Bmw e46 320d diagnostic fail - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-26-2019, 07:01 AM   #1
nenov
Hi everyone, i'm new here. I have BMW E46 320D 150hp facelift 2002.
I'm having trouble attaching the diagnostic. I've tried a bmw scanner and delphi. Interestingly, the Kess v2 connects to the car without a problem.
nenov is offline   Reply With Quote
Old 01-15-2020, 11:32 AM   #2
nenov
Up
Old 01-16-2020, 07:24 AM   #3
markusmarkus
My Ride: 2018 M240i
Google BMW E46 hidden OBC functions. Test #9 will show you the voltage as seen by the computer. I suspect the voltage from the battery is low.
Sponsored Links
Advertisement
Old 01-22-2020, 04:05 AM   #4
nenov
these are the values
ID:	792007   Click image for larger version
ID:	792009   Click image for larger version
ID:	792011   Click image for larger version
Old 01-22-2020, 06:53 AM   #5
markusmarkus
My Ride: 2018 M240i
Hmmm, obviously your OBC isnt like the one in US cars as its showing the temperature. When you say you have problems with both a BMW and a Delphi scanners, what exactly do you mean? What does the Kess scanner tell you? What software on you computer are you using?
Check the voltage at jumper post under the red plastic cover under the hood. Use the engine for the ground.
Old 01-22-2020, 08:32 AM   #6
LL i am
My Ride: 2001 325ci
Senior, you just misread. 12.3 vdc
LL i am is offline   Reply With Quote
Old 01-22-2020, 11:37 AM   #7
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
What does this mean? Provide a clear explanation with details.
Old 01-22-2020, 12:27 PM   #8
LL i am
My Ride: 2001 325ci
i think what was meant is problem attaching the scanner to the obd port
Old 01-22-2020, 04:04 PM   #9
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Right, but physically or electronically or software doesn't connect or can only access certain modules or something else? I can think of a lot of things that match OP's description.
