if the glas is between you and the cover.
Luckily removing the glass is the easy part
