The Comprehensive E46 Brake Upgrade Guide - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 06-14-2019, 09:28 PM   #41
swordsman11868
My Ride: 2003 325i
So Iím gong to need brakes sometime this year
Iíd like to put on drilled rotors for the look. I donít track or do canyons.
Whatís the consensus on drilled? Did they solve the cracking issues?
If I install Eline (Chinese) from Amazon will they last 50k miles? Or will I have to redo it in 20k?
I put brakes on so seldom I donít even know what the industry standards are.
Thanks.
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 06-14-2019, 10:42 PM   #42
YoitsTmac
My Ride: 01 330Ci "Mia"
For these cars, drilled isnít much of an upgrade if at all. Theyíre more expensive, more prone to cracking, and blanks do great. I would just get better blanks.
YoitsTmac is offline   Reply With Quote
Old 06-15-2019, 07:37 PM   #43
swordsman11868
My Ride: 2003 325i
While I agree I was just going for looks.
Old 06-15-2019, 09:29 PM   #44
YoitsTmac
Your car, if you want it, go for it! My first brake DIY was drilled rotors, be prepared that because of the holes, thereís a, whatís the word. It was so long ago, but there was an unforeseen noise that came under medium to hard braking. I think it was because of how air is under pressure or vacuum in the holes as the pads clasp the rotor. YMMV of course.
Old 06-21-2019, 08:00 PM   #45
swordsman11868
My Ride: 2003 325i
Is the cheap (Eline) ok in your opinion or should I go with the more expensive Brembo/Stoptech/etc rotors?
Old 06-22-2019, 09:59 AM   #46
YoitsTmac
I think eline is what I had. Although there wasnít anything inherently wrong with the product, the way it performed is not something Iíd ever want to do again. The noise, honestly the way the steel looked. It looked like a cheap product, and there something always just. Weird, about the feel of the brakes. Nothing insane just, off.
Itís like when you eat the same fast food at a different location than usual - itís fine to eat, but itís not the same as what youíre used to, but you itís close enough and you accept it as the same. But given the choice between that new location and the old, youíd probably prefer the original choice. Hope that analogy makes sense.
Old 06-23-2019, 08:35 PM   #47
swordsman11868
My Ride: 2003 325i
Thanks for the info.
After having done some reading it looks like Zimmerman are made in Germany and FCP has a drilled set for sale.
Now I just need to decide which pad to use. :-/
Thereís a lot of choices!
Suggestions?
Old 06-24-2019, 02:41 PM   #48
YoitsTmac
PFC-Z pads. Great possible modulation when cold, one or two good stops makes it bite right at the top and hard. Lots of brake dust if that's important to you though.
Old 07-17-2019, 01:51 AM   #49
Aussigazza
My Ride: E46 330i and M3
Year: 1999
Model: Now 330i
Transmission: 6 Speed M3
I have spare new rear M3 rotors and M3 calipers.
Your write up talks about machining the front carriers to put M3 on 330i.
Already have csl upgrade on front.
What is required to put the rear M3parts on my 330i?
Garry
Aussigazza is online now   Reply With Quote
