DIY: Z4 Electric Fan Conversion for E46 - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-13-2019, 04:20 PM   #21
wfx32
My Ride: 330xi (04/05) auto
Originally Posted by Andy325is View Post
5) For 600W fan: Use dremel-type tool or saw to remove lower right arm on frame of cooling fan that will reside where the A/C compressor is located
Originally Posted by wfx32 View Post
Originally Posted by itongx View Post
did you have coolant temp datalog when running with this configuration and any issue so far seem low clearance between the engine and the fans
these 600W fans were installed on stock Z4 and X3 with 'hot climate' package back in 2005. so they should fit the regular (non M3) E46 just fine, as long as you [1] convert the three pin connector and [2] remove that lower right arm so that it clears the AC compressor.
wfx32 is offline   Reply With Quote
Old 08-16-2019, 12:44 AM   #22
itongx
My Ride: 323i'01
Year: 2001
Model: E46-EssVT1
Transmission: AT
from the image it slighlty difference in fan size ? believe that e46 used 16" and what about x3 and z4 are they 19"
itongx is offline   Reply With Quote
Old 08-16-2019, 07:15 PM   #23
wfx32
mount points on the radiator are the same (plastic rivet on driver side, torx screw on passenger side). the issue seems to be the depth of the fan. hence andy is removing that one piece of the plastic cage. i am just about ready to do the 05 so i will share some more pictures of the install.
Old 08-17-2019, 01:28 AM   #24
itongx
My Ride: 323i'01
Year: 2001
Model: E46-EssVT1
Transmission: AT
x3 fan should not direct swap as mount point is difference than z4 and e46 but with a little modification we can use x3 fan with e46. note that motor is same except the shrould of the fan x3 is higher
Old 08-17-2019, 06:44 AM   #25
wfx32
interesting.. what modification to the mount point? i just re-measured between the mount points and both are 20.5 inches?
bear in mind i am replacing the mechanical fan clutch on the inside of the radiator with the electrical fan from the x3 .. not the aux fan on the outside of the radiator.
Old 08-17-2019, 07:02 AM   #26
itongx
My Ride: 323i'01
Year: 2001
Model: E46-EssVT1
Transmission: AT
just done mind see pic below show what the mount point is differnce in height instead of bolt on you need to drill new hold to mount it but it work fine to me
https://www.dropbox.com/s/0sy5mnrh7r...22315.jpg?dl=0
https://www.dropbox.com/s/hf42oaxzrj...32355.jpg?dl=0
https://www.dropbox.com/s/m1xe3tsn0z...60805.jpg?dl=0
Old 08-17-2019, 07:26 AM   #27
wfx32
oh thank you. i see now. the width is the same but the height is different. so the bottom inserts on the e46 radiator will not suffice for the X3 fan. can you share a picture of your new drill hold/mount?
Old 08-17-2019, 07:36 AM   #28
itongx
My Ride: 323i'01
Year: 2001
Model: E46-EssVT1
Transmission: AT
note that the bottom of the fan fits very well to the radiator but only the top side need to drill the hole and I hold it with cable tile and the other side use pieces of metal to hold it with original screw
Old 08-17-2019, 07:43 AM   #29
wfx32
excellent, thanks, i was afraid of damaging the radiator. very good that someone has already done this.
Old 08-17-2019, 09:32 AM   #30
itongx
My Ride: 323i'01
Year: 2001
Model: E46-EssVT1
Transmission: AT
next time I will find only Z4 fan should to swap but the fan itself able to use E65 / E83 / E85 as what I known
