Xenon headlights blinking (not flashing) simultaneously for 5-10 minutes - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-09-2019, 10:59 PM   #1
SD Pete
My Ride: 2005 ILB E46 M3
Every time I turn on the headlights (low beams), they both flash simultaneously for about 5-10 minutes,. Then they both stop flashing at the same time.
Video
I just replaced the DS2s, but the problem's still there. Any thoughts?
TIA,
Pete
SD Pete is offline   Reply With Quote
Old 07-09-2019, 11:05 PM   #2
325ciLover
My Ride: 2004 325ci
I have no clue what it could be but I'm definitely following this one! Sounds interesting and that there is an easy fix using pa soft, but I don't know the setting.
Sent from my ONEPLUS A6000 using Tapatalk
325ciLover is offline   Reply With Quote
Old 07-11-2019, 04:35 PM   #3
TerraPhantm
My Ride: M3 & ZHP
Did it ever work properly? Any changes you can think of (even if not lighting related) around the time it started doing this?
Sponsored Links
Advertisement
Old 08-01-2019, 09:21 PM   #4
SD Pete
Still trying to figure things out. Thankfully, they still come on after 5 minutes or so...
No other mods or work done for quite a while before it started occurring.
Old 08-04-2019, 01:55 PM   #5
G-Hots
My Ride: ///M3 & 328ci
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
Video won't load up for me... but sounds like the issue I had years ago. Check your tail light ground wires until you find the corrosion/ wiring break/ burnt out connector. Trace the brown ground wire (tail light harness). usually the connector itself will either burn out / corrode & that's what causes what you described. LCM goes haywire over a lousy cable
G-Hots is offline   Reply With Quote
